MediaBrowser: Song restarts when finish buffering
actionsoft
Post Tue Jan 20, 2015 2:03 am
Hi Zip! In 1.5 this error still is present. The song starts fine but when the greyed bar finish the buffering, the song starts again from the principle.
This not happen with all songs, in the link below you have a problematic .mp3 to add to Serviio and try.
This is a very very annoying bug :(
http://www71.zippyshare.com/v/P7xu6IlW/file.html
Thank You!
Post Tue Jan 20, 2015 10:41 am
Re: MediaBrowser: Song restarts when finish buffering
Thanks, I'll try to reproduce
actionsoft
Post Wed Jan 21, 2015 1:54 am
Thank you! I'll be waiting for your answer :oops:
marko weber
Post Wed Jan 21, 2015 4:38 pm
i also posted this a time ago.....
actionsoft
Post Fri Jan 23, 2015 7:45 pm
Zip, you can tested it?
Post Sun Jan 25, 2015 10:34 pm
tested it locally - can't reproduce it but maybe because the file loads very quickly (the grey bar is full almost immediately).
Are you experiencing on a local netrwork or via internet?
Does it happen if you run mediabrowser on the same PC where Serviio runs (and the file is stored)?
actionsoft
Post Thu Jan 29, 2015 8:02 pm
Hi Zip!
In the same machine (Server + MediaBrowser) the buffering is instantly and works well. In Wifi LAN the buffering takes 4 seconds and restarts. In WAN varies with the internet speed and is the most notorius case because the song restarts in the half.
Thank you!
actionsoft
Post Wed Feb 04, 2015 5:19 pm
Some News? :(
Post Wed Feb 04, 2015 11:48 pm
Thanks - I was able to reproduce and fix it for 1.5.1
actionsoft
Post Wed Mar 04, 2015 5:23 pm
Confirmed! fixed in 1.5.1!! Thank you for your time and work :D
Users browsing this forum: No registered users and 54 guests
