Serviio doesn't startup on Mac
Scroller
Post Sun Feb 01, 2015 9:32 pm
Hi Guys
I tried to look in a lot of topics but couldn't find my problem.
I downloaded the file from the homepage and installed it.
I go to applications and start the program Serviio-console, the program jumps for about 20sec and nothing happens. I can in the left top corner the application is running but no window is opening.
I've checked in activation-monitor that Serviio is running and the TV can find it, but noting is shared.
Can someone please help?
Info: I went to see in Library/application support/ but no Serviio folder to see?
Best Regards
Scroller
Post Mon Feb 02, 2015 1:04 pm
Re: Serviio doesn't startup on Mac
I assume you're running 1.5?
The installer should create /Library/Application Support/Serviio folder, definitely.
Scroller
Post Mon Feb 02, 2015 8:27 pm
Correct, the one from http://serviio.org/download
It runs the installer with no fault.
Settings:
MAC Book pro early 2011
Yosemite 10.10.1
Do you have any idea?
Br
Scroller
Post Mon Feb 02, 2015 9:58 pm
Does it ask you for your admin password when running the installer?
Scroller
Post Tue Feb 03, 2015 7:49 pm
Yes its ask about that.
I actually tried it once again and now i have a folder in Library.
But i have a Console icon in the applications folder.
It just jumps a lot of times and nothing happens.
Scroller
Post Wed Feb 04, 2015 5:26 pm
is there something in your serviio.log ?
Also, try this: viewtopic.php?f=5&t=18188
Scroller
Post Wed Feb 04, 2015 9:05 pm
Yes i have this:
Mon Feb 02 21:46:52 CET 2015:
Booting Derby version The Apache Software Foundation - Apache Derby - 10.11.1.1 - (1616546): instance a816c00e-014b-4c0b-b9ea-fffff4a463b2
on database directory /Library/Application Support/Serviio/library/db with class loader sun.misc.Launcher$AppClassLoader@2f92e0f4
Loaded from file:/Library/Application%20Support/Serviio/lib/derby.jar
java.vendor=Oracle Corporation
java.runtime.version=1.8.0_20-b26
user.dir=/
os.name=Mac OS X
os.arch=x86_64
os.version=10.10.1
derby.system.home=/Library/Application Support/Serviio/library
derby.stream.error.file=../log/derby.log
Database Class Loader started - derby.database.classpath=''
And this:
2015-02-02 21:46:51,306 INFO [MediaServer] ------------------------------------------------------------------------
2015-02-02 21:46:51,306 INFO [MediaServer] Serviio DLNA media streaming server v 1.5 (rev. 19ceb8acec8c)
2015-02-02 21:46:51,306 INFO [MediaServer] Petr Nejedly 2009-2015
2015-02-02 21:46:51,306 INFO [MediaServer] http://www.serviio.org
2015-02-02 21:46:51,306 INFO [MediaServer] Java 1.8.0_20-Oracle Corporation x86_64
2015-02-02 21:46:51,307 INFO [MediaServer] OS Mac OS X 10.10.1
2015-02-02 21:46:51,307 INFO [MediaServer] File encoding: UTF-8
2015-02-02 21:46:51,307 INFO [MediaServer] Headless mode enabled: true
2015-02-02 21:46:51,307 INFO [MediaServer] User: root
2015-02-02 21:46:51,307 INFO [MediaServer] User home dir: /var/root
2015-02-02 21:46:51,307 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2015-02-02 21:46:51,307 INFO [MediaServer] ------------------------------------------------------------------------
2015-02-02 21:46:51,488 INFO [WebServer] Socket buffer set to 65535 bytes
2015-02-02 21:46:51,489 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-02-02 21:46:51,577 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-02-02 21:46:51,577 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-02-02 21:46:51,594 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-02-02 21:46:51,607 INFO [DatabaseManager] Using DERBY database language
2015-02-02 21:46:53,094 INFO [DBSchemaUpdateExecutor] Updating DB schema
2015-02-02 21:46:56,254 INFO [DBSchemaUpdateExecutor] Dropping search index
2015-02-02 21:46:56,256 INFO [SearchManager] Starting up search engine
2015-02-02 21:46:56,510 INFO [DBSchemaUpdateExecutor] Cleaning temporary cache
2015-02-02 21:46:56,532 INFO [Device] Created UPnP Device with UUID: ffaf0b4b-a3be-3ed8-a235-a6ac83a874b6, bound address: 192.168.0.195
2015-02-02 21:46:56,642 INFO [DBSchemaUpdateExecutor] Cleaning persistent cache
2015-02-02 21:46:56,674 WARN [IndexedDiskCache] Region [online_technical_metadata] Reseting cache
2015-02-02 21:46:56,764 INFO [MediaServer] ------------------------------------------------------------------------
2015-02-02 21:46:56,764 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2015-02-02 21:47:27,239 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-02-02 21:47:27,354 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2015-02-02 21:47:27,380 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2015-02-02 21:47:27,384 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2015-02-02 21:47:27,385 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2015-02-02 21:47:27,386 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2015-02-02 21:47:27,397 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2015-02-02 21:47:27,400 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2015-02-02 21:47:27,400 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2015-02-02 21:47:27,401 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2015-02-02 21:47:27,402 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2015-02-02 21:47:27,405 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2015-02-02 21:47:27,407 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2015-02-02 21:47:27,408 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2015-02-02 21:47:27,408 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2015-02-02 21:47:27,410 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2015-02-02 21:47:27,411 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2015-02-02 21:47:27,411 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2015-02-02 21:47:27,412 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2015-02-02 21:47:27,413 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2015-02-02 21:47:27,415 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2015-02-02 21:47:27,416 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2015-02-02 21:47:27,416 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2015-02-02 21:47:27,416 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2015-02-02 21:47:27,417 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2015-02-02 21:47:27,417 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2015-02-02 21:47:27,418 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2015-02-02 21:47:27,418 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2015-02-02 21:47:27,419 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2015-02-02 21:47:27,419 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2015-02-02 21:47:27,421 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2015-02-02 21:47:27,422 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2015-02-02 21:47:27,422 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2015-02-02 21:47:27,423 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2015-02-02 21:47:27,423 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2015-02-02 21:47:27,424 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2015-02-02 21:47:27,424 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2015-02-02 21:47:27,425 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2015-02-02 21:47:27,426 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2015-02-02 21:47:27,426 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2015-02-02 21:47:27,427 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2015-02-02 21:47:27,428 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2015-02-02 21:47:27,428 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2015-02-02 21:47:27,429 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2015-02-02 21:47:27,436 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2015-02-02 21:47:27,436 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2015-02-02 21:47:27,437 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2015-02-02 21:47:27,438 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2015-02-02 21:47:27,439 INFO [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2015-02-02 21:47:27,503 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-02-02 21:47:27,504 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2015-02-02 21:47:27,507 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2015-02-02 21:47:27,507 INFO [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2015-02-02 21:47:27,509 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2015-02-02 21:47:27,509 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2015-02-02 21:47:27,510 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2015-02-02 21:47:27,511 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2015-02-02 21:47:27,512 INFO [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2015-02-02 21:47:27,512 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2015-02-02 21:47:27,513 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2015-02-02 21:47:27,544 INFO [PluginCompilerThread] Looking for plugins at /Library/Application Support/Serviio/plugins
2015-02-02 21:47:27,545 INFO [PluginCompilerThread] Started looking for plugins
2015-02-02 21:47:27,547 INFO [UpdateChecker] Checking if a new version is available
2015-02-02 21:47:27,616 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
2015-02-02 21:47:27,646 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-02-02 21:47:27,682 INFO [WebServer] WebServer starting on port 8895
2015-02-02 21:47:27,683 INFO [Device] Updated bound IP address of Device with UUID: ffaf0b4b-a3be-3ed8-a235-a6ac83a874b6, bound address: 192.168.0.195
2015-02-02 21:47:27,691 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-02-02 21:47:27,691 INFO [EventDispatcher] Starting EventDispatcher
2015-02-02 21:47:27,693 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-02-02 21:47:27,697 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2015-02-02 21:47:27,697 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en1 (en1) and address 192.168.0.195, timeout = 0
2015-02-02 21:47:27,697 INFO [RendererSearchSender] Searching for Renderer devices
2015-02-02 21:47:28,545 INFO [RendererManager] Stored a new renderer: uuid='4b8b2214-9c37-415b-9702-d89b74494a23', name = 'Unrecognized device', ipAddress='192.168.0.190', profile = '1'
2015-02-02 21:47:28,554 INFO [RendererManager] Stored a new renderer: uuid='5f9ec1b3-ed59-79bf-4530-0007f5ffffff', name = 'VSX-528/SYXE8 ', ipAddress='192.168.0.196', profile = '1'
2015-02-02 21:47:28,953 INFO [RendererManager] Stored a new renderer: uuid='00000000-0000-1010-8000-fcf152e52df4', name = 'KD-55X8505B', ipAddress='192.168.0.190', profile = '1'
2015-02-02 21:47:53,736 INFO [FeedUpdaterWorker] Started looking for information about online resources
2015-02-02 21:47:53,775 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2015-02-02 21:47:53,785 INFO [LocalLibraryManager] Starting automatic library scan
2015-02-02 21:47:53,786 INFO [LibraryDeltaScanner] Starting the library delta scan
2015-02-02 21:47:53,789 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2015-02-02 21:58:13,850 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2015-02-02 21:58:14,512 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2015-02-03 20:45:06,587 INFO [DiscoveryManager] System wake up detected, restarting UPnP services for network re-discovery
2015-02-03 20:45:06,588 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2015-02-03 20:45:06,589 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2015-02-03 20:45:06,589 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2015-02-03 20:45:06,589 INFO [EventDispatcher] Leaving EventDispatcher
2015-02-03 20:45:06,589 INFO [Device] Updated bound IP address of Device with UUID: ffaf0b4b-a3be-3ed8-a235-a6ac83a874b6, bound address: 192.168.0.195
2015-02-03 20:45:06,590 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-02-03 20:45:06,590 INFO [EventDispatcher] Starting EventDispatcher
2015-02-03 20:45:06,591 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-02-03 20:45:06,591 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en1 (en1) and address 192.168.0.195, timeout = 0
2015-02-03 20:45:11,592 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2015-02-03 21:09:47,817 INFO [DiscoveryManager] System wake up detected, restarting UPnP services for network re-discovery
2015-02-03 21:09:47,817 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2015-02-03 21:09:47,817 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2015-02-03 21:09:47,818 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2015-02-03 21:09:47,818 INFO [EventDispatcher] Leaving EventDispatcher
2015-02-03 21:09:47,819 INFO [Device] Updated bound IP address of Device with UUID: ffaf0b4b-a3be-3ed8-a235-a6ac83a874b6, bound address: 192.168.0.195
2015-02-03 21:09:47,820 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-02-03 21:09:47,820 INFO [EventDispatcher] Starting EventDispatcher
2015-02-03 21:09:47,822 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-02-03 21:09:47,822 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en1 (en1) and address 192.168.0.195, timeout = 0
2015-02-04 22:03:31,738 INFO [DiscoveryManager] System wake up detected, restarting UPnP services for network re-discovery
2015-02-04 22:03:31,739 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2015-02-04 22:03:31,739 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2015-02-04 22:03:31,739 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2015-02-04 22:03:31,739 INFO [EventDispatcher] Leaving EventDispatcher
2015-02-04 22:03:31,740 INFO [Device] Updated bound IP address of Device with UUID: ffaf0b4b-a3be-3ed8-a235-a6ac83a874b6, bound address: 192.168.0.194
2015-02-04 22:03:31,741 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-02-04 22:03:31,741 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en1 (en1) and address 192.168.0.194, timeout = 0
2015-02-04 22:03:31,741 INFO [EventDispatcher] Starting EventDispatcher
2015-02-04 22:03:31,741 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
Post Thu Feb 05, 2015 1:16 am
Log is fine, server is running. Try the tip of moving the Console app out of Applications and back
