[SOLVED] network share not reading
trident
Post Mon Jan 12, 2015 11:06 pm
not sure if this if this has come up before
i have a solairs server that doing cifs share to my windows 8.1 machine
all my video stuff is on that share which open fine under windows
but if i put a add to the library it never pickup the file.
this is what in the log
2015-01-12 21:52:44,525 INFO [WebServer] WebServer starting on port 8895
2015-01-12 21:52:44,650 INFO [Device] Updated bound IP address of Device with UUID: 6bda01ee-619d-35d3-ae78-606a24dc288f, bound address: 192.168.1.84
2015-01-12 21:52:44,650 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-01-12 21:52:44,650 INFO [EventDispatcher] Starting EventDispatcher
2015-01-12 21:52:44,651 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-01-12 21:52:44,734 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth1 (Realtek PCIe GBE Family Controller) and address 192.168.1.84, timeout = 0
2015-01-12 21:52:44,734 INFO [RendererSearchSender] Searching for Renderer devices
2015-01-12 21:55:25,905 WARN [LibraryAdditionsCheckerThread] Folder 'M:\ANEMAI' is either not an existing directory or cannot be read due to access rights
2015-01-12 21:55:25,913 WARN [LibraryAdditionsCheckerThread] Folder 'M:\ANEMAI\Air Gear' is either not an existing directory or cannot be read due to access rights
2015-01-12 21:55:25,921 WARN [LibraryAdditionsCheckerThread] Folder 'M:\TV Show' is either not an existing directory or cannot be read due to access rights
2015-01-12 21:55:25,935 WARN [LibraryAdditionsCheckerThread] Folder '\\192.168.1.9\vol02_media\ANEMAI' is either not an existing directory or cannot be read due to access rights
2015-01-12 22:00:25,965 WARN [LibraryAdditionsCheckerThread] Folder 'M:\ANEMAI' is either not an existing directory or cannot be read due to access rights
2015-01-12 22:00:25,973 WARN [LibraryAdditionsCheckerThread] Folder 'M:\ANEMAI\Air Gear' is either not an existing directory or cannot be read due to access rights
2015-01-12 22:00:25,982 WARN [LibraryAdditionsCheckerThread] Folder 'M:\TV Show' is either not an existing directory or cannot be read due to access rights
2015-01-12 22:00:25,997 WARN [LibraryAdditionsCheckerThread] Folder '\\192.168.1.9\vol02_media\ANEMAI' is either not an existing directory or cannot be read due to access rights
2015-01-12 22:05:26,029 WARN [LibraryAdditionsCheckerThread] Folder 'M:\ANEMAI' is either not an existing directory or cannot be read due to access rights
2015-01-12 22:05:26,037 WARN [LibraryAdditionsCheckerThread] Folder 'M:\ANEMAI\Air Gear' is either not an existing directory or cannot be read due to access rights
2015-01-12 22:05:26,045 WARN [LibraryAdditionsCheckerThread] Folder 'M:\TV Show' is either not an existing directory or cannot be read due to access rights
2015-01-12 22:05:26,405 WARN [LibraryAdditionsCheckerThread] Folder '\\192.168.1.9\vol02_media\ANEMAI' is either not an existing directory or cannot be read due to access rights
2015-01-12 22:10:26,467 WARN [LibraryAdditionsCheckerThread] Folder 'M:\ANEMAI' is either not an existing directory or cannot be read due to access rights
2015-01-12 22:10:26,475 WARN [LibraryAdditionsCheckerThread] Folder 'M:\ANEMAI\Air Gear' is either not an existing directory or cannot be read due to access rights
so my question is what do i need to do to get the right s right for access
forgot to say this is on 1.4.1.2 and pro lic as well
thanks
Post Tue Jan 13, 2015 2:53 am
Re: network share not reading
trident
Post Wed Jan 14, 2015 12:53 pm
thanks for that
took a while but yet sorted
thanks again
trident
Post Thu Jan 15, 2015 8:48 pm
just update and again it not working
i did the same as the link did which work for the older version
is there something else i need to change.
i know the real fix is me to get am AD fully working on Solaris but that going to take sometime
any thing else i should look in the 1.5 release
thanks
trident
Post Fri Jan 16, 2015 2:05 pm
ok got it working
now to sort out all the stuff i have lol any way thanks am liking this it doing a nice job
Users browsing this forum: Baidu [Spider] and 73 guests
