Flowplayer Logo
Wizzkidy
Post Sat Dec 27, 2014 11:06 pm
Flowplayer Logo
Hi all,
I bought a copy of serviio and use the media browser when at different locations, Is there any way to remove the flowplayer icon bottom left, I get this logo internally on my LAN as well as outside of my LAN
Currently running latest version on a freshly built server 2012 R2.
I did start getting some help from Zip but unfortunately I have not had any replies back regarding this, Is it suppose to be there? is it not? help?
Post Sun Dec 28, 2014 6:32 pm
Re: Flowplayer Logo
It's not supposed to be there. Can you post detailed log of starting the server and starting playing a single file in MB?
Wizzkidy
Post Sun Dec 28, 2014 7:16 pm
Re: Flowplayer Logo
Thanks Zip, Here is the detailed log, I stopped the service, enabled detailed logging, restarted the service and then played a file for 5 minutes, this is the output
I have uploaded it to Mega - https://mega.co.nz/#!PAIniYab!zfOvygd5F ... rgBfONuuSw
Post Sun Dec 28, 2014 7:53 pm
Re: Flowplayer Logo
Thanks, unfortunatelly all I can see are file library checks. Can you change this in log4j.xml
<param name="MaxFileSize" value="500KB" />
to
<param name="MaxFileSize" value="50000KB" />
, restart the service and post the logs again?
Wizzkidy
Post Sun Dec 28, 2014 8:15 pm
Re: Flowplayer Logo
Followed same procedure as before but changed what you requested, Yes I do have a LOT of stuff so this is probably why the log is so large, sorry about that,
here is the new link - https://mega.co.nz/#!LRBFlSwZ!h8WYMD4_Q ... 2jE5DW57Pg
Post Sun Dec 28, 2014 8:44 pm
Re: Flowplayer Logo
Thanks, I think I know what might be the cause (probably the .co.uk domain you're using). Can you confirm by trying to hit the MB via a public IP address, rather than the domain name?
I will try to get the fix in for 1.5
https://bitbucket.org/xnejp03/serviio/i ... g-for-some
Wizzkidy
Post Sun Dec 28, 2014 8:49 pm
Re: Flowplayer Logo
Yes this works, funny because I never thought about trying with IP only and I would like to use name but thanks be good to get this fix in, Thanks when do you expect 1.5 to be out out of curiosity?
Post Sun Dec 28, 2014 9:08 pm
Re: Flowplayer Logo
pretty soon
Users browsing this forum: Baidu [Spider], Google [Bot] and 48 guests
