Post Thu Nov 27, 2014 4:16 pm
spietrza wrote:I just installed ServiiGo ver 4.3.2 but i didint find any information about how use this soft with ChromeCast.
Ofc when i press play i can choose other player LocalCast and movie start but transcoding doesnt work ??
if anyone solve this problem ??
memberlist.php?mode=viewprofile&u=655
Post Thu Nov 27, 2014 6:40 pm
Chromecast support is disabled by default because I'm currently using an old and unsupported version of the media player library that and as such it may break at any point. I'm not using the official one because it does not work well unless you fully re-encode the video during the transcoding process. There is an open bug which Google have accepted, but no ETA on a fix.
Please email me at the support address/pm me with your email address and I will give you the details on how to enable it, with the warning that it may break at any point.
ServiiGo (Android 3G/4G/WiFi Playback App) Developer: More info
Player: Sony BDP S370 | Server: Debian 6.0 x86
HowTo: Provide details of a video file that doesn't play
NX3
Post Thu Nov 27, 2014 9:40 pm
Chromecast support isn't working currently [DIZZY FACE]
Post Thu Nov 27, 2014 9:50 pm
NX3 wrote:Chromecast support isn't working currently [DIZZY FACE]
Going to need more details....
NX3
Post Thu Nov 27, 2014 9:55 pm
Sorry that was meant to post above based on last update. I thought you were saying it's probably broken and my experience is it no longer works. So I can send to the CC device and it initiates, serviio on tv, see the tv program meta data I.e screenshot. However it sticks on that screen with play symbol spinning but never starts.
Post Thu Nov 27, 2014 9:58 pm
NX3 wrote:Sorry that was meant to post above based on last update. I thought you were saying it's probably broken and my experience is it no longer works. So I can send to the CC device and it initiates, serviio on tv, see the tv program meta data I.e screenshot. However it sticks on that screen with play symbol spinning but never starts.
I had no reason to believe it would currently be broken, just that there is no guarantee it won't in the future.
Have you checked your Serviio log for an error?
I'm away this weekend so won't be able to test until Monday evening.
NX3
Post Thu Nov 27, 2014 10:07 pm
Thanks for quick reply, I'll check over the weekend
Post Thu Nov 27, 2014 10:19 pm
NX3 wrote:Thanks for quick reply, I'll check over the weekend
Just did a quick test and it worked fine for me.
snowflake7
Post Mon Dec 01, 2014 3:26 pm
Testing 1.5 Presentation settings. I noticed that if I disable an entire "branch" say "Audio" It is still listed in the ServiiGo browser. This is not consistent with the web-based MediaBrowser.
Not sure if this is the Thread where you want this info relayed.
Post Tue Dec 02, 2014 7:16 pm
snowflake7 wrote:Testing 1.5 Presentation settings. I noticed that if I disable an entire "branch" say "Audio" It is still listed in the ServiiGo browser. This is not consistent with the web-based MediaBrowser.
This is how it has always worked and is by design. Doing so simplifies things and won't affect most users, and as it does not affect the number of clicks/action the user must perform to reach content I felt the benifits were worth it.
Pleblo
Post Mon Dec 08, 2014 2:01 am
Will or anyone else with Amazon Fire Stick.
Does anyone know if the Amazon Fire stick works with ServiiGo?
Been thinking of getting one but wanted to make sure it works with it.
Thank you,
Jim
Post Mon Dec 08, 2014 7:55 am
Pleblo wrote:Will or anyone else with Amazon Fire Stick.
Thank you,
Jim
Not sure, I belive it is just a lower powered Fire TV which can run APKs (rather than Chromecast which is very different), so it could work, but again the UI won't be optimised.
Pleblo
Post Mon Dec 08, 2014 5:12 pm
Thanks Will. Ill give it a try and see how it goes. Was only 24.00 at best buy the other day.
bengio
Post Wed Dec 10, 2014 9:31 pm
Hi Pablo I'm interested about your test on Amazon Fire TV stick. I follow you. Bye
Inviato dal mio Xperia S utilizzando Tapatalk
ServiiGo beta tester
Pleblo
Post Fri Dec 12, 2014 3:12 am
bengio wrote:Hi Pablo I'm interested about your test on Amazon Fire TV stick. I follow you. Bye
Sure ill let you know but it wont' be till after Xmas getting one for Xmas.
SSJSephiroth
Post Thu Dec 18, 2014 4:02 am
Just picked up a chromecast and would love to use serviigo with it. I understand it's not perfect, but I'm ok with that :-).
Post Thu Dec 18, 2014 8:26 am
Here are the details for how to activate Chromecast support. Unfutunately the only way to get everything working with newer versions of MPL on Chromecast is to force transcoding to ensure it stays below a certain bitrate. This change has been made for 1.5 so once it comes out I will be updating the client and receiver app to require Serviio 1.5. This means that if you have a low powered server that works now it may not be fast enough to stream HD content once full transcoding is activated. (E.g. my Intel D525 is not fast enough :()
Also remember that as an experimental feature, that this may break, be removed, or turned into a paid feature at anytime without notice.
    Goto Menu->About
    Tap 5 times on the ServiiGo logo
    In the developer mode dialog, type the word "Cast" (without the quotes), and press enter on your keyboard
    The app will restart
    Goto Menu->About
    Scroll down, and you should see 'CastCompanionLibrary-Android' in the list of libraries
    You should now see the cast icon once connected to a server when a Chromecast is availble
sailorickm
Post Thu Dec 18, 2014 2:00 pm
Will, does what you say about forcing transcoding apply to every file, or just when casting?
Post Thu Dec 18, 2014 6:26 pm
sailorickm wrote:Will, does what you say about forcing transcoding apply to every file, or just when casting?
Sorry if that wasn't clear, this is a change to the Chromecast profile so it impacts casting non h264 mp4 files to a Chromecast. Normal playback is not affected (and casting to more powerful devices such as Android TV also won't be affected once I work out how to tell the difference).
Post Mon Dec 22, 2014 9:02 am
I've just uploaded a new update which adds support for the new browsing categories that have been added in the latest Serviio beta. As it also contains library changes i've just uploaded it to the beta channel, and if all goes well I will promote it to the production channel in a few days time.
==== 4.4 ====
*Added full support for Serviio 1.5
*Various minor bug fixes and improvements
*Updated libraries and build tools
