Will Canon MTS Format Play??
serviiobbbb
Post Mon Dec 29, 2014 6:23 am
I have a Canon digital camcorder and about 3-4 years of HD .mts files that were recorded using this camcorder. I noticed on this page on the Serviio site, http://www.serviio.org/features, that MPEG-2 TS (.ts, .m2ts) are supported but no mention was made of .mts files. Before I take the time to download and setup Serviio, can anyone tell me if my .mts files will play on a new Sony Bravia TV using Serviio on a Windows 7 or Windows Vista PC?
Thanks in advance for the help!!!!
Post Mon Dec 29, 2014 1:36 pm
Re: Will Canon MTS Format Play??
They should. You might have to rename them to .mpeg or .ts or .m2ts.
To be sure you could post ffmpeg -i for one of the videos
serviiobbbb
Post Mon Dec 29, 2014 1:47 pm
I am new to Serviio so I am not sure what this means - "To be sure you could post ffmpeg -i for one of the videos" - could someone tell me what the ffmpeg -i means and what I need to do?
Thanks!!!
serviiobbbb
Post Mon Dec 29, 2014 2:14 pm
I think I figured out the ffmpeg -i... here is what I did. Let me know if more is needed and what I need to do to provide the requested additional detail.
Opened CMD prompt
C:\Users\xxx>"C:\Program Files\Serviio\lib\ffmpeg.exe" -i "C:\PATHDELETED\20141213104923.mts"
[mpegts @ 01AFEF00] max_analyze_duration 5000000 reached at 5003333 microseconds
Input #0, mpegts, from 'C:\PATHDELETED\20141213104923.mts':
Duration: 00:01:40.61, start: 0.471856, bitrate: 6582 kb/s
Program 1
Stream #0:0[0x1011]: Video: h264 (High) (HDMV / 0x564D4448), yuv420p, 1440x1
080 [SAR 4:3 DAR 16:9], 29.97 fps, 59.94 tbr, 90k tbn, 59.94 tbc
Stream #0:1[0x1100]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp,
256 kb/s
C:\Users\xxx>
Post Mon Dec 29, 2014 2:18 pm
yes, it should be fine
serviiobbbb
Post Mon Dec 29, 2014 2:20 pm
Great!!! Thanks for the quick reply!!!
serviiobbbb
Post Mon Dec 29, 2014 6:31 pm
Updated this post with more info:
- I have finally been able to get Serviio installed and running after a few challenges.
- I have added the shared folders for the .mts videos using the Console. I see the folders on my TV but once I drill into the folder, the TV says, "There are no items to display." Not sure if this means I didn't set something up correctly or if the .mts files will not play.
- I can see jpg files just fine on the TV. Haven't tried music yet.
- I tried adding .avi files to a Shared Folder that was already showing on the TV and the same folder that has .jpg files that I can see and did a force refresh but the .avi never came up on the TV
- I tried adding .avi files from a folder that is on a mapped network drive via the shared folders tab in Serviio Console - no luck there either - can't not see the files
- I can see the videos in the MediaBrowser but they don't show on the TV
My questions are:
- Why can't I see any of the video files on the TV?
- Is this a sharing or permissions issue of some sort?
Config: Win7 64bit PC, Sony Bravia TV
Post Tue Dec 30, 2014 1:45 pm
What does your shared folders tab in the console look like?
For shared drives, read the FAQ - it's probably access rights issue.
Which profile are you using for the TV?
