Bug in serviio 1.5 (cannot browse Series)
gobater
Post Mon Jan 19, 2015 9:02 pm
Since I installed Serviio 1.5, I have problems on my TV (Samsung UE40D6500) browsing the Category "Series". My TV reports an error, and does display anything. The logfile looks fine (see attached file)
I am using the standard "Samsung C/D series" profile, without any modifications.
Browsing other categories works without any issues.
Using serviio 1.4.1.2 all categories work fine
Regards
PS: Using BubbleUpnp in my android tablet, I can browse "series" without problems. Maybe is a timing issue?
serviio.log.zip
serviio 1.5 logfile
(60.11 KiB) Downloaded 572 times
Post Mon Jan 19, 2015 9:13 pm
Re: Bug in serviio 1.5 (cannot browse Series)
Yes, log looks fine.
Did you install fresh or updated previous installation? Does it work in MediaBrowser?
gobater
Post Tue Jan 20, 2015 7:21 pm
I updated from 1.4.1.2 following the instructions on the website.
A clean reinstall helped. Library is currently being rebuilt but it seems to work fine.
Thank you
Post Wed Jan 21, 2015 1:52 pm
It might have been caused by your librabry still being upgraded when you were trying to browse.
