aac no temp output
Nazar78
Post Fri Feb 18, 2011 7:58 am
aac no temp output
Hi zip,
I've just started playing around with serviio. It was fun!
But I notice the ffmpeg came with Serviio won't work with aac as mentioned in the Support section without the switch "-strict experimental".
Since this is related with transcoding, would it possible to include other types of codecs in the targetVCodec and targetACodec? Of course if ffmpeg supports. eg. below I used a ffmpeg with libx264:
ffmpeg.exe -threads 8 -i C:\Users\Public\Videos\Movies\Unstoppable.2010.BluRay.1080p.DTS.x264-CHD\Unstoppable.2010.BluRay.1080p.DTS.x264-CHD.mkv -y -vcodec libx264 -fpre libx264-hq.ffpreset -b 20000k -maxrate 20000k -bufsize 5097k -r 23.98 -g 15 -copyts -copytb -acodec aac -ab 320k -ac 6 -map 0:0 -map 0:1 -strict experimental -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-8839-MPEG2TS.stf
Thanks for the great work!
Post Fri Feb 18, 2011 10:42 am
Re: aac no temp output
Serviio ships with FFmpeg without linked libx264 (licence) so it's not possible to transcode into H264.
