Twitch.tv/Justin.tv
number45_
Post Thu Jan 22, 2015 8:40 pm
Re: Twitch.tv/Justin.tv
I am trying to watch a twitch stream on my TV but there is nothing showing up on the online folder. I have also tried to view the stream on my PS3 and also get the "No Titles" message in the online folder.
I've tried several streams but none of them work. This is the error message I get, every stream seems to be the same error.
2015-01-22 20:27:39,414 WARN [FeedUpdaterWorker] An error occured while parsing the online resource http://www.twitch.tv/faceittv, will try again soon: Unexpected error while invoking plugin (twitch.tv): http://usher.twitch.tv/select/faceittv. ... e99&nauth={"user_id":null,"channel":"faceittv","expires":1421959693,"chansub":{"view_until":1924905600,"restricted_bitrates":[]},"private":{"allowed_to_view":true},"privileged":false,"source_restricted":false}&allow_source=true
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (twitch.tv): http://usher.twitch.tv/select/faceittv. ... e99&nauth={"user_id":null,"channel":"faceittv","expires":1421959693,"chansub":{"view_until":1924905600,"restricted_bitrates":[]},"private":{"allowed_to_view":true},"privileged":false,"source_restricted":false}&allow_source=true
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:78)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:186)
at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:203)
at org.serviio.library.online.metadata.FeedUpdaterWorker.getOnlineItems(FeedUpdaterWorker.java:191)
at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:108)
Caused by: java.io.FileNotFoundException: http://usher.twitch.tv/select/faceittv. ... e99&nauth={"user_id":null,"channel":"faceittv","expires":1421959693,"chansub":{"view_until":1924905600,"restricted_bitrates":[]},"private":{"allowed_to_view":true},"privileged":false,"source_restricted":false}&allow_source=true
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1834)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1439)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.configuredInputStream(DefaultGroovyMethods.java:16692)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.newReader(DefaultGroovyMethods.java:16760)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getText(DefaultGroovyMethods.java:15130)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getText(DefaultGroovyMethods.java:15102)
at org.codehaus.groovy.runtime.dgm$375.doMethodInvoke(Unknown Source)
at org.codehaus.groovy.reflection.GeneratedMetaMethod$Proxy.doMethodInvoke(GeneratedMetaMethod.java:70)
at groovy.lang.MetaClassImpl$GetBeanMethodMetaProperty.getProperty(MetaClassImpl.java:3465)
at org.codehaus.groovy.runtime.callsite.GetEffectivePojoPropertySite.getProperty(GetEffectivePojoPropertySite.java:61)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callGetProperty(AbstractCallSite.java:227)
at Twitch.extractHlsStream(twitch.groovy:136)
at Twitch$extractHlsStream.callCurrent(Unknown Source)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCallCurrent(CallSiteArray.java:46)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:133)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:141)
at Twitch.extractItems(twitch.groovy:80)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
... 1 more
Is this something to do with my setup or has twitch changed something as the stream initially worked when I set it up on Monday.
jules
Post Fri Jan 23, 2015 7:39 pm
andreyv wrote:I investigated the FFMPEG problem a bit more today. The actual error message is
2015-01-19 19:31:02,795 WARN  [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
av_interleaved_write_frame(): Invalid data found when processing input
[mpegts @ 03933740] H.264 bitstream malformed, no startcode found, use the video bitstream filter 'h264_mp4toannexb' to fix it ('-bsf:v h264_mp4toannexb' option with ffmpeg)
frame=    6 fps=0.0 q=-1.0 Lsize=       0kB time=00:00:00.08 bitrate=   0.0kbits/s
video:88kB audio:2kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
Conversion failed!
Notice that it is recommended to add "-bsf:v h264_mp4toannexb" to the FFMPEG command line. Has anyone tested this? Maybe there is no need for custom-built FFMPEG at all.
Can we edit Serviio's FFMPEG options somewhere?
yeah, i added that and it doesn't help.
number45_ wrote:I am trying to watch a twitch stream on my TV but there is nothing showing up on the online folder. I have also tried to view the stream on my PS3 and also get the "No Titles" message in the online folder.
... 1 more
hey, you seem to be using the old version of the plugin. can you please try this one? download/file.php?id=4966
number45_
Post Fri Jan 23, 2015 9:09 pm
jules wrote:hey, you seem to be using the old version of the plugin. can you please try this one? download/file.php?id=4966
Thanks. I updated the plugin with that version but I am still getting the same error.
jules
Post Sat Jan 24, 2015 6:40 pm
yeah, because i linked the wrong file. sorry!
try this one: https://raw.githubusercontent.com/bogen ... tch.groovy
replace the file, do right click -> force refresh on the stream you're trying to watch in serviio console, qualities should show up.
Zapp
Post Sat Jan 24, 2015 8:49 pm
Hey,
tried several plugins and "ffmpeg.exe" files but I didn't get the twitch feed working on my TV (Panasonic Viera TX-42ASW604)
I see the qualitys on the TV with an older tumbnail. It happened also twice that the feed startet in the small preview window, but didn't work after I tried to start the normal view.
My local files work.
Hope I past the right log here:
2015-01-24 21:29:50,267 WARN  [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
[mpegts @ 053ac880] H.264 bitstream malformed, no startcode found, use the video bitstream filter 'h264_mp4toannexb' to fix it ('-bsf:v h264_mp4toannexb' option with ffmpeg)
frame=    1 fps=0.0 q=-1.0 Lsize=       4kB time=00:00:00.06 bitrate= 541.8kbits/s
video:88kB audio:3kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
Conversion failed!
2015-01-24 21:44:48,171 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2015-01-24 21:44:48,172 INFO  [WebServer] WebServer shutting down
2015-01-24 21:44:48,174 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2015-01-24 21:44:48,175 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2015-01-24 21:44:48,176 INFO  [EventDispatcher] Leaving EventDispatcher
2015-01-24 21:44:49,457 INFO  [WebServer] WebServer starting on port 8895
2015-01-24 21:44:49,732 INFO  [Device] Updated bound IP address of Device with UUID: 2efd738a-fb1b-3bf0-8eee-a56b5039448d, bound address: 192.168.1.97
2015-01-24 21:44:49,736 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-01-24 21:44:49,740 INFO  [EventDispatcher] Starting EventDispatcher
2015-01-24 21:44:49,752 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-01-24 21:44:50,233 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface wlan0 (Intel(R) WiFi Link 1000 BGN) and address 192.168.1.97, timeout = 0
2015-01-24 21:44:50,256 INFO  [RendererSearchSender] Searching for Renderer devices
2015-01-24 21:47:25,590 INFO  [WebServer] WebServer shutting down
2015-01-24 21:47:25,592 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2015-01-24 21:47:25,593 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2015-01-24 21:47:25,593 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2015-01-24 21:47:25,594 INFO  [EventDispatcher] Leaving EventDispatcher
2015-01-24 21:47:27,865 INFO  [WebServer] WebServer starting on port 8895
2015-01-24 21:47:28,166 INFO  [Device] Updated bound IP address of Device with UUID: 2efd738a-fb1b-3bf0-8eee-a56b5039448d, bound address: 192.168.1.97
2015-01-24 21:47:28,168 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-01-24 21:47:28,168 INFO  [EventDispatcher] Starting EventDispatcher
2015-01-24 21:47:28,169 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-01-24 21:47:28,613 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface wlan0 (Intel(R) WiFi Link 1000 BGN) and address 192.168.1.97, timeout = 0
2015-01-24 21:47:28,710 INFO  [RendererSearchSender] Searching for Renderer devices
Would be nice, if somebody could help. Thanks!
jules
Post Sun Jan 25, 2015 12:42 am
that log would indicate that you're still using the wrong version of ffmpeg. please get the one from this post:
viewtopic.php?p=94157#p94157
Zapp
Post Sun Jan 25, 2015 11:28 am
Hey, thanks for the reply thought I used it allready. But I downloaded it again and replaced the old one with it. I got still the same issue. Attached the log, cause it was to long to paste (don't know which part ist the important one).
Edit: The error is "unsupportet file"...tested it with my Xbox a while ago and got an disconnection error (but did checked it again after changing things)
(84.78 KiB) Downloaded 2424 times
jules
Post Sun Jan 25, 2015 1:22 pm
judging from the log, on the plugin's end of things, extraction runs just fine. so you should take a look at the profiles you've set in serviio console for the respective clients, and also try out whether it works using VLC (you'll likely need a 64bit build of that if it freezes initially), just to verify that it works at all.
Zapp
Post Sun Jan 25, 2015 2:11 pm
It is working in VLC. So should I try all profiles (not only those for Viera TVs)?
Oh btw: The error is not an unsupportet file, the TV is not able to read the file (still no problem with the local files, no mather which profile)
Edit: Seems to work with the profile "DirectTV HD-DVR". But not very fluently (which might be, because TV and Laptop are connected via WLan)
zamk0we
Post Sun Jan 25, 2015 8:55 pm
Hey
I got latest version of plugin and ffmpeg from your link. It works partially. It shows resource in TV, but only "mobile" quality of stream works, all other give error "video codec not supported". I wonder if it is a problem with TV, but it reads all mp4 files i tried. Do I have to configure transcoding somehow?
jules
Post Mon Jan 26, 2015 8:07 pm
Zapp wrote:It is working in VLC. So should I try all profiles (not only those for Viera TVs)?
i've no idea, my samsung tv plays back every stream i throw at it fine if i use the samsung profile.
zamk0we wrote:Hey
twitch hands out slightly broken h264 video, but my tv and VLC will handle it fine (confirm the latter). transcoding may fix the issues with your tv, but don't ask me how that works.
number45_
Post Tue Jan 27, 2015 6:29 pm
Thanks for the file. Streams seem to be working now :D
zamk0we
Post Tue Jan 27, 2015 8:56 pm
jules wrote:twitch hands out slightly broken h264 video, but my tv and VLC will handle it fine (confirm the latter). transcoding may fix the issues with your tv, but don't ask me how that works.
I used profile "DirectTV HD-DVR" instead of Samsung C/D and it works fine now. Video is smooth, even on source quality. But quailty itself isnt best, i think ill search for way to improve it since right now it consumes only ~10% of cpu
crash965
Post Sat Jan 31, 2015 2:15 pm
Here's the log error I'm getting
2015-01-31 09:11:56,294 WARN [FeedUpdaterThread] An error occured while parsing the online resource http://www.twitch.tv/captainsparklez/v/3733893, will try again soon: Unexpected error while invoking plugin (twitch.tv): http://usher.twitch.tv/api/channel/hls/ ... b55&token={"user_id":null,"channel":"captainsparklez","expires":1422714718,"chansub":{"view_until":1924905600,"restricted_bitrates":[]},"private":{"allowed_to_view":true},"privileged":false,"source_restricted":false}&allow_source=true
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (twitch.tv): http://usher.twitch.tv/api/channel/hls/ ... b55&token={"user_id":null,"channel":"captainsparklez","expires":1422714718,"chansub":{"view_until":1924905600,"restricted_bitrates":[]},"private":{"allowed_to_view":true},"privileged":false,"source_restricted":false}&allow_source=true
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:181)
at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:198)
at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:185)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:108)
Caused by: java.io.FileNotFoundException: http://usher.twitch.tv/api/channel/hls/ ... b55&token={"user_id":null,"channel":"captainsparklez","expires":1422714718,"chansub":{"view_until":1924905600,"restricted_bitrates":[]},"private":{"allowed_to_view":true},"privileged":false,"source_restricted":false}&allow_source=true
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at Twitch.extractHlsStream(twitch.groovy:137)
at Twitch.extractItems(twitch.groovy:81)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Now I'm not sure if this is because it's a VOD or what, but nothing is showing up in the online folder on my Samsun Smart TV. I have the changed ffmpeg.exe and have the newest version of twitch.groovy. Am I doing something wrong?
jules
Post Sun Feb 01, 2015 2:51 pm
yeah, /v/ urls for vods are new and don't work yet. and i don't have time to implement that right now, sorry. maybe in a few days.
note to self on that:
qualities: http://usher.twitch.tv/vod/<v-id>?nauth=<token>&nauthsig=<sig>
thumbnail: http://api.twitch.tv/api/videos/<id with v in front>?on_site=1
crash965
Post Sun Feb 01, 2015 5:40 pm
jules wrote:yeah, /v/ urls for vods are new and don't work yet. and i don't have time to implement that right now, sorry. maybe in a few days.
No problem! Just making sure I wasn't doing something idiotic. I really appreciate you making this plugin. Regular streams work great!
jules
Post Wed Feb 04, 2015 1:28 am
okay, original post is updated with a new version that should work for /v/ vod urls.
crash965
Post Sun Feb 08, 2015 11:55 pm
I keep getting the file type not supported message when trying to watch VODs. I have a newer H series smart tv and I've been using a profile made by someone on the forums. Would using the generic profile or the E/F series profile make the TV able to play the VOD? I'm using the new version of the plugin.
jules
Post Mon Feb 09, 2015 1:30 am
my samsung ES6100 plays back vods just fine with the E/F profile.
crash965
Post Mon Feb 09, 2015 7:10 pm
Tried using the E/F profile. Didn't work. Tried turning on ans off transcoding, trying the newest version and your version of ffmpeg.exe, the new version of the plugin, the generic DLNA profile, and still get the unsupported file error message with VODs. Here's the log: [quote015-02-07 19:31:21,154 WARN [FeedUpdaterThread] An error occured while parsing the online resource http://www.twitch.tv/captainsparklez/v/3742224, waiting for expiry time to try again: Unexpected error while invoking plugin (twitch.tv): http://usher.twitch.tv/api/channel/hls/ ... 706&token={"user_id":null,"channel":"captainsparklez","expires":1423356683,"chansub":{"view_until":1924905600,"restricted_bitrates":[]},"private":{"allowed_to_view":true},"privileged":false,"source_restricted":false}&allow_source=true
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (twitch.tv): http://usher.twitch.tv/api/channel/hls/ ... 706&token={"user_id":null,"channel":"captainsparklez","expires":1423356683,"chansub":{"view_until":1924905600,"restricted_bitrates":[]},"private":{"allowed_to_view":true},"privileged":false,"source_restricted":false}&allow_source=true
Caused by: java.io.FileNotFoundException: http://usher.twitch.tv/api/channel/hls/ ... 706&token={"user_id":null,"channel":"captainsparklez","expires":1423356683,"chansub":{"view_until":1924905600,"restricted_bitrates":[]},"private":{"allowed_to_view":true},"privileged":false,"source_restricted":false}&allow_source=true
at java.lang.Thread.run(Unknown Source)[/quote]
I just don't get what I'm doing wrong.
EDIT: I had the wrong log in the quote. That was the main channel which was offline
Return to Available plugins
Users browsing this forum: Bing [Bot] and 32 guests
