Cannot mach title with "." in it
schmurfy
Post Fri Jan 02, 2015 9:49 am
Serviio is a really nice tool but I stumbled accross a difficult case...
I want to match ".hack" as in http://thetvdb.com/?tab=series&id=79099&lid=7 but the issue is no matter how I name the folder / files it always fails in different ways.
First I tried with the folder:
- Hack: it matches a tv serie by that name
- .hack: seems ignored by serviio, I suppose it only search for not hidden files
Then I tried with the files:
- hack_s01e01.avi : matched to the hack tv serie
- .hack_s01e01: this is what Filebot renamed my files to when I matched it but it is ignored (hidden file again I suppose since that's a Linux machine)
I also tried to add a tvshow.nfo but after fiddling around with it I quickly realized the file was completely ignored, after reading more on the forums I understand than it is either online metadata OR local xml files which is fine I suppose but if so how can I "hint" serviio to look for the right serie when the automatch fails miserably ?
I know perfectly well what the serie is, I just need a way to pass it to serviio to create the correct metadata :(
PS: I am running serviio on a Synology NAS.
Post Sun Jan 04, 2015 8:37 am
Re: Cannot mach title with "." in it
I think this one may take development work to resolve (something like https://bitbucket.org/xnejp03/serviio/i ... e-than-one). As I understand it anything after the "." is ignored by the filename -> metadata matching engine within Serviio.
Sometimes you can get a match by simply removing the "." from the filename but in this case it finds a valid match against a different series, so that won't work. So (unless anyone else knows something I am missing) at this stage I'm afraid these files will only appear under the "Folders" category in Serviio.
Post Sun Jan 04, 2015 6:00 pm
How about adding a year to the file name? I have one series that I had to do so (Anne of Green Gables (1985) S01E01 - Anne of Green Gables.mkv). Without the year I couldn't get the proper metadata.
schmurfy
Post Mon Jan 05, 2015 10:14 am
I forgot to mention it but I tried to name the folder "Hack (2003)" but it didn't help, I don't remember if I tried to add it in the filenames, I will try again.
Downtown
Post Mon Jan 12, 2015 4:09 am
I have a similar problem with the show Black-ish. I have to rename the show to blackish for it to work but it would be nice if it could ignore special characters before the S0xE0x in the filename.
Post Mon Jan 12, 2015 4:53 am
Good suggestion - have created a ticket: https://bitbucket.org/xnejp03/serviio/i ... de-special expanding it a little to cater for movie titles. Probably not as applicable to movies as from version 1.5 you can always nail these by adding the IMDB ID to the file name.
Users browsing this forum: Google [Bot] and 59 guests
