live stream to bdp-s5100
tange1
Post Sat Jan 31, 2015 4:58 pm
Hello -
I am trying to use serviio to open a live stream and play it back on a sony BDP-s5100. I realize you may need logs from me to help but i am unsure which to attach to the post.
Here are the details:
Using serviio 1.5 on Windows server 2012
I defined a live stream to this URL:
http://ironpigslive.sectv.com//ironpigslive.m3u8
Using check URL, i get a green check mark.
My player is a BDP-s5100 and I have defined the BDP-Sx100 (2013) profile and stopped/started the server.
Transcoding is turned on.
When I try to play back the stream I get:
Unsupported or corrupt file type.
Any tips?
tange1
Post Sat Jan 31, 2015 5:03 pm
Re: live stream to bdp-s5100
ffmepg info:
gslive.m3u8
ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
built on Nov 19 2014 22:12:09 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enab
le-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype
-lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-
os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
libavutil 54. 14.100 / 54. 14.100
libavcodec 56. 12.101 / 56. 12.101
libavformat 56. 14.100 / 56. 14.100
libavdevice 56. 3.100 / 56. 3.100
libavfilter 5. 2.103 / 5. 2.103
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 1.100 / 1. 1.100
libpostproc 53. 3.100 / 53. 3.100
[aac @ 01BDB420] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 043A9D40] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 01C62B40] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 01C03A60] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 0450B540] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 045084E0] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 0450A120] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 0656C1A0] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 0656AD60] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 0656DDC0] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 01CAEA80] ChannelElement 1.0 missing
[aac @ 01CAEA80] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 04AF0A80] ChannelElement 1.0 missing
[aac @ 04AF0A80] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 0447F6E0] ChannelElement 1.0 missing
[aac @ 0447F6E0] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 04508CE0] ChannelElement 1.0 missing
[aac @ 04508CE0] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 04507CC0] ChannelElement 1.0 missing
[aac @ 04507CC0] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 04509D00] ChannelElement 1.0 missing
[aac @ 04509D00] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 0450AD20] ChannelElement 1.0 missing
[aac @ 0450AD20] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 0656BD80] ChannelElement 1.0 missing
[aac @ 0656BD80] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 0656E9E0] ChannelElement 1.0 missing
[aac @ 0656E9E0] skip_data_stream_element: Input buffer exhausted before END ele
ment found
[aac @ 0656D9C0] ChannelElement 1.0 missing
[aac @ 0656D9C0] skip_data_stream_element: Input buffer exhausted before END ele
ment found
Input #0, hls,applehttp, from 'http://ironpigslive.sectv.com//ironpigslive.m3u8'
Duration: N/A, start: 23028.420178, bitrate: 1038 kb/s
Program 0
variant_bitrate : 771658
Stream #0:0: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 480x270 [
SAR 1:1 DAR 16:9], 59.94 fps, 59.94 tbr, 90k tbn, 119.88 tbc
Stream #0:1: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 10
3 kb/s
Program 1
variant_bitrate : 978234
Stream #0:2: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 480x270 [
Stream #0:3: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 10
3 kb/s
Program 2
variant_bitrate : 1184810
Stream #0:4: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [
Stream #0:5: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 10
3 kb/s
Program 3
variant_bitrate : 1391434
Stream #0:6: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [
Stream #0:7: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 10
3 kb/s
Program 4
variant_bitrate : 1598010
Stream #0:8: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 960x540 [
Stream #0:9: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 10
3 kb/s
Program 5
variant_bitrate : 1804586
Stream #0:10: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 960x540
[SAR 1:1 DAR 16:9], 59.94 fps, 59.94 tbr, 90k tbn, 119.88 tbc
Stream #0:11: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 1
03 kb/s
Program 6
variant_bitrate : 2011210
Stream #0:12: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 960x540
Stream #0:13: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 1
03 kb/s
Program 7
variant_bitrate : 2217786
Stream #0:14: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 1024x576
Stream #0:15: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 1
03 kb/s
Program 8
variant_bitrate : 3250762
Stream #0:16: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 1280x720
Stream #0:17: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 1
03 kb/s
Program 9
variant_bitrate : 3767226
Stream #0:18: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 1280x720
Stream #0:19: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 1
03 kb/s
