Serviio on DSM 5.1-5004 (DS1513+)
zuffa.patrik
Post Thu Nov 27, 2014 9:58 am
Hi guys, i have a problem with my Synology & Serviio server. I've installed correctly Java and also Serviio package on my Synology DS1513+ but I'm able only to access the MediaBrowser, not the console. I don't have icon on desktop and also on Start Menu. How can i solve this issue? Thank you.
boschhd
Post Sun Nov 30, 2014 11:17 am
Re: Serviio on DSM 5.1-5004 (DS1513+)
This is how it is supposed to look: there is no icon to link to the library.
When you go to the serviio page in the package center you will find a link to the mediabrowser in the bottom left corner.
Or if you know you synology's ip this probably will work: http://your synology's ip here:23424/mediabrowser/#/login
regards
Henk
zuffa.patrik
Post Mon Dec 01, 2014 2:05 pm
Hi Henk,
Thanks for reply. The problem is that i cannot login....
Users browsing this forum: No registered users and 176 guests
