Not Transcoding
EDIT: I've tried setting the profile of my TV to both LG TV/Player and Generic DLNA device, but neither works.
ffmpeg.exe -threads 2 -i C:\Users\Zaharaddeen\Downloads\Music\(Hi10)_Genshiken_Nidaime_-_01_(720p)_(HorribleSubs).mkv -y -threads 2 -c:v mpeg2video -pix_fmt yuv420p -qscale:v 1 -r 24000/1001 -g 15 -c:a ac3 -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-2391-8-ORIGINAL.stfGeneral
Unique ID : 196480618675424187722852705211592607018 (0x93D0CA6B4E8F3A89B1E6FDBFDA02052A)
Complete name : C:\Users\Zaharaddeen\Downloads\Music\(Hi10)_Genshiken_Nidaime_-_01_(720p)_(HorribleSubs).mkv
Format : Matroska
Format version : Version 2
File size : 73.8 MiB
Duration : 23mn 40s
Overall bit rate : 436 Kbps
Encoded date : UTC 2013-07-07 11:01:49
Writing application : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library : libebml v1.2.1 + libmatroska v1.1.1
Attachment : Yes
Format : AVC
Format profile : High 10@L5.0
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 23mn 40s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Writing library : x264 core 120 r2120 0c7dab9
Encoding settings : cabac=1 / ref=16 / deblock=1:1:2 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=24.0 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=1:0.60
Language : English
Default : Yes
Forced : No
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 23mn 40s
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Default : Yes
Forced : No
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Default : Yes
Forced : Yes
Zee530 wrote:Thanks a lot, that got it working, i was sure i read all the support files on the web but it seemed i missed that one, thanks for all the support.
One last tiny miniscule issue, is there a way to get seeking capabilities on my TV, at this time any video format i play doesn't allow me to rewind or forward, all i can do is pause.
Zee530 wrote:Yeah, hardware isn't great, i'm using a T2400 Duo core @1.83GHz with a GMA 950. Be that as it may, when i had a ps3, i was able to use ps3 media server to transcode both 720 and 1080p vids without issues, 720p played seamlessly, 1080p i had to allow it to buffer itself a bit, but once it did it also played perfectly. I noticed in the code for transoding that i was using 384-bps, will lowering it help a bit. I am using a wired connection.
Users browsing this forum: Baidu [Spider] and 13 guests
