missing subtitle sentences
aleflocco
Post Fri Jan 23, 2015 6:04 pm
I just set up Serviio to stream to a Sony BDP-S390.
I choose to always embed subtitles in transcodin, and it almost works, except that some sentences are completely missing...
Did somebody face this issue?
Thanks Ale
aleflocco
Post Fri Jan 23, 2015 6:09 pm
Re: missing subtitle sentences
Extra info...
I just noticed that the missing sentences contain characters with accent (Italian subtitles contain chars like ò à è ì ù and so on).
Thanks again
Ale
Post Sun Jan 25, 2015 2:46 pm
You need to convert the subtitle file to UTF-8 encoding, or set the encoding of the file in the console (on the Subtitles tab)
aleflocco
Post Mon Jan 26, 2015 8:22 am
I changed the charset with Notepad++ and now it works.
Is there a way to check it and convert the file on the fly directly in Serviio?
Thanks a lot
ale
Post Mon Jan 26, 2015 1:54 pm
Not really. There is no 100% correct mechanism to detect file encoding, AFAIK, so it'd only work in certain cases anyway.
aleflocco
Post Mon Jan 26, 2015 1:57 pm
ok, thanks a lot... For Serviio and your excellent support :)
Ale
Users browsing this forum: Baidu [Spider] and 12 guests
