Toshiba 32L3433DG Not Playing Bulgarian Subtitles
ALLEyezOnMe
Post Sat Jan 17, 2015 3:54 pm
Hey, guys!
We bought a Toshiba 32L3433DG TV-set for one of the other rooms and for some reason it is not displaying Bulgarian subtitles at all.
The subtitles section in Serviio is set as following:
Enable Subtitles and Enable extraction of subtitles embedded in video files are checked.
The subtitles I downloaded are encoded in UTF-8. Tried saving them as Unicode, but it did not make any difference.
Also, I checked the subtitles for any "weird"characters that may be messing things up, but there weren't any.
Looking forward to your most valuable input.
Cheers!
Post Sat Jan 17, 2015 5:21 pm
Re: Toshiba 32L3433DG Not Playing Bulgarian Subtitles
You don't need embedded subtitles checked, if you have external srt file.
You will probably have to check burned-in subtitles for your device though.
ALLEyezOnMe
Post Sat Jan 17, 2015 5:24 pm
zip wrote:You don't need embedded subtitles checked, if you have external srt file.
Thank you! I will give it a go and get back to you with the outcome. One more thing though, should I leave the Subtitle character encoding to UTF-8 and should I be changing the encoding of the subtitle file to Unicode, or just leave it as it is (it's UTF-8 by default I reckon)?
Post Sat Jan 17, 2015 5:31 pm
utf-8
momchil
Post Sun Oct 08, 2017 12:43 pm
Windows-1251
SOLUTION for subs - viewtopic.php?f=26&t=19265
Return to Toshiba
