Live Stream doesn't show in Serviio
Georower
Post Tue Dec 09, 2014 11:27 am
Hi guys,
I've set-up a live stream from my Desktop using VLC. The stream works well as I can see it from other PC's. I've also added it to Serviio console library where it is shown under Online resources without any problems.
My problem is that on my TV (Sony Bravia) under Video/Online there is no item to show. Can anyone point to me what I should do to make it work?
Thanks,
George
Post Tue Dec 09, 2014 8:35 pm
Re: Live Stream doesn't show in Serviio
Does it show in MediaBrowser?
Post Tue Dec 09, 2014 10:44 pm
As per the wiki
Finally, to setup Serviio to play the stream, add your PC's static address to the Serviio Console/Online Sources/Live Stream/Video in the form http://192.168.1.10:8081 and name it “Desktop”. (Note that zip has advised that the stream must be running, as instructed above, when the link is added to the console, else Serviio will not accept the link or display it in the Online menu.) Then on the TV click on the “Desktop” icon and the stream should play.
Georower
Post Wed Dec 10, 2014 6:33 am
No, it's not showing in MediaBrowser. I've done the steps in the wiki and it is being shown in the Media Library with the name Desktop and a satellite dish at its left. I can also play the stream on another PC using VLC and the stream's URL address.
Post Wed Dec 10, 2014 6:14 pm
