Utorrent Temp Directory - Serviio 1.5
jclay7484
Post Sat Jan 24, 2015 9:12 pm
I currently use Utorrent and have my files sent to a temp directory (sub folder in my main video folder) while they're downloading. Once the file transfer completes u torrent then moves that file from the temp directory to another folder (one level up from the temp folder).
1.5 recognizes the file in the temp directory, but after the file move by utorrent it doesn't change the location. So even though the file was moved, i need to naviagate to the temp folder to play that file.
Any ideas?
Thanks in advance for any help.
James
Post Sun Jan 25, 2015 2:12 pm
Re: Utorrent Temp Directory - Serviio 1.5
1.5 doesn't play well with files being downloaded by torrents.
I'd suggest you move your temp folder outside of the shared folders hierarchy. Alternatively you could try this: viewtopic.php?f=17&t=18183
jclay7484
Post Sun Jan 25, 2015 3:49 pm
zip wrote:I'd suggest you move your temp folder outside of the shared folders hierarchy.
Problem solved, much appreciated!
