Online Streams Not working
zdabbas
Post Sun Jan 18, 2015 5:50 pm
I have purchased a pro license. So far it’s working great, except for one thing that is making my life difficult. The environment is as follows:-
- I have some 2M Satellite Head ends each with about 5 channels
- I’m broadcasting on an IP network using UDP from the Head Ends
- The stream is MPEG2-TS
The problem:-
- I enter the Stream IP in serviio and check the stream all is good I get a green check on it.
- When I try to view on any Smart TV I get file not supported
- I check the stream on the Serviios MediaBrowser and it runs fine.
Can you tell what is going wrong?
PS:- All the VOD media works fine.
Post Mon Jan 19, 2015 9:45 am
Re: Online Streams Not working
maybe the transcoding is not setup right. You will need to give us:
ffmpeg -i "stream url"
detailed log playing the stream
you device and profile you're using
zdabbas
Post Mon Jan 19, 2015 11:04 am
Thank you for the reply, but I'm using Windows version.
But I did find this error in the Serviio Log
2015-01-19 14:06:54,220 INFO [RendererManager] Stored a new renderer: uuid='2fac1234-31f8-11b4-a222-18182184c002', name = 'LG TV', ipAddress='192.168.20.6', profile = '1'
2015-01-19 14:07:13,589 WARN [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Cannot retrieve online media item URL: unknown protocol: udp
Post Mon Jan 19, 2015 2:19 pm
not sure how the fact that you're using Windows is related?
you still need to provide the 3 items I asked for in order to help you
zdabbas
Post Mon Jan 19, 2015 2:33 pm
That's what I'm trying to tell you. when I type ffmpeg -i udp://@225.1.1.13:11111
I get
'ffmpeg' is not recognized as an internal or external command,
operable program or batch file.
Post Mon Jan 19, 2015 4:29 pm
oh, sorry - http://wiki.serviio.org/doku.php?id=howto_win_ffmpeg
also, wrap the URL in quotes, like ffmpeg -i "udp://......"
zdabbas
Post Mon Jan 19, 2015 6:01 pm
Ok Got it.
with regards to the log. is it the serviio log you need after running th ffmpeg command? or is there another log you want?
Post Mon Jan 19, 2015 8:50 pm
run ffmpeg manually first to see the stream details.
then turn on the detailed log, restart the service / PC and try to play the stream via Serviio.
zdabbas
Post Wed Jan 21, 2015 5:50 pm
This is the Output I get from running the command
C:\Program Files\Serviio\lib>ffmpeg -i "udp://@225.1.151.1:11111" >log.log
ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
  built on Nov 19 2014 22:12:09 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enab
le-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype
-lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-
os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
  libavutil      54. 14.100 / 54. 14.100
  libavcodec     56. 12.101 / 56. 12.101
  libavformat    56. 14.100 / 56. 14.100
  libavdevice    56.  3.100 / 56.  3.100
  libavfilter     5.  2.103 /  5.  2.103
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  1.100 /  1.  1.100
  libpostproc    53.  3.100 / 53.  3.100
[mpeg2video @ 03553860] Invalid frame dimensions 0x0.
    Last message repeated 19 times
Input #0, mpegts, from 'udp://@225.1.151.1:11111':
  Duration: N/A, start: 92654.194611, bitrate: 160 kb/s
  Program 706
    Stream #0:0[0xfa]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p
(tv), 720x576 [SAR 64:45 DAR 16:9], max. 15000 kb/s, 25 fps, 25 tbr, 90k tbn, 50
 tbc
    Stream #0:1[0xfb]: Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16
p, 160 kb/s
and this is the error in Serviio log:
2015-01-21 19:55:59,375 DEBUG [VideoDeliveryEngine] Delivering file 'udp://@225.1.151.1:11111' in native format
2015-01-21 19:55:59,376 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Cannot retrieve online media item URL: unknown protocol: udp
Post Thu Jan 22, 2015 10:06 am
Ok.
Try to add this as the first block inside the Generic profile's Online Transcoding block:
  <Matches container="mpegts" vCodec="mpeg2video" aCodec="mp2" />
zdabbas
Post Thu Jan 22, 2015 1:29 pm
Worked Great thanks.
Return to General discussion
