"The video data is not supported" - ua65f6400
gth
Post Sun Dec 21, 2014 4:35 am
Howdy folks,
Apologies if this has been asked before - I searched and couldn't see an exact match (although many seem rather vague). My issue is both Samsung TVs randomly halt playback and show a dialog of "The video data is not supported" - then offer to Skip or Stop this file. If I select stop and then play the file again, the video resumes (usually from where it stopped, or moments before) everything is fine for a random number of minutes (or even, in some cases, only 10-30 seconds) and it happens all over again. Each time it gets further in the video file and I've tried a LOT of different video files I have of various formats - the problem doesn't seem to be tied to any particular format. In order to provide a precise example, I'm downloading a reference copy of Big Buck Bunny so I can track the consistency of the error.
System: Thecus NAS -> separate gigabit LAN -> Windows x64 server -> serviio 1.4.1.2 -> gigabit switch -> TVs (i.e. no Wifi)
TVs: Samsung ua65f6400 and ua55f6400, being 65" and 55" respectively
I have a WDTV Live device as well, connected to the 55" and it can play all of the same content without error, beginning to end. But I'd prefer not to have to use it though, given the capabilities of the TVs and that I've already got server running 24x7. Not to mention all of the other cool features that Serviio would add, if I could get it working.
whatsupkramer
Post Sun Jan 04, 2015 12:05 pm
Re: "The video data is not supported" - ua65f6400
Hey
I have also come across this. I just upgraded my UA46ES6200 with a UA60H6400 and started having this problem.
Originally serviio (1.4.1.2) did not pick a profile, so I chose the Samsung E/F series.
I was thinking of updating the profiles with one of the Samsung H series on this forum to see if this resolves the issue.
Chris
Post Sun Jan 04, 2015 5:56 pm
The next version of Serviio will include an H Series profile that works quite well. I haven't encountered any unplayable files, although I do hit some with unsupported audio (usually Dolby TrueHD). I just let it play and change the audio track to the second one, which is usually Dolby Digital.
I'm disappointed that my Samsung BD player seems to have issues with the HD Audio bitstream though. My Sony players would pass it through with no problem, and my AV receiver would show the HD audio being decoded. The Samsung strips DTS Master Audio to the lossy DTS core, and as I mentioned gives an error with TrueHD. Although, a few TrueHD files will play. Samsung has more work to do with their DLNA processing.
whatsupkramer
Post Tue Jan 06, 2015 10:31 am
I installed the series h profile this afternoon after trying the generic profile for a day.
The generic profile still caused this fault to still occur however the resume function was lost causing us to have to fast forward each time it stops.
The series h profile still hase the fault but at least the resume function works.
The file that i am trying to play is a 720 mp4 file
I hope someone else has any ideas.
Chris
Post Tue Jan 06, 2015 1:38 pm
whatsupkramer wrote:I installed the series h profile this afternoon after trying the generic profile for a day.
Chris
The H Series profile that will be in the next version has some changes from the one found here in the forum. I can't say what Zip changed, but I haven't encountered any playback issues using it. There's also functionality that the current version of Serviio doesn't support, so you can't use the new profile with the existing version.
The only files I ever had any disconnect issues with were Blu-Ray HD rips with HD Audio. On my test server (the only one running the beta) I don't have one of those files, but I do have SD and HD MP4 and MKV files, and those have played just fine.
bobsmo
Post Tue Jan 06, 2015 6:16 pm
Better to start to get ready for the J series as well with Tizen...........
whatsupkramer
Post Wed Jan 07, 2015 9:12 am
Sounds good. I requested to be part of the beta program with no luck. I am assuming this is due to not being active in the fourm. Anyways when I get some time I will have a look in more details.
Chris
whatsupkramer
Post Wed Jan 07, 2015 1:15 pm
I ran the debug logs and the show stopped once with the video data is not supported, I have been through the code but I can not pick where the fault is.
2015-01-07 22:54:38,619 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49212: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,getMediaInfo.sec: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:38,619 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:38,619 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:38,620 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:38,620 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:38,620 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:38,620 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:38,620 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:38,620 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:38,620 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:38,620 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:38,623 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:38,623 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:38,623 DEBUG [GETMethodProcessor] Stream entity has length: 267279476
2015-01-07 22:54:38,623 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 267279476,Date: Wed, 07 Jan 2015 11:54:38 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 0-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,MediaInfo.sec: SEC_Duration=2550000;]]
2015-01-07 22:54:38,782 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-01-07 22:54:38,785 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49213: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=267279425-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:38,786 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:38,786 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:38,786 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:38,786 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:38,786 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:38,786 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:38,786 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:38,786 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:38,786 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:38,786 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:38,786 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:38,787 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:38,787 DEBUG [GETMethodProcessor] Stream entity has length: 51
2015-01-07 22:54:38,787 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 51,Date: Wed, 07 Jan 2015 11:54:38 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 267279425-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:38,808 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49214: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=1323332-,getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:38,808 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:38,808 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:38,808 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:38,808 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:38,808 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:38,808 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:38,808 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:38,808 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:38,808 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:38,808 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:38,809 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:38,809 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:38,809 DEBUG [GETMethodProcessor] Stream entity has length: 265956144
2015-01-07 22:54:38,809 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 265956144,Date: Wed, 07 Jan 2015 11:54:38 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 1323332-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:38,860 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49215: POST /serviceControl HTTP/1.1, headers = [Accept: */*,User-Agent: SEC_HHP_[TV]ExtraLarge/1.0 DLNADOC/1.50,Host: 10.0.0.4:8895,SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",CONTENT-TYPE: text/xml; charset="utf-8",Content-Length: 470,Connection: close]]
2015-01-07 22:54:38,861 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:38,861 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.0.45
2015-01-07 22:54:38,862 DEBUG [ContentDirectory] Browse() called for renderer UA60H6400 (profile sam_h) with parameters: objectID = V_S^SER_533^SSN_1^V_189461, browseFlag = BrowseMetadata, filter = *, startIndex = 0, count = 1, sortCriteria =
2015-01-07 22:54:38,862 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:38,862 DEBUG [VideoDAOImpl] Retrieving last episode for series 533
2015-01-07 22:54:38,863 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:38,863 DEBUG [GenreDAOImpl] Reading a Genre (id = 479)
2015-01-07 22:54:38,863 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:38,863 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461 and profile Samsung TV / player (h-series)
2015-01-07 22:54:38,863 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 618638)
2015-01-07 22:54:38,863 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_resetafterplay), returning it
2015-01-07 22:54:38,865 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2015-01-07 22:54:38,924 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:57132: HEAD /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2015-01-07 22:54:38,924 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:38,924 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:38,924 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:38,927 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:38,927 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:38,928 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:38,928 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:38,928 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:38,928 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mp4,Content-Length: 267279476,Date: Wed, 07 Jan 2015 11:54:38 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2015-01-07 22:54:39,846 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49217: GET /resource/618638/COVER_IMAGE HTTP/1.0, headers = [HOST: 10.0.0.4:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-01-07 22:54:39,846 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:39,846 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:39,846 DEBUG [ResourceDeliveryProcessor] Request for resource 618638 and type 'COVER_IMAGE' received
2015-01-07 22:54:39,846 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 618638)
2015-01-07 22:54:39,846 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 618638
2015-01-07 22:54:39,847 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 618638
2015-01-07 22:54:39,847 DEBUG [GETMethodProcessor] Stream entity has length: 3515
2015-01-07 22:54:39,847 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 3515,Date: Wed, 07 Jan 2015 11:54:39 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:42,136 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /10.0.0.45:54165s
2015-01-07 22:54:42,136 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /10.0.0.45:54165
2015-01-07 22:54:42,137 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /10.0.0.45:54165
2015-01-07 22:54:42,986 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 10.0.0.4, timeout = 0
2015-01-07 22:54:42,986 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 66333861-1e81-334b-9cff-028e77be7789
2015-01-07 22:54:44,131 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-01-07 22:54:44,135 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49220: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=3137810-,getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:44,135 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:44,135 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:44,135 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:44,135 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:44,135 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:44,136 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:44,136 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:44,136 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:44,136 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:44,136 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:44,136 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:44,136 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:44,136 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:44,137 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:44,137 DEBUG [GETMethodProcessor] Stream entity has length: 264141666
2015-01-07 22:54:44,137 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 264141666,Date: Wed, 07 Jan 2015 11:54:44 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 3137810-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:44,720 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-01-07 22:54:44,724 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49222: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=5102932-,getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:44,724 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:44,724 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:44,724 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:44,724 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:44,724 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:44,724 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:44,724 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:44,725 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:44,725 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:44,725 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:44,725 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:44,725 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:44,725 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:44,725 DEBUG [GETMethodProcessor] Stream entity has length: 262176544
2015-01-07 22:54:44,725 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 262176544,Date: Wed, 07 Jan 2015 11:54:44 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 5102932-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:44,786 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:35 (advertisement duration is 1800 sec.)
2015-01-07 22:54:45,253 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-01-07 22:54:45,258 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49224: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=6509891-,getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:45,258 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:45,258 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:45,258 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:45,258 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:45,258 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:45,258 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:45,258 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:45,259 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:45,259 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:45,259 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:45,259 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:45,259 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:45,259 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:45,259 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:45,259 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:45,259 DEBUG [GETMethodProcessor] Stream entity has length: 260769585
2015-01-07 22:54:45,259 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 260769585,Date: Wed, 07 Jan 2015 11:54:45 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 6509891-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:45,822 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-01-07 22:54:45,826 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49225: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=7451440-,getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:45,827 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:45,827 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:45,827 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:45,827 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:45,827 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:45,827 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:45,827 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:45,827 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:45,827 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:45,827 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:45,827 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:45,828 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:45,828 DEBUG [GETMethodProcessor] Stream entity has length: 259828036
2015-01-07 22:54:45,828 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 259828036,Date: Wed, 07 Jan 2015 11:54:45 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 7451440-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:46,301 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-01-07 22:54:46,305 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49226: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=8334831-,getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:46,305 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:46,306 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:46,306 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:46,306 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:46,306 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:46,306 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:46,306 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:46,306 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:46,306 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:46,306 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:46,306 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:46,306 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:46,307 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:46,307 DEBUG [GETMethodProcessor] Stream entity has length: 258944645
2015-01-07 22:54:46,307 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 258944645,Date: Wed, 07 Jan 2015 11:54:46 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 8334831-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:47,149 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-01-07 22:54:47,153 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49227: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=9193704-,getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:47,153 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:47,153 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:47,153 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:47,153 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:47,153 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:47,154 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:47,154 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:47,154 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:47,154 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:47,154 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:47,154 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:47,154 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:47,154 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:47,155 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:47,155 DEBUG [GETMethodProcessor] Stream entity has length: 258085772
2015-01-07 22:54:47,155 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 258085772,Date: Wed, 07 Jan 2015 11:54:47 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 9193704-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:47,900 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-01-07 22:54:47,905 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49228: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=10283953-,getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:47,905 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:47,905 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:47,905 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:47,905 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:47,905 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:47,905 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:47,905 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:47,905 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:47,906 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:47,906 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:47,906 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:47,906 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:47,906 DEBUG [GETMethodProcessor] Stream entity has length: 256995523
2015-01-07 22:54:47,906 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 256995523,Date: Wed, 07 Jan 2015 11:54:47 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 10283953-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:48,639 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-01-07 22:54:48,642 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49229: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=12052319-,getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:48,643 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:48,643 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:48,643 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:48,643 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:48,643 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:48,643 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:48,643 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:48,643 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:48,643 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:48,643 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:48,643 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:48,644 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:48,644 DEBUG [GETMethodProcessor] Stream entity has length: 255227157
2015-01-07 22:54:48,644 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 255227157,Date: Wed, 07 Jan 2015 11:54:48 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 12052319-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:48,653 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2015-01-07 22:54:48,656 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49230: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=12160086-,getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:48,656 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:48,656 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:48,656 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:48,656 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:48,656 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:48,656 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:48,657 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:48,657 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:48,657 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:48,657 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:48,657 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:48,657 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:48,657 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:48,657 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:48,666 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:48,666 DEBUG [GETMethodProcessor] Stream entity has length: 255119390
2015-01-07 22:54:48,666 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 255119390,Date: Wed, 07 Jan 2015 11:54:48 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 12160086-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:49,443 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-01-07 22:54:49,448 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49231: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=14082964-,getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:49,448 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:49,448 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:49,448 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:49,448 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:49,448 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:49,448 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:49,448 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:49,449 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:49,449 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:49,449 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:49,449 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:49,459 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:49,459 DEBUG [GETMethodProcessor] Stream entity has length: 253196512
2015-01-07 22:54:49,459 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 253196512,Date: Wed, 07 Jan 2015 11:54:49 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 14082964-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:49,763 DEBUG [SearchManager] Committing search index
2015-01-07 22:54:50,329 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-01-07 22:54:50,333 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49232: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=15708095-,getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:50,333 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:50,333 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:50,333 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:50,333 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:50,333 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:50,333 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:50,333 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:50,333 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:50,333 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:50,333 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:50,334 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:50,334 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:50,334 DEBUG [GETMethodProcessor] Stream entity has length: 251571381
2015-01-07 22:54:50,334 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 251571381,Date: Wed, 07 Jan 2015 11:54:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 15708095-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:50,347 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-01-07 22:54:50,350 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49233: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=15766545-,getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:50,350 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:50,350 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:50,350 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:50,350 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:50,350 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:50,350 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:50,350 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:50,351 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:50,351 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:50,351 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:50,351 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:50,351 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:50,351 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:50,351 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:50,395 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:50,395 DEBUG [GETMethodProcessor] Stream entity has length: 251512931
2015-01-07 22:54:50,395 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 251512931,Date: Wed, 07 Jan 2015 11:54:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 15766545-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:51,229 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-01-07 22:54:51,240 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49234: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=19203368-,getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:51,240 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:51,240 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:51,241 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:51,241 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:51,241 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:51,241 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:51,241 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:51,241 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:51,241 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:51,241 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:51,241 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:51,242 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:51,242 DEBUG [GETMethodProcessor] Stream entity has length: 248076108
2015-01-07 22:54:51,242 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 248076108,Date: Wed, 07 Jan 2015 11:54:51 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 19203368-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:52,841 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-01-07 22:54:52,844 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49236: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=17789315-,getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:52,844 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:52,845 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:52,845 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:52,845 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:52,845 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:52,845 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:52,845 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:52,845 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:52,845 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:52,845 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:52,845 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:52,845 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:52,846 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:52,846 DEBUG [GETMethodProcessor] Stream entity has length: 249490161
2015-01-07 22:54:52,846 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 249490161,Date: Wed, 07 Jan 2015 11:54:52 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 17789315-267279475/267279476,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-01-07 22:54:52,874 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-01-07 22:54:52,878 DEBUG [ServiioHttpService] Incoming request from /10.0.0.45:49237: GET /resource/189461/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=17842141-,getcontentFeatures.dlna.org: 1,Host: 10.0.0.4:8895,Connection: close]]
2015-01-07 22:54:52,878 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.45
2015-01-07 22:54:52,878 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:52,878 DEBUG [ResourceDeliveryProcessor] Request for resource 189461 and type 'MEDIA_ITEM' received
2015-01-07 22:54:52,878 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 189461 (local)
2015-01-07 22:54:52,878 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 189461)
2015-01-07 22:54:52,878 DEBUG [VideoDAOImpl] Reading a Video (id = 189461)
2015-01-07 22:54:52,878 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 189461, format AVC_MP4_MP_SD_AAC_MULT5 and profile Samsung TV / player (h-series)
2015-01-07 22:54:52,879 DEBUG [VideoDeliveryEngine] Delivering item '189461' for client 'Identifier=10.0.0.45, Profile=Samsung TV / player (h-series)'
2015-01-07 22:54:52,879 DEBUG [VideoDeliveryEngine] Delivering file 'Extant.S01E11.A New World.mp4' in native format
2015-01-07 22:54:52,879 DEBUG [MediaItemDAOImpl] Getting file of media item 189461
2015-01-07 22:54:52,879 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 189461) as read
2015-01-07 22:54:52,879 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-01-07 22:54:52,879 DEBUG [GETMethodProcessor] Stream entity has length: 249437335
Can anyone assist with this information?
Chris
whatsupkramer
Post Wed Jan 07, 2015 1:16 pm
I also ran the Invoke Get Protocol on the TV and got this
http-get:*:audio/L16:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO,http-get:*:image/png:DLNA.ORG_PN=PNG_TN,http-get:*:image/png:DLNA.ORG_PN=PNG_SM_ICO,http-get:*:image/png:DLNA.ORG_PN=PNG_LRG_ICO,http-get:*:image/png:DLNA.ORG_PN=PNG_LRG,http-get:*:audio/vnd.dolby.dd-raw:DLNA.ORG_PN=AC3;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AMR_3GPP;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=AMR_WBplus;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/x-sony-oma:DLNA.ORG_PN=ATRAC3plus;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_LTP_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_LTP_MULT7_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_MULT5_ADTS;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_MULT5_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L2_ADTS;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L3_ADTS;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L3_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_MULT5_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L2_ADTS_320;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO_320;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=BSAC_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=BSAC_MULT5_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL;DLNA.ORG_FLAGS=8D100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG1;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_NA_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_PAL;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_NTSC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_PAL_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_NTSC_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_ATRAC3plus;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_L2_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_L2_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_SP_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_SP_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG2_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG2_L2_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG2_L2_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_SP_G726;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_VGA_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_VGA_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_HEAAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_ATRAC3plus;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_ASP_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L5_SO_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L5_SO_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L5_SO_HEAAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_ASP_L5_SO_G726;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L4_SO_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L4_SO_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L4_SO_HEAAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_ASP_L4_SO_G726;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_H263_MP4_P0_L10_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_H263_3GPP_P0_L10_AMR_WBplus;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_CO_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_CO_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_CO_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_CO_MPEG2_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_CO_MPEG2_L2_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_CO_MPEG2_L2_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_3GPP_SP_L0B_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_3GPP_SP_L0B_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_H263_3GPP_P3_L10_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_HEAAC_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_HEAAC_L2_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_HEAAC_L2_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT7;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT7_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT7_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_BSAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_BSAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_HEAAC_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LTP_MULT7;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_ATRAC3plus;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3L_SD_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3L_SD_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3_SD_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_HEAAC_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_HEAAC_L2_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_HEAAC_L2_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_HEAAC_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L2_CIF30_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_BSAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_940;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_HEAAC_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_HEAAC_L2_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_HEAAC_L2_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT7;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT7_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT7_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_BSAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_BSAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_520;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_LTP_520;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L12_CIF15_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L1B_QCIF15_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_CIF30_AMR_WBplus;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_CIF15_AMR_WBplus;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AMR_WBplus;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_PRO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHM_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_MP3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_NA_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_NA_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:text/xml:SEC.COM_DIDLSIMAGE=1;SEC.COM_DIDLSAUDIO=1;SEC.COM_DIDLSVIDEO=1,http-get:*:image/jpeg:*,http-get:*:image/png:*,http-get:*:image/bmp:*,http-get:*:image/mpo:*,http-get:*:audio/mpeg:*,http-get:*:audio/x-ms-wma:*,http-get:*:audio/mp4:*,http-get:*:audio/x-m4a:*,http-get:*:audio/3ga:*,http-get:*:audio/ogg:*,http-get:*:audio/x-wav:*,http-get:*:audio/x-flac:*,http-get:*:smi/caption:*,http-get:*:video/x-msvideo:*,http-get:*:video/x-ms-asf:*,http-get:*:video/x-divx:*,http-get:*:video/x-ms-wmv:*,http-get:*:video/x-mkv:*,http-get:*:video/mp4:*,http-get:*:video/x-avi:*,http-get:*:video/avi:*,http-get:*:video/x-flv:*,http-get:*:video/mpeg:*,http-get:*:video/3gpp:*,http-get:*:video/webm:*
Chris
Users browsing this forum: No registered users and 83 guests
