Help, Console or Media Browser for Synology Diskstation
bignose2
Post Wed Jan 21, 2015 3:20 pm
Hate to ask on such a basic question but I have tried a number of times for some hours & had to give up each time.
I can't get the console or media browser to work.
I set up Servioo & Java originally I think for either Madsonic or Logitech Media Server but would like to stream photo's & other stuff.
There is no DS Photo+ for my Roku so can't view pictures direct from the DS.
If I view from my Roku etc. I can select the Serviio server but there is nothing in any folders, video,music or photos so I guess I have to set up folders somewhere
(I can view videos & music from DS apps etc, stream music from LMS & download music for subsonic/madsonic, so generally all works well but nothing from Serviio)
DS213j: DSM 5.1-5022: Java 1.7.0_51
1.4.1.2 - For Nas
1.5 for Windows For Console - Only installed console.
Added to the bins files:
-Dserviio.remoteHost=192.168.2.41 , My local IP.
I run Serviio console, pauses for a second then nothing, no errors but also nothing else.
Couple of things that I perhaps don't understand, I can click http://192.168.2.41:23424/mediabrowser/#/login from the DS package center & it brings up Mediabrowser login.
1) I thought there was no built in browser.?
I don't have a password, i don't think, if you type anything is says only available in the pro version.
2) I thought the pro version was just for computer server & not the NAS so why is there a www page for login?
I would be happy to buy the pro version if I could get it working.
I read somewhere so I added in the DS Firewall settings to allow the port 23424 but was not quite sure if to have a separate source & destination, did both, no help, but as local assumed doubt a problem anyway. I did NOT do anything to the NAS confiuration files as that particular article suggested.
What am I missing?? Everything else has been easy & great on the synology Nas but this is driving me crazy.
THanks I/A.
bignose2
Post Wed Jan 21, 2015 3:52 pm
Re: Help, Console or Media Browser for Synology Diskstation
Continued on from my own question.
Forgot to say Windows 8.1.
Tried running from the start menu & also direct from the folder where it was installed.
There is nothing in the systray & I can't find anything related in the task manager so 99% sure not running in the background anywhere.
Post Wed Jan 21, 2015 4:18 pm
You will need the same version of console as you have the server on the NAS (you have 1.5 console, 1.4 server).
Windows 1.4 installer is here: download.serviio.org/releases/serviio-1.4.1.2-win-setup.exe
MediaBrowser comes with every version, but only is accessible in the Pro version (or during the evaluation period). Once you buy Pro, you will be able to set up a password on the Remote tab in the console.
Users browsing this forum: Google [Bot] and 41 guests
