Serviio won't start up
JAC8
Post Sat Dec 20, 2014 10:43 am
Hi all, recently my serviio won't startup, there is always an error.
java.lang.ClassNotFoundException: org.serviio.console.ServiioConsole
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
I have looked at other post which have recommended installing the latest version of Java, which done and redone just to make sure, however this had no effect.
If anyone could help it would be greatly appreciated
Post Sun Dec 21, 2014 11:53 pm
Re: Serviio won't start up
Make sure you remove any old versions of Java before installing the latest - see http://java.com/en/download/faq/remove_ ... rsions.xml. Sometimes old versions are not apparent - this will find them and allow you to remove them.
Also, if you are on 64 bit windows you must install the 64 bit version of Java (usually as well as the 32 bit version that is required by any 32 bit internet browsers that you use).
JAC8
Post Mon Dec 22, 2014 2:19 pm
Thank you, got it up and working again.
Only thing in case anyone else has this problem I had to uninstall then reinstall serviio after removing the old versions of java
Users browsing this forum: No registered users and 72 guests
