Serviio won't transcode .mp4 to Xbox 360
AmericanNuke
Post Sat Nov 22, 2014 9:49 pm
So I'm new to Serviio and I apologize in advance if someone has already posted this question, but, my Xbox 360 picks up Serviio, pulls up the videos, but says they are an unrecognized file and can not be played. They are .mp4 files and i have searched high and low for a solution to this but have found none. (It's connected via CAT6 Ethernet)
I'm running Windows 7 HE with an intel i5 processor. Everything with Serviio was setup fine, the log itself shows no errors, but I can't pull up the ffmpeg log from the cmd. My Serviio file was installed in the regular program file but when i try to access it via cmd, it can not be found. (viewtopic.php?f=5&t=960)
C:\User\Admin>cd"\ProgramFiles\Serviio\lib
The system cannot find the path specified.
Maybe I'm doing it wrong but any help with getting the ffmpeg log and fixing this problem will help.
Post Tue Nov 25, 2014 12:33 pm
Re: Serviio won't transcode .mp4 to Xbox 360
Try
    cd "\Program Files\Serviio\lib"
    or
    cd "\Program Files (x86)\Serviio\lib"
Note the spaces - they are important. You may also have to run the cmd as an elevated process (Run as Administrator). Having said that, why not access it using Windows Explorer (or My Computer).
Make sure your Xbox is assigned to the correct profile in Serviio Console, Status tab (should be the Xbox 360 profile). Is this all mp4's or just some? MediaInfo is probably better for providing details on mp4's (see viewtopic.php?f=5&t=4510). Also may pay to post the Serviio log file when attempting to play the file (located in "\Program Files\Serviio\log").
AmericanNuke
Post Fri Nov 28, 2014 7:44 pm
DenyAll,
I followed your instructions and got farther then what I did on my own. Ran cmd as Admin, typed in all the info, came up with access is denied. Then out of frustration I tried it again and got a new error, Unable to find a suitable output format for 'version'. Version: Invalid Argument
As stated before the log shows nothing about me even trying to play the video on my xbox 360, and yes they are all .mp4. I will try the mediainfo as well.
Complete name                            : C:\Users\Addison\Desktop\Serviio Files\The-Walking-DeadSeason-5--Episode-1---ENG-.mp4
Format profile                           : Base Media
Codec ID                                 : isom
File size                                : 384 MiB
Duration                                 : 43mn 56s
Overall bit rate                         : 1 222 Kbps
Writing application                      : Lavf54.59.106
Format profile                           : High@L3.1
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 43mn 56s
Bit rate                                 : 1 800 Kbps
Frame rate                               : 25.000 fps
Bits/(Pixel*Frame)                       : 0.078
Stream size                              : 566 MiB
Writing library                          : x264 core 129
Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=24 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=1800 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Codec ID                                 : 40
Duration                                 : 43mn 56s
Bit rate                                 : 128 Kbps
Sampling rate                            : 44.1 KHz
Stream size                              : 40.2 MiB (10%)
Hope this helps more. And thanks for being patient with me while I figure this out.
Post Tue Dec 02, 2014 11:45 am
I can't see why this wouldn't work. To confirm, you (or Serviio automatically) have assigned the Xbox 360 profile to the device (in Serviio Console, Status tab, Renderer Profiles) and transcoding is enabled?
Need to confirm that ffmpeg is installed - your log file will tell you. Also try navigating to it in Windows Explorer (My Computer). Alternatively you can use my WinHelper tool to access ffmpeg and copy the data to the clipboard - see viewtopic.php?f=17&t=12136 and viewtopic.php?f=17&t=12136&p=80505#p80505. You can also use this tool to remux the file in case it is corrupted somehow.
Post Thu Dec 04, 2014 9:08 pm
This should play natively, so no transcoding needed. if it doesn't it probably means the console has a problem with the file's encoding and you'll have to reencode it.
AmericanNuke
Post Sun Dec 07, 2014 6:39 pm
I appreciate all the help with this problem. I will get to work on reencoding the videos and see if it helps.
Users browsing this forum: Google [Bot] and 29 guests
