Servio Console window will not open Ubuntu 14.04
mark_macrae
Post Wed Dec 10, 2014 3:26 am
I searched the forums for this problem, assuming it must be common... but haven't found an answer.
I just downloaded and unpacked Serviio into my home directory. I'd just read that it would replace uShare for streaming video to my Xbox 360 since I updated Ubuntu and that stopped working.
Anyway, I start the serviio.sh server ok, then open a new terminal to run the console (serviio.sh). After a few moments, there is a flash of a window opening and closing, the serviio icon appears in the launcher bar as if it is running... but I cannot find the window, nor can I switch to the window using alt-tab.
I checked the log and there are no clues:
2014-12-09 22:15:21,791 INFO [ServiioConsole] Initializing Serviio Console
2014-12-09 22:15:21,807 INFO [ServiioConsole] Starting Serviio Console
2014-12-09 22:15:26,438 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2014-12-09 22:15:27,578 INFO [Messages] Loaded console message bundle for locale: en
2014-12-09 22:15:30,774 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2014-12-09 22:15:31,709 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2014-12-09 22:15:39,575 INFO [FeedUpdaterThread] Started looking for information about online resources
2014-12-09 22:15:39,576 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-12-09 22:15:39,578 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-12-09 22:15:39,579 INFO [PlaylistMaintainerThread] Started looking playlist changes
Just for fun, in case it helps somebody find my problem, here is the log from the server launch:
2014-12-09 22:15:08,759 INFO [MediaServer] ------------------------------------------------------------------------
2014-12-09 22:15:08,770 INFO [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f+)
2014-12-09 22:15:08,770 INFO [MediaServer] Petr Nejedly 2009-2014
2014-12-09 22:15:08,770 INFO [MediaServer] http://www.serviio.org
2014-12-09 22:15:08,770 INFO [MediaServer] Java 1.7.0_65-Oracle Corporation
2014-12-09 22:15:08,770 INFO [MediaServer] OS Linux amd64 3.13.0-40-generic
2014-12-09 22:15:08,770 INFO [MediaServer] File encoding: UTF-8
2014-12-09 22:15:08,770 INFO [MediaServer] Headless mode enabled: true
2014-12-09 22:15:08,770 INFO [MediaServer] User: mark
2014-12-09 22:15:08,770 INFO [MediaServer] User home dir: /home/mark
2014-12-09 22:15:08,771 INFO [MediaServer] Temp dir: /tmp
2014-12-09 22:15:08,771 INFO [MediaServer] ------------------------------------------------------------------------
2014-12-09 22:15:08,982 INFO [WebServer] Socket buffer set to 65535 bytes
2014-12-09 22:15:09,001 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-12-09 22:15:09,056 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-12-09 22:15:09,056 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-12-09 22:15:09,079 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-12-09 22:15:09,105 INFO [DatabaseManager] Using DERBY database language
2014-12-09 22:15:11,076 INFO [MediaServer] ------------------------------------------------------------------------
2014-12-09 22:15:11,076 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2014-12-09 22:15:11,084 INFO [Device] Created UPnP Device with UUID: 7c03e23b-dd40-3855-8e20-f7d9756dc143, bound address: 192.168.1.17
2014-12-09 22:15:11,839 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2014-12-09 22:15:12,081 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2014-12-09 22:15:12,095 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2014-12-09 22:15:12,100 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2014-12-09 22:15:12,102 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2014-12-09 22:15:12,103 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2014-12-09 22:15:12,124 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2014-12-09 22:15:12,139 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2014-12-09 22:15:12,140 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2014-12-09 22:15:12,141 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2014-12-09 22:15:12,152 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2014-12-09 22:15:12,170 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013)' (id=sony2013)
2014-12-09 22:15:12,179 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2014-12-09 22:15:12,181 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2014-12-09 22:15:12,222 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2014-12-09 22:15:12,223 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2014-12-09 22:15:12,224 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2014-12-09 22:15:12,262 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2014-12-09 22:15:12,278 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2014-12-09 22:15:12,280 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2014-12-09 22:15:12,288 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2014-12-09 22:15:12,294 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2014-12-09 22:15:12,294 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2014-12-09 22:15:12,295 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2014-12-09 22:15:12,296 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2014-12-09 22:15:12,302 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2014-12-09 22:15:12,303 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2014-12-09 22:15:12,304 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2014-12-09 22:15:12,309 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2014-12-09 22:15:12,311 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2014-12-09 22:15:12,316 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2014-12-09 22:15:12,317 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2014-12-09 22:15:12,319 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2014-12-09 22:15:12,320 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2014-12-09 22:15:12,321 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2014-12-09 22:15:12,322 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2014-12-09 22:15:12,323 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2014-12-09 22:15:12,325 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2014-12-09 22:15:12,326 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2014-12-09 22:15:12,335 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2014-12-09 22:15:12,337 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2014-12-09 22:15:12,343 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2014-12-09 22:15:12,344 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2014-12-09 22:15:12,346 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2014-12-09 22:15:12,348 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2014-12-09 22:15:12,349 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2014-12-09 22:15:12,350 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2014-12-09 22:15:12,499 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2014-12-09 22:15:12,509 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2014-12-09 22:15:12,511 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2014-12-09 22:15:12,512 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2014-12-09 22:15:12,513 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2014-12-09 22:15:12,514 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2014-12-09 22:15:12,516 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2014-12-09 22:15:12,525 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2014-12-09 22:15:12,527 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2014-12-09 22:15:12,614 INFO [PluginCompilerThread] Looking for plugins at /home/mark/serviio-1.4.1.2/plugins
2014-12-09 22:15:12,615 INFO [PluginCompilerThread] Started looking for plugins
2014-12-09 22:15:12,616 INFO [UpdateChecker] Checking if a new version is available
2014-12-09 22:15:13,202 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version 1.2.6-7:1.2.6-1~trusty1 Copyright (c) 2000-2014 the FFmpeg developers
2014-12-09 22:15:13,203 WARN [FFMPEGWrapper] FFmpeg is not compiled with libass support, rendering subtitles (hardsubs) will not work.
2014-12-09 22:15:13,452 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2014-12-09 22:15:13,508 INFO [WebServer] WebServer starting on port 8895
2014-12-09 22:15:13,508 INFO [Device] Updated bound IP address of Device with UUID: 7c03e23b-dd40-3855-8e20-f7d9756dc143, bound address: 192.168.1.17
2014-12-09 22:15:13,515 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2014-12-09 22:15:13,517 INFO [EventDispatcher] Starting EventDispatcher
2014-12-09 22:15:13,518 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2014-12-09 22:15:13,540 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface wlan1 (wlan1) and address 192.168.1.17, timeout = 0
2014-12-09 22:15:13,542 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2014-12-09 22:15:13,542 INFO [RendererSearchSender] Searching for Renderer devices
NX3
Post Wed Dec 10, 2014 9:58 am
Re: Servio Console window will not open Ubuntu 14.04
Your running the serviio-console.sh not just serviio.sh twice? Just double checking...
mark_macrae
Post Wed Dec 10, 2014 12:21 pm
Yes
