Serviio erases all metadata if metadata source inaccessible
n3mmr
Post Thu Feb 17, 2011 11:55 am
If selected metadata resources are inaccessible, or otherwise detectably unusable, serviio should immediately stop updating the library.
Tests for usability/access should be performed up front.
Post Thu Feb 17, 2011 1:30 pm
Re: Serviio erases all metadata if metadata source inaccessi
Let's say the online DB is down for 2 days. In that case you would not be able to watch your new videos until it's up again. Don't think it's a good idea ;-)
n3mmr
Post Thu Feb 17, 2011 1:50 pm
It should at least not erase any data, but leave it as is, and just present what it already has, plus the "folders" view.
Post Thu Feb 17, 2011 2:27 pm
It does that? The online metadata is only checked the first time the file is found - it's never updated afterwards (unless you click Update video metadata). Files are only removed from library if the folder cannot be accessed anymore (e.g. external HDD is unplugged - in which case you should disable automatic scanning for that folder)
n3mmr
Post Fri Feb 18, 2011 7:39 am
certainly seemed that way to me: i e it was removed from the "nice" menues, and only remained available as "folder" view items.
Return to Feature requests
Users browsing this forum: Baidu [Spider] and 16 guests
