[TOOLS] FileBot TV Renamer and Subtitle Downloader
rednoah42
Post Tue Nov 12, 2013 3:04 am
Re: [TOOLS] FileBot TV Renamer and Subtitle Downloader
FileBot 3.8 is out! Get it here!
This new major release brings new support for uploading subtitles and renaming music videos as well as updates to GUI and episode/movie matching that'll make things work much more smooth.
Changes:
* Support for OpenSubtitles Subtitle Upload (experimental)
* Support for music videos in Audio mode (may require chromaprint-tools 1.0 or higher)
* Support for alias names in matching and naming
* Improved Episode matching and Series detection
* Improved Movie detection
* Improved User guidance
* Improved caching and cache updates
* Format Editor with full Groovy syntax highlighting (thanks to RSyntaxTextArea)
* Calling with -clear-cache or -clear-prefs will now clear & exit
* Support --filter expressions in Movie mode
* Exclude list check/update support (i.e. ignore files that have already been processed in previous runs)
* Fix TheMovieDB artwork API issues
* New little utility to help with escaping arguments
Xmantium
Post Tue Nov 12, 2013 7:11 am
Just tried this, thankyou so much, works much better than theRenamer to organise my media for Serviio.
FileBot has much more options and customisation.
rednoah42
Post Thu Dec 11, 2014 10:20 am
FileBot 4.5.3 is out! Get it here!
This is a new minor release brings lots of bugfixes and improvements.
Features:
* Change Output Folder button in Format Dialog
* Extract All will now only extract not-already-extracted files from the selected archives
* Improved support for non-English names
* Improved support for subtitle tags and language detection
* New binding {output}
* Lots of optimizations and usability improvements
* Lots of bugfixes
Changes:
* OpenSubtitles now requires login due to heavy abuse
* Clicking [X] when user selection is required during auto-detection will abort processing
rednoah42
Post Fri May 13, 2016 5:16 pm
FileBot 4.7 is out! Get it here!
This is a new major release brings lots of improvements in almost all aspects. Lots of new features! Lots of new bindings! Lots of internal performance improvements!
Features:
Smart Mode for handling Movies, TV Shows, Anime and Music all at once
• Improved movie / episode auto-detection
• Support for TheMovieDB in Episode Mode
• Support for Renaming Folders (i.e. auto-delete left-behind empty folders)
• Resolve relative formats against the Media root folder (instead of the parent folder)
Send To context menu for Episodes / Filter / List panels
• Improved Filter tools and List tool
• Fix various OpenSubtitles Search/Download and Upload issues
• Fix various TheTVDB / AniDB / TVMaze issues
• Fix various multi-episode detection issues
• Fix various ID3 Tags lookup issues
• Fix various UI/UX issues
• Performance and caching improvements
• Improved logging and error messages
• Plex Naming Standard binding {plex}
• Use range multi-episode formatting by default when using {sxe} or {s00e00}
{s00e00} binding will now evaluate to TheTVDB Airdate Season/Episode numbers for AniDB absolute episode numbers.
• Subtitle language auto-detection when using the {lang} binding
• Subtitle language/category extension binding {subt}
• Spoken languages binding {languages}
• Stereoscopic 3D binding {s3d}
• A-Z folder binding {az}
• Just-in-time localization binding {localize} (e.g. {localize.German.Title})
• Filesize bindings {bytes}, {megabytes} and {gigabytes}
• Generic MediaInfo bindings {video}, {audio}, etc are now multi-stream bindings (and {videos}, {audios}, etc have consequently been removed)
• New CLI operation -revert to revert previous -rename operations
• CLI option --conflict now supports index conflict resolution behaviour
@file syntax for command-line argument passing
• Scripts from the online repository (e.g. fn:sysinfo) are now code signed and cryptographically secured against malicious tampering (not just HTTPS transport encryption)
plittlefield
Post Thu Jun 23, 2016 2:39 pm
Hello Folks,
I am having an issue with Serviio Pro 1.6.1 not recognising (and thereby not showing) an entire TV Series because the folder is missing .nfo information for each episode.
For example, if I use either Bubble UPnP on my phone, or the new VLC 2.0 on my tablet, neither "Game of Thrones" or "Penny Dreadful" are listed in the Library.
Is there a script or add-on to the filebot -script fn:artwork.tvdb which can generate an .nfo file for each episode, and not just the TV show itself?
Paully
Previous
Users browsing this forum: No registered users and 82 guests
