External HDD no sleep since using Serviio
slipz
Post Wed Jan 21, 2015 12:06 am
Hello
All my media files are on a 4 TB external HDD connected with USB 3. Since I'm using Serviio the HD is never going to sleep. Before, when I was using Plex it always went to sleep after about 10 minutes not using it. What setting should I change in Serviio?
Thank you in advance for your help
Post Wed Jan 21, 2015 1:50 pm
Re: External HDD no sleep since using Serviio
Try to uncheck the automatic updates to library.
slipz
Post Wed Jan 21, 2015 3:58 pm
zip wrote:Try to uncheck the automatic updates to library.
Thank you for your reply. Sadly it's still the same.
Post Wed Jan 21, 2015 4:13 pm
Try to also set plugins.check system variable to false
http://serviio.org/index.php?option=com ... icle&id=43
slipz
Post Wed Jan 21, 2015 4:39 pm
It's getting too complicated for me :? I leave it as it is. Thank you for your help anyway.
Users browsing this forum: No registered users and 64 guests
