My Experience...
Christopher_Povey
Post Thu Feb 17, 2011 12:28 pm
My Experience...
This is the best media server I have come across! I have had some issues though... For example I have a set of four Divx avi files from the same source which stream to my Sony BDP-S570 perfectly, but error on a Panasonic Viera TV. However this seems to be an issue with the TV as the same files on a USB stick would not play either. Oddly, when burnt on to a DVD a Panasonic Blu-ray player played them fine!
My only other minor gripe is I own a Yamaha AV amp which also supports media streaming (for music only). When I was using WMP11 it worked fine. However, though Serviio can see my amp as an unknown device, the amp itself cannot see Serviio. Any ideas how I can fix this, as I have to now play streamed MP3 files through my Sony BDP-S570 instead (which is hooked up to the Yamaha Amp)?
Keep up the good work.
Chris.
Chris
Running Serviio on Intel Q6700 Windows 7 Ultimate x64 PC feeding a Sony BDP-S570, Pansonic TX-L37G20B, and a XBox 360.
Managed with Serviidroid via HTC One X
Post Thu Feb 17, 2011 12:40 pm
Re: My Experience...
that could be because there is no profile for you amp yet and you posted the infromation on your amp here at the forums so that the community can help you make a profile ??????
HOWTO: Provide supported formats of a device
Christopher_Povey
Post Thu Feb 17, 2011 12:46 pm
Ok. I am at work at the moment. I cannot remember the exact model number. I can dig out the manual and detail what file formats it supports etc, when I get home.
Chris
Post Thu Feb 17, 2011 12:47 pm
follow the link mate :) it explainns what u need to do once your home :)
Christopher_Povey
Post Thu Feb 17, 2011 12:52 pm
Cerberus wrote:follow the link mate :) it explainns what u need to do once your home :)
:oops: Missed the link! Will do once I get home! :)
Chris
Post Thu Feb 17, 2011 1:28 pm
I assume that the player uses Search method for browsing media, which is not supported by Serviio (only Browse method is). Detailed log should confirm this.
Christopher_Povey
Post Thu Feb 17, 2011 5:03 pm
Bits of the Debug log that might be if use:
My Yamaha RX-N600D AV Amp is on 192.168.0.13:
2011-02-17 16:52:46,140 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.13:2049
2011-02-17 16:52:46,140 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.13:2049
2011-02-17 16:52:47,109 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629 from 192.168.0.13 (headers = [Host: 192.168.0.10,User-Agent: YAMAHA Network Receiver,Accept: */*,Connection: close])
2011-02-17 16:52:47,109 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.13
2011-02-17 16:52:47,109 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-02-17 16:52:56,171 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.13:2049
2011-02-17 16:52:56,171 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.13:2049
2011-02-17 16:52:57,781 DEBUG [WebServer] Incoming connection from /192.168.0.13:2050
2011-02-17 16:52:57,781 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629 from 192.168.0.13 (headers = [Host: 192.168.0.10,User-Agent: YAMAHA Network Receiver,Accept: */*,Connection: close])
2011-02-17 16:52:57,781 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.13
2011-02-17 16:52:57,781 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-02-17 16:53:06,218 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.13:2049
2011-02-17 16:53:06,218 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.13:2049
2011-02-17 16:53:06,343 DEBUG [WebServer] Incoming connection from /192.168.0.13:2051
2011-02-17 16:53:06,343 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629 from 192.168.0.13 (headers = [Host: 192.168.0.10,User-Agent: YAMAHA Network Receiver,Accept: */*,Connection: close])
2011-02-17 16:53:06,343 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.13
2011-02-17 16:53:06,343 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
Is this the "Search Method"?
Chris
Post Thu Feb 17, 2011 5:48 pm
No, I think that after this it'll invoke method GetSearchCapabilities() and Serviio returns 'non supported'
Christopher_Povey
Post Thu Feb 17, 2011 6:48 pm
zip wrote:No, I think that after this it'll invoke method GetSearchCapabilities() and Serviio returns 'non supported'
Is it non supported then? Or does it just need a profile? I have the dump from the Intel UPnP Tool if that helps, but its quite a large block of text?
Chris
Post Thu Feb 17, 2011 7:25 pm
post
Christopher_Povey
Post Thu Feb 17, 2011 7:54 pm
Illico wrote:post
See attachment...
Edit: Deleted as was not the Yamaha Sink File.
Last edited by Christopher_Povey on Fri Feb 18, 2011 10:48 pm, edited 1 time in total.
Chris
Christopher_Povey
Post Thu Feb 17, 2011 7:59 pm
I've made a start on a profile:
   <Profile id="14" name="Yamaha Rx-N600D" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <User-Agent>YAMAHA Network Receiver</User-Agent>
         </HttpHeaders>
      </Detection>
The Console now names my amp! Not sure what the next step is though! :?
Chris
Post Thu Feb 17, 2011 8:19 pm
Christopher_Povey wrote:See attachment...
This is the serviio sink result, we need your yamaha renderer GetProtoccolInfo sink result.
Did it appear on the device list with INTEL tools?
Christopher_Povey
Post Thu Feb 17, 2011 8:30 pm
Oh! No then. The only item under Devices is Serviio. If I turn on my Sony BDP-S570 it appears! Is that that then? :(
Edit: Bit of background on the RX-N600D. The manual states it needs Windows Media Connect 2.0 to stream mp3 and wma files. However this is not compatible with WMP11. So I updated the firmware in the amp from Yamaha's website. It then streamed mp3 and wma files from WMP11. Serviio can see it, but it cannot see any music on my PC! :(
Last edited by Christopher_Povey on Thu Feb 17, 2011 8:51 pm, edited 1 time in total.
Chris
Post Thu Feb 17, 2011 8:51 pm
post your whole detailed log
Christopher_Povey
Post Thu Feb 17, 2011 8:57 pm
zip wrote:post your whole detailed log
2011-02-17 20:54:18,484 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2011-02-17 20:54:18,500 INFO  [MediaServer] ------------------------------------------------------------------------
2011-02-17 20:54:18,500 INFO  [MediaServer] Serviio DLNA media streaming server v 0.5 (rev. 975aa458693c)
2011-02-17 20:54:18,500 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-02-17 20:54:18,500 INFO  [MediaServer] http://www.serviio.org
2011-02-17 20:54:18,500 INFO  [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-02-17 20:54:18,500 INFO  [MediaServer] OS Windows XP x86 5.1
2011-02-17 20:54:18,500 INFO  [MediaServer] File encoding: windows-1252
2011-02-17 20:54:18,562 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-02-17 20:54:18,609 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-02-17 20:54:18,609 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2011-02-17 20:54:19,250 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2011-02-17 20:54:19,250 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2011-02-17 20:54:19,250 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2011-02-17 20:54:19,250 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2011-02-17 20:54:19,250 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2011-02-17 20:54:19,250 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2011-02-17 20:54:19,250 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2011-02-17 20:54:19,390 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-02-17 20:54:19,406 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2011-02-17 20:54:19,578 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-02-17 20:54:19,578 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2011-02-17 20:54:19,640 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-02-17 20:54:19,640 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2011-02-17 20:54:19,687 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-02-17 20:54:19,687 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2011-02-17 20:54:19,703 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-02-17 20:54:19,703 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2011-02-17 20:54:19,734 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-02-17 20:54:19,734 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2011-02-17 20:54:19,765 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-02-17 20:54:19,765 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2011-02-17 20:54:19,812 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-02-17 20:54:19,812 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2011-02-17 20:54:19,828 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-02-17 20:54:19,828 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2011-02-17 20:54:19,906 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-02-17 20:54:19,906 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2011-02-17 20:54:20,109 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player (EU)' (id=10)
2011-02-17 20:54:20,109 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 11
2011-02-17 20:54:20,359 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player (US)' (id=11)
2011-02-17 20:54:20,359 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2011-02-17 20:54:20,406 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-02-17 20:54:20,406 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2011-02-17 20:54:20,453 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-02-17 20:54:20,453 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2011-02-17 20:54:20,468 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha Rx-N600D' (id=14)
2011-02-17 20:54:20,468 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2011-02-17 20:54:20,468 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2011-02-17 20:54:20,531 INFO  [VideoDeliveryEngine] Cleaning transcode engine and its data
2011-02-17 20:54:20,531 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2011-02-17 20:54:20,546 DEBUG [VideoDeliveryEngine] Deleting temporary transcoded files from: C:\WINDOWS\TEMP\Serviio
2011-02-17 20:54:20,546 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-02-17 20:54:20,562 INFO  [WebServer] WebServer starting on port 8895
2011-02-17 20:54:20,750 INFO  [Device] Created UPnP Device with UUID: c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629, bound address: 192.168.0.10
2011-02-17 20:54:20,765 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-02-17 20:54:20,765 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-02-17 20:54:20,765 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-02-17 20:54:20,765 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-02-17 20:54:20,765 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-02-17 20:54:20,765 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-02-17 20:54:20,765 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1297976060765, LastAccessTime = 1297976060765, getTimeToLiveSeconds() = -1, createTime = 1297976060765 ]
2011-02-17 20:54:20,765 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-02-17 20:54:20,781 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-02-17 20:54:20,781 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-02-17 20:54:20,781 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-02-17 20:54:20,781 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-02-17 20:54:20,781 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-02-17 20:54:20,781 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-02-17 20:54:20,781 INFO  [CompositeCacheConfigurator] Finished configuration in 16 ms.
2011-02-17 20:54:20,781 DEBUG [DiscoveryManager] UPNP device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629 (192.168.0.10) is available
2011-02-17 20:54:20,781 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-02-17 20:54:20,781 INFO  [EventDispatcher] Starting EventDispatcher
2011-02-17 20:54:20,781 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-02-17 20:54:20,781 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Attansic L1 Gigabit Ethernet 10/100/1000Base-T Controller - Packet Scheduler Miniport) and address 192.168.0.10, timeout = 0
2011-02-17 20:54:20,781 INFO  [RendererSearchSender] Searching for Renderer devices
2011-02-17 20:54:20,781 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-02-17 20:54:20,828 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth0 (Attansic L1 Gigabit Ethernet 10/100/1000Base-T Controller - Packet Scheduler Miniport) and address 192.168.0.10, timeout = 0
2011-02-17 20:54:20,828 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2011-02-17 20:54:20,843 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.10:4771
2011-02-17 20:54:20,859 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Attansic L1 Gigabit Ethernet 10/100/1000Base-T Controller - Packet Scheduler Miniport) and address 192.168.0.10, timeout = 0
2011-02-17 20:54:20,859 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629
2011-02-17 20:54:20,875 DEBUG [WebServer] Incoming connection from /192.168.0.11:1149
2011-02-17 20:54:20,875 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629 from 192.168.0.11 (headers = [Host: 192.168.0.10:8895,Connection: Keep-Alive])
2011-02-17 20:54:20,875 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.11
2011-02-17 20:54:20,890 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.11
2011-02-17 20:54:20,937 DEBUG [WebServer] Incoming connection from /192.168.0.42:38912
2011-02-17 20:54:20,937 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629 from 192.168.0.42 (headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.0.10:8895,X-PANASONIC-Registration: VklFUkEAAAAAAAAAAAAAAAAAAAAAAAAAAAA=,X-PANASONIC-DMP-Profile: MPEG_PS_PAL JPEG_SM PV_DIVX_DIV3 PV_DIVX_DIV4 PV_DIVX_DIVX PV_DIVX_DX50 PV_DRM_DIVX_DIV3 PV_DRM_DIVX_DIV4 PV_DRM_DIVX_DIVX PV_DRM_DIVX_DX50])
2011-02-17 20:54:20,937 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.42
2011-02-17 20:54:21,015 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Panasonic Viera'
2011-02-17 20:54:21,015 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-02-17 20:54:21,046 DEBUG [WebServer] Incoming connection from /192.168.0.11:1152
2011-02-17 20:54:21,046 DEBUG [WebServer] Incoming connection from /192.168.0.11:1153
2011-02-17 20:54:21,046 DEBUG [WebServer] Incoming connection from /192.168.0.11:1154
2011-02-17 20:54:21,062 DEBUG [WebServer] Incoming connection from /192.168.0.11:1155
2011-02-17 20:54:21,062 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallJPG
2011-02-17 20:54:21,062 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largePNG
2011-02-17 20:54:21,062 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largeJPG
2011-02-17 20:54:21,062 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2011-02-17 20:54:21,062 DEBUG [WebServer] Incoming connection from /192.168.0.11:1156
2011-02-17 20:54:21,062 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-02-17 20:54:21,062 DEBUG [WebServer] Incoming connection from /192.168.0.11:1157
2011-02-17 20:54:21,062 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-02-17 20:54:21,062 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-02-17 20:54:21,078 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-02-17 20:54:22,828 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-02-17 20:54:23,125 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.13:2049
2011-02-17 20:54:23,125 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.13:2049
2011-02-17 20:54:24,437 DEBUG [WebServer] Incoming connection from /192.168.0.13:2153
2011-02-17 20:54:24,437 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629 from 192.168.0.13 (headers = [Host: 192.168.0.10,User-Agent: YAMAHA Network Receiver,Accept: */*,Connection: close])
2011-02-17 20:54:24,437 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.13
2011-02-17 20:54:24,437 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Yamaha Rx-N600D'
2011-02-17 20:54:26,843 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2011-02-17 20:54:32,843 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Attansic L1 Gigabit Ethernet 10/100/1000Base-T Controller - Packet Scheduler Miniport) and address 192.168.0.10, timeout = 0
2011-02-17 20:54:32,843 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629
2011-02-17 20:54:33,171 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.13:2049
2011-02-17 20:54:33,171 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.13:2049
2011-02-17 20:54:33,546 DEBUG [WebServer] Incoming connection from /192.168.0.42:64834
2011-02-17 20:54:33,546 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629 from 192.168.0.42 (headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.0.10:8895,X-PANASONIC-Registration: VklFUkEAAAAAAAAAAAAAAAAAAAAAAAAAAAA=,X-PANASONIC-DMP-Profile: MPEG_PS_PAL JPEG_SM PV_DIVX_DIV3 PV_DIVX_DIV4 PV_DIVX_DIVX PV_DIVX_DX50 PV_DRM_DIVX_DIV3 PV_DRM_DIVX_DIV4 PV_DRM_DIVX_DIVX PV_DRM_DIVX_DX50])
2011-02-17 20:54:33,546 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.42
2011-02-17 20:54:33,562 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.42
2011-02-17 20:54:33,562 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Panasonic Viera'
2011-02-17 20:54:33,687 DEBUG [WebServer] Incoming connection from /192.168.0.13:2154
2011-02-17 20:54:33,687 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629 from 192.168.0.13 (headers = [Host: 192.168.0.10,User-Agent: YAMAHA Network Receiver,Accept: */*,Connection: close])
2011-02-17 20:54:33,687 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.13
2011-02-17 20:54:33,687 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Yamaha Rx-N600D'
2011-02-17 20:54:34,765 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-02-17 20:54:43,109 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.13:2049
2011-02-17 20:54:43,109 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.13:2049
2011-02-17 20:54:44,625 DEBUG [WebServer] Incoming connection from /192.168.0.13:2155
2011-02-17 20:54:44,625 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629 from 192.168.0.13 (headers = [Host: 192.168.0.10,User-Agent: YAMAHA Network Receiver,Accept: */*,Connection: close])
2011-02-17 20:54:44,625 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.13
2011-02-17 20:54:44,625 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Yamaha Rx-N600D'
2011-02-17 20:54:44,765 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Attansic L1 Gigabit Ethernet 10/100/1000Base-T Controller - Packet Scheduler Miniport) and address 192.168.0.10, timeout = 0
2011-02-17 20:54:44,765 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629
2011-02-17 20:54:45,500 DEBUG [WebServer] Incoming connection from /192.168.0.42:49753
2011-02-17 20:54:45,500 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629 from 192.168.0.42 (headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.0.10:8895,X-PANASONIC-Registration: VklFUkEAAAAAAAAAAAAAAAAAAAAAAAAAAAA=,X-PANASONIC-DMP-Profile: MPEG_PS_PAL JPEG_SM PV_DIVX_DIV3 PV_DIVX_DIV4 PV_DIVX_DIVX PV_DIVX_DX50 PV_DRM_DIVX_DIV3 PV_DRM_DIVX_DIV4 PV_DRM_DIVX_DIVX PV_DRM_DIVX_DX50])
2011-02-17 20:54:45,500 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.42
2011-02-17 20:54:45,500 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Panasonic Viera'
2011-02-17 20:54:46,734 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:11:05
Edit: Just had another look in the log file it is repeating the following:
2011-02-17 21:00:04,031 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.13:2049
2011-02-17 21:00:04,031 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.13:2049
2011-02-17 21:00:04,937 DEBUG [WebServer] Incoming connection from /192.168.0.13:2187
2011-02-17 21:00:04,937 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629 from 192.168.0.13 (headers = [Host: 192.168.0.10,User-Agent: YAMAHA Network Receiver,Accept: */*,Connection: close])
2011-02-17 21:00:04,937 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.13
2011-02-17 21:00:04,937 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Yamaha Rx-N600D'
Chris
Post Thu Feb 17, 2011 10:03 pm
Is that all, nothing after the first log you posted? It asks for serviio's description and nothing after that. That is weird. It should work if that is the case.
Christopher_Povey
Post Thu Feb 17, 2011 11:37 pm
zip wrote:Is that all, nothing after the first log you posted? It asks for serviio's description and nothing after that. That is weird. It should work if that is the case.
All other devices on my network are now off. I'll do a clean log with just the Yamaha amp on...
Log attached. It snapshot as it still updating with the repeating Yamaha bit shown above...
I've added the following to profiles.xml:
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
Edit: Attachment deleted...
Last edited by Christopher_Povey on Fri Feb 18, 2011 10:49 pm, edited 1 time in total.
Chris
Post Fri Feb 18, 2011 12:19 am
Hmm, not sure what to do here. It gets the description but does nothing with it. I guess it wont work in the current state ;-/
Christopher_Povey
Post Fri Feb 18, 2011 7:58 am
zip wrote:Hmm, not sure what to do here. It gets the description but does nothing with it. I guess it wont work in the current state ;-/
Its ok, as my BDP- S570 is hooked up to the same amp and it works perfectly with Serviio. Actually thinking on it the user front end on the Sony is streets ahead of the Yamaha anyway so I use it for my music.
Only thing I have noticed is some of my music is missing album, artist details etc on the Sony so I need to check the ID tags in the MP3! Something to do when I am bored! :)
Thanks for the help though! :)
Edit: Turns out that the Sony BDP-S570 does not like Lyric tag in MP3 files. Once removed all the track details appear.
Chris
Return to User experiences
