serviio on win7 32 bit and client on win 7 64 bit
telex
Post Mon Jan 12, 2015 8:38 pm
Serviio is running on my PC Win7 32 bit and its good working on TV and AVR.
But on my laptop (Win7 64bit) I can not see any files as client. I see the server and the directories but no contents....
Post Tue Jan 13, 2015 2:28 am
Re: serviio on win7 32 bit and client on win 7 64 bit
What client software are you using on the the Win 64bit PC? Windows Media Player is not a DLNA client - you need something like XMBC which can act as a DLNA client. Win64 will detect Serviio as a Media Server, but has no inherent DLNA capabilities to allow you scan the library or play the files.
But then... why? Why not simply use either Serviio Mediabrowser (particularly if the Win64 PC will be accessing the server across the Internet), or share the media files/folder directly with the Win64 PC - you can then run Windows Media Player, XMBC or any other player of choice.
telex
Post Tue Jan 13, 2015 1:35 pm
client software is win7 proffesional
what do I have to enter on browser to get the files on client laptop?
I have the files on windows share and can use it but I wanted to know why it is not shown on WMP..
Post Tue Jan 13, 2015 1:55 pm
telex wrote:client software is win7 proffesional
Like he said, WMP is not a DLNA client. It may see the server but doesn't show any of the media. There's nothing that can be done about that.
If you want to use MediaBrowser, you have to have the paid version of Serviio. When you first install Serviio, MediaBrowser is enabled for a test period (14 days I think), but after that you need a license to use the browser. I can even access my media from my work computer (if I wanted to, that is) with the proper settings in my firewall. If the client computer is inside the firewall, then you just open your browser (Firefox, Chrome or Internet Explorer for example) and enter the URL. See this page for more complete information: http://serviio.org/component/content/ar ... diabrowser
telex
Post Tue Jan 13, 2015 4:49 pm
I use the paid version long time. Which url I have to enter?
Post Tue Jan 13, 2015 6:35 pm
Look at the link I provided above. It has the information you need.
Users browsing this forum: Baidu [Spider] and 18 guests
