Serviio does not find all files?
el-lobo
Post Thu Feb 17, 2011 9:38 pm
Hy there,
I am a new user of this nice program and think, this is the nicest software for dlna arround!
But I have a litle problem..
I use it for my SAMSUNG LE40B750 and my BlueRay System C5500. The setup was no problem, I can see my Notebook on both systems, but when I browse in the folders, I can not see all the content. I can see only 2 of the 8 *.vob files of the film in the folder, there are 8 vob files but I can see only 2 of them on both systems!
It seems, that SERVIIO does not recognize all files.
How could this happen?
Thank you for the support!
I am sorry for my bad englisch, but I hope you understand what I mean?
Regards from germany!
Martin
Post Thu Feb 17, 2011 9:47 pm
Re: Serviio does not find all files?
Just to be clear you tv is LE40B750 and not LE40C750?
now to your actual problem.
How long have you waited before testing on your TV? It can take up to 24hours to populate large librarys.
el-lobo
Post Thu Feb 17, 2011 9:54 pm
No, it is the 40B750 and the BlueRay Player HT-C5500. I am very happy with this combination, but the DLNA.... :-(
I did not wait a very long time, but the partition with my movies is not big, I have only 5 Movies stored on it. And a lot of MP3, but the MP3 files are found all very fast.
Is it neccessary to keep the serviio console runnig for scanning for all files? Or is it enough to start the service?
Thank you!
Post Thu Feb 17, 2011 9:57 pm
just the service but the library includes all of your files mp3 and movies so you may find if you give it time they will appear after the library is full built :)
el-lobo
Post Thu Feb 17, 2011 10:18 pm
ok, i will keep the service running for a day or so. thanks for the support!
Post Thu Feb 17, 2011 10:19 pm
you can check the log file for a list of added files
el-lobo
Post Thu Feb 17, 2011 11:17 pm
I checked the log-file, but something seems to be wrong:
2011-02-18 00:12:52,093 ERROR [DiscoverySSDPMessageListener] Cannot open multicast socket,will try again
java.net.BindException: Address already in use: Cannot bind
at java.net.PlainDatagramSocketImpl.bind0(Native Method)
at java.net.PlainDatagramSocketImpl.bind(Unknown Source)
at java.net.DatagramSocket.bind(Unknown Source)
at java.net.MulticastSocket.<init>(Unknown Source)
at org.serviio.util.MultiCastUtils.startMultiCastSocketForListening(MultiCastUtils.java:41)
at org.serviio.upnp.discovery.DiscoverySSDPMessageListener.run(DiscoverySSDPMessageListener.java:79)
at java.lang.Thread.run(Unknown Source)
2011-02-18 00:12:53,109 ERROR [DiscoverySSDPMessageListener] Cannot open multicast socket,will try again
These are only the last two entries of the log, but all this is repeating all the time. so my log file is about 6mb since 24hrs now...
I don´t know what these entries mean...
el-lobo
Post Thu Feb 17, 2011 11:18 pm
and there is no added file in the log... :cry:
Post Fri Feb 18, 2011 12:25 am
post the whole log. there is either something blocking needed port or you're not binding the server to the proper address
el-lobo
Post Fri Feb 18, 2011 7:08 pm
OK, this is the new, actual log, serviio created today as I startet the service... as you see, the service was running just a few minutes and the log is going already really big! ;-)
hope, you can see something.... btw, i did not configured my router until now. maybe this is the fault. which port do I have to open for serviio?
thanks again for the big support!
here is the new log:
2011-02-18 19:56:21,500 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-02-18 19:56:34,171 ERROR [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-02-18 19:56:34,187 INFO [Messages] Loaded console message bundle for locale: en
2011-02-18 19:56:37,812 INFO [ServiioConsole] Leaving Serviio Console
2011-02-18 19:56:44,765 INFO [MediaServer] ------------------------------------------------------------------------
2011-02-18 19:56:44,765 INFO [MediaServer] Serviio DLNA media streaming server v 0.5 (rev. 975aa458693c)
2011-02-18 19:56:44,765 INFO [MediaServer] Petr Nejedly 2009-2011
2011-02-18 19:56:44,765 INFO [MediaServer] http://www.serviio.org
2011-02-18 19:56:44,765 INFO [MediaServer] Java 1.6.0_21-Sun Microsystems Inc.
2011-02-18 19:56:44,765 INFO [MediaServer] OS Windows XP x86 5.1
2011-02-18 19:56:44,765 INFO [MediaServer] File encoding: windows-1252
2011-02-18 19:56:44,953 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-02-18 19:56:45,046 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-02-18 19:56:47,234 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-02-18 19:56:47,781 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-02-18 19:56:47,953 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-02-18 19:56:48,062 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-02-18 19:56:48,140 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-02-18 19:56:48,234 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-02-18 19:56:48,359 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-02-18 19:56:48,468 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-02-18 19:56:48,531 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-02-18 19:56:48,546 INFO [ServiioConsole] Starting Serviio Console
2011-02-18 19:56:48,656 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-02-18 19:56:48,718 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-02-18 19:56:49,281 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player (EU)' (id=10)
2011-02-18 19:56:50,156 INFO [Messages] Loaded console message bundle for locale: en
2011-02-18 19:56:50,156 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player (US)' (id=11)
2011-02-18 19:56:50,265 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-02-18 19:56:50,359 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-02-18 19:56:50,593 INFO [VideoDeliveryEngine] Cleaning transcode engine and its data
2011-02-18 19:56:50,687 INFO [WebServer] Socket buffer set to 65535 bytes
2011-02-18 19:56:50,734 INFO [WebServer] WebServer starting on port 8895
2011-02-18 19:56:50,937 INFO [Device] Created UPnP Device with UUID: 83403509-60a4-3ac0-bae1-94340baf2344, bound address: 192.168.1.2
2011-02-18 19:56:51,000 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-02-18 19:56:51,000 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-02-18 19:56:51,000 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-02-18 19:56:51,015 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-02-18 19:56:51,015 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-02-18 19:56:51,015 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-02-18 19:56:51,015 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1298055411015, LastAccessTime = 1298055411015, getTimeToLiveSeconds() = -1, createTime = 1298055411015 ]
2011-02-18 19:56:51,015 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-02-18 19:56:51,046 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-02-18 19:56:51,046 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-02-18 19:56:51,046 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-02-18 19:56:51,046 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-02-18 19:56:51,046 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-02-18 19:56:51,046 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-02-18 19:56:51,046 INFO [CompositeCacheConfigurator] Finished configuration in 46 ms.
2011-02-18 19:56:51,046 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-02-18 19:56:51,046 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-02-18 19:56:51,046 INFO [EventDispatcher] Starting EventDispatcher
2011-02-18 19:56:51,046 ERROR [DiscoverySSDPMessageListener] Cannot open multicast socket,will try again
2011-02-18 19:56:51,062 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-02-18 19:56:51,062 INFO [RendererSearchSender] Searching for Renderer devices
2011-02-18 19:56:52,062 ERROR [DiscoverySSDPMessageListener] Cannot open multicast socket,will try again
2011-02-18 19:56:53,062 ERROR [DiscoverySSDPMessageListener] Cannot open multicast socket,will try again
2011-02-18 19:56:54,078 ERROR [DiscoverySSDPMessageListener] Cannot open multicast socket,will try again
2011-02-18 19:56:55,078 ERROR [DiscoverySSDPMessageListener] Cannot open multicast socket,will try again
And this repeats all the time...
Post Fri Feb 18, 2011 7:16 pm
Is 192.168.1.2 the IP address of the PC? If yes port UDP 1900 is already taken on that PC by another application. Do you have any other UPnP software running?
el-lobo
Post Fri Feb 18, 2011 7:41 pm
Yes, 192.168.1.2 is my PC, and I also have another UPNP device running; my fritz.box router is also using UPNP. But in the moment I don´t know the actual port of it.
In between I checked some things... I deleted the renderer profile in the console, restartet everything, but the error message in the log still occurs!
there is also no binding adress configured...
Post Fri Feb 18, 2011 11:09 pm
No binding address is needed as it already picks the proper one. The local UDP 1900 port is the problem and it'll cause the server to not be visible on your device. Try to stop the other UPnP service(s).
el-lobo
Post Sat Feb 19, 2011 7:54 pm
Hi There!
thanks again for your support!
I stopped the other UPNP Service now. But the problem still exists! Dont know why, but in the log is a entry that the adress is already in use...
But, btw, the problem was not, that serviio does not find my devices! This is working well and I can see my folders on the TV and the BlueRay System.
The problem is, that the Service is not sharing all files! I have a folder with a movie contains 4 *vob files, but on my TV are only 2 of them!
That was the problem in the beginning. But maybe it is the same problem like the bad log entries?
Post Sun Feb 20, 2011 12:35 pm
no, it's a different problem.
Post ffmpeg -i for the unrecognized files
Users browsing this forum: Baidu [Spider] and 26 guests
