How reduce bandwidth when transcoding
m3z
Post Sat Nov 15, 2014 9:48 am
I send video to my TV Sony Bravia KDL 40EX710 using Serviio. The profile is Sony Bravia TV (2010)
But when video is h264 1080p, on fast moving scene, it stuttering and after a some time TV reboot !
At this moment the bandwith is maximum ~ 20000 kbps
I try to put maxVBitrate=10000 and 5000 to reduce bandwitth in the profile Sony Bravia TV (2010) but witout result.
Mesured bandwidth stay at same level.
What's wrong ?
NX3
Post Sun Nov 16, 2014 8:37 am
Re: How reduce bandwidth when transcoding
Is the file being transcoded to mpeg2? Are you wired or over WiFi?
NX3
Post Sun Nov 16, 2014 8:47 am
This is on all matching files not just one? And firmware is updated?
m3z
Post Sun Nov 16, 2014 6:20 pm
Hello NX3
And many thanks for your help
Yes Tv uses wired connexion and TV firmware is up to date.
It's a matroska H264, file that should be converted to mpeg2 because my tv is only compatible with that format.
You can see down there the ffmep output.
I monitor network output bandwidth and cpu directly on my Synology NAS.
Hope this help !
ffmpeg version 2.0.2 Copyright (c) 2000-2013 the FFmpeg developers
  built on May 29 2014 11:42:17 with gcc 4.6.3 (crosstool-NG 1.17.0)
  configuration: --prefix=/usr/syno --incdir='${prefix}/include/ffmpeg' --arch=i686 --target-os=linux --cross-prefix=/usr/local/i686-pc-linux-gnu/bin/i686-pc-linux-gnu- --enable-cross-compile --enable-optimizations --enable-pic --enable-gpl --enable-shared --disable-static --enable-version3 --enable-nonfree --enable-libfaac --enable-encoders --enable-pthreads --disable-bzlib --disable-protocol=rtp --disable-muxer=image2 --disable-muxer=image2pipe --disable-swscale-alpha --disable-ffserver --disable-ffplay --disable-devices --disable-bzlib --disable-altivec --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libmp3lame --disable-decoder=amrnb --disable-encoder=zmbv --disable-encoder=dca --disable-encoder=ac3 --disable-encoder=ac3_fixed --disable-encoder=eac3 --disable-decoder=dca --disable-decoder=eac3 --disable-decoder=truehd --cc=/usr/local/i686-pc-linux-gnu/bin/i686-pc-linux-gnu-ccache-gcc --enable-yasm --enable-libx264 --enable-encoder=libx264
  libavutil      52. 38.100 / 52. 38.100
  libavcodec     55. 18.102 / 55. 18.102
  libavformat    55. 12.100 / 55. 12.100
  libavdevice    55.  3.100 / 55.  3.100
  libavfilter     3. 79.101 /  3. 79.101
Input #0, matroska,webm, from '47 Ronin FRENCH 2013 1080p x264 AC3 [MorphisM].mkv':
    creation_time   : 2014-03-22 14:46:12
  Duration: 01:58:43.14, start: 0.000000, bitrate: 2582 kb/s
    Chapter #0.0: start 0.000000, end 267.559000
      title           : 00:00:00.000
    Chapter #0.1: start 267.559000, end 672.088000
      title           : 00:04:27.559
    Chapter #0.2: start 672.088000, end 987.820000
      title           : 00:11:12.088
    Chapter #0.3: start 987.820000, end 1211.836000
      title           : 00:16:27.820
    Chapter #0.4: start 1211.836000, end 1612.319000
      title           : 00:20:11.836
    Chapter #0.5: start 1612.319000, end 1862.944000
      title           : 00:26:52.319
    Chapter #0.6: start 1862.944000, end 2170.627000
      title           : 00:31:02.944
    Chapter #0.7: start 2170.627000, end 2616.614000
      title           : 00:36:10.627
    Chapter #0.8: start 2616.614000, end 3014.511000
      title           : 00:43:36.614
    Chapter #0.9: start 3014.511000, end 3299.421000
      title           : 00:50:14.511
    Chapter #0.10: start 3299.421000, end 3594.049000
      title           : 00:54:59.421
    Chapter #0.11: start 3594.049000, end 4197.735000
      title           : 00:59:54.049
    Chapter #0.12: start 4197.735000, end 4439.018000
      title           : 01:09:57.735
    Chapter #0.13: start 4439.018000, end 4752.247000
      title           : 01:13:59.018
    Chapter #0.14: start 4752.247000, end 5057.386000
      title           : 01:19:12.247
    Chapter #0.15: start 5057.386000, end 5580.825000
      title           : 01:24:17.386
    Chapter #0.16: start 5580.825000, end 5935.555000
      title           : 01:33:00.825
    Chapter #0.17: start 5935.555000, end 6281.609000
      title           : 01:38:55.555
    Chapter #0.18: start 6281.609000, end 6518.303000
      title           : 01:44:41.609
    Chapter #0.19: start 6518.303000, end 7123.136000
      title           : 01:48:38.303
    Stream #0:0: Video: h264 (High), yuv420p, 1920x800, SAR 1:1 DAR 12:5, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(fre): Subtitle: subrip (default) (forced)
      title           : French Forced
    Stream #0:2: Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default)
devsk
Post Sun Dec 28, 2014 7:42 am
NX3
Post Sun Dec 28, 2014 11:13 am
I had a 2010 Sony, you could flood the set and cause it to reboot. I never worked out the bandwidth / cpu limit as I inherited a 2011 set which didn't have this problem.
