PACKAGE: Serviio 1.5 for QNAP NAS (ARM & x86 Intel)
IndividualLover
Post Tue Jan 20, 2015 5:07 pm
Re: PACKAGE: Serviio 1.4 for QNAP NAS (ARM & x86 Intel)
Xmantium, do you planning create qpkg for latest released Serviio 1.5 to x86 intel based QNAP?
Xmantium
Post Tue Jan 20, 2015 7:07 pm
Going to try to release ARM version tonight, my Intel QNAP is still in storage, I run my ARM version 24/7. Hope to release Intel version this week. Zip helped me out with the latest ffmpeg
IndividualLover
Post Tue Jan 20, 2015 7:58 pm
Thanks for the update Xmantium. We are waiting intel version.
Have a nice night ;)
new2serviio79
Post Thu Jan 22, 2015 9:35 pm
Xmantium, any chance the new ARM build will be able to support TS-x31 series (Cortex A9/A15 CPU platform?) I've tried a manual install and get the "platform not supported" error.
Xmantium
Post Sun Jan 25, 2015 8:26 pm
Re: PACKAGE: Serviio 1.5 for QNAP NAS (ARM & x86 Intel)
ARM: TS-x10, x12, x19, x20, x21
Serviio 1.5 Revision 1 - Includes latest ffmpeg and webui
Install the latest Java JRE_ARM from QNAP App Centre or here first - http://download.qnap.com/QPKG/JRE_ARM_8.6.0_arm-x19.zip
Due to recent house build, i will be providing Intel version soon
Users of ARM x31 and x31+, you will have to install JAVA JRE_ARM from here, since i dont have this model and they use a different ARM chip i wouldnt know how my ARM build will work.
Its easier to install Java with App Centre, look at the below screenshot, seach for JRE
Xmantium
Post Sun Jan 25, 2015 9:03 pm
new2serviio79 wrote:Xmantium, any chance the new ARM build will be able to support TS-x31 series (Cortex A9/A15 CPU platform?) I've tried a manual install and get the "platform not supported" error.
I love to own one of these new QNAP ARM models, I thought these are coming out next month?!
QNAP have moved from Marvell to Freescale ARM chips
Need to figure this out and may have a test build if your up for testing
alanimal
Post Mon Jan 26, 2015 10:19 pm
I am pretty keen to setup Serviio onto my TS-251 QNAP. I have installed the JRE app, should I wait until you release the intel version or is there a package I can download now to install? Thanks :)
new2serviio79
Post Tue Jan 27, 2015 2:20 am
Well I bought mine from Newegg here in the US mid-December...funny enough I got sick of waiting for the Synology DS-215!
Xmantium wrote:QNAP have moved from Marvell to Freescale ARM chips
I would certainly be up for some testing if you want to try a new build for x31!
jcsousa
Post Tue Jan 27, 2015 3:35 am
I am also waiting for the serviio 1.5 for my Qnap TS-251.
TIA
Serviio Pro on WIndows 8.1
Qnap TS-251 Intel® Celeron™ 2.41GHz Dual-Core Processor w/
2.58GHz Turbo RAM 1GB SO-DIMM DDR3L-1333
Xmantium
Post Tue Jan 27, 2015 8:40 pm
Regarding models TS-x31 and x31+, these use different arm chips and for some reason have a different method of installing apps.
You will have to install the right JRE installer -
http://www.qnap.com/i/uk/app_center/con ... 62080&hf=1
Can anyone try if my latest 1.5 ARM package works on these models
cool120
Post Tue Jan 27, 2015 9:40 pm
Can't try ARM QNAP, but can try Intel version with x51 models... :)
Tks for your works, and to help Servviio community !
IndividualLover
Post Thu Jan 29, 2015 12:07 pm
@Xmantium when will release qnap intel version?
Thanks for interesting, we are waiting intel version :D
Xmantium
Post Thu Jan 29, 2015 1:00 pm
I should have the Intel build tonight, was waiting on swoopx to make all the changes to web UI so it runs smoothly, he just messaged me saying is now complete.
The ARM build will have a new revision with this latest web UI for those not knowing how to update the web UI themselves
alanimal
Post Thu Jan 29, 2015 8:12 pm
I have setup my TS-251 and am successfully running Serviio PRO v 1.4.1.2 EVALUATION license - WebUI v 1.5.4
Do I need to buy a pro license so I can publish my videos over WAN? e.g. so I can watch them on my friends home theater?
Xmantium
Post Thu Jan 29, 2015 8:20 pm
Yes you can do that, unfortunately the version you installed is out of date, the web interface doesn't upload the licence as it should.
Tonight I'll have Serviio 1.5 ready with the latest web UI.
You can get the licence by going here http://www.serviio.org/buy-pro
alanimal
Post Thu Jan 29, 2015 8:26 pm
ok I will wait and install this :) thank you mate
Xmantium
Post Fri Jan 30, 2015 2:43 am
Here it is for those INTEL users who waited patiently!!
Ive tested it myself, please if you have any issues let me know.
Best to install the latest Java JRE first from your App Centre of your NAS or downloan manually from here - http://download.qnap.com/QPKG/JRE_8.6.0_x86.zip
Then install my QPKG from here - https://bitbucket.org/Xmantium/serviio- ... 1_x86.qpkg
IndividualLover
Post Fri Jan 30, 2015 2:52 pm
Thanks @Xmantium;
I'll inform you if i face to the any issue ;)
Xmantium
Post Sun Feb 01, 2015 7:43 pm
ARM users, theres a new revision that updates Revision 1 with the latest web interface that fixes the pro licence upload
https://bitbucket.org/Xmantium/serviio- ... m-x19.qpkg
ARM x31 and x31+ users, ive made a test build, this may not work, let me know how it works.
https://bitbucket.org/Xmantium/serviio- ... m-x31.qpkg
Java JRE_ARM for these x31 here or from your App Centre
new2serviio79
Post Fri Feb 06, 2015 2:46 am
Xmantium wrote:ARM x31 and x31+ users, ive made a test build, this may not work, let me know how it works.
So I installed your test build on my TS-231 with the latest 4.1.2 012615 build, and it seems to work perfectly. Installation and setup were a snap. I have doubts about the platforms transcoding abilities and haven't tested subtitles yet, but so far so good! Thanks for putting this together!
