Cannot detect TV
DunxUK
Post Sun Jan 04, 2015 12:06 pm
Cannot detect TV
I've searched the forum but couldn't find anything that seemed to help! Serviio seems to be detecting two computers on the local network but not the television. The log is as follows:
2015-01-04 11:57:02,578 INFO [MediaServer] ------------------------------------------------------------------------
2015-01-04 11:57:02,578 INFO [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f)
2015-01-04 11:57:02,578 INFO [MediaServer] Petr Nejedly 2009-2014
2015-01-04 11:57:02,578 INFO [MediaServer] http://www.serviio.org
2015-01-04 11:57:02,578 INFO [MediaServer] Java 1.7.0_05-Oracle Corporation
2015-01-04 11:57:02,578 INFO [MediaServer] OS Windows XP amd64 5.2
2015-01-04 11:57:02,578 INFO [MediaServer] File encoding: windows-1252
2015-01-04 11:57:02,578 INFO [MediaServer] Headless mode enabled: true
2015-01-04 11:57:02,578 INFO [MediaServer] User: SYSTEM
2015-01-04 11:57:02,578 INFO [MediaServer] User home dir: C:\Documents and Settings\Default User
2015-01-04 11:57:02,578 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2015-01-04 11:57:02,687 INFO [WebServer] Socket buffer set to 65535 bytes
2015-01-04 11:57:02,687 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-01-04 11:57:02,718 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-01-04 11:57:02,718 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-01-04 11:57:02,734 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-01-04 11:57:02,734 INFO [DatabaseManager] Using DERBY database language
2015-01-04 11:57:09,890 INFO [DBSchemaUpdateExecutor] Updating DB schema
2015-01-04 11:57:20,390 INFO [DBSchemaUpdateExecutor] Cleaning temporary cache
2015-01-04 11:57:20,421 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 9 times
2015-01-04 11:57:25,421 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 8 times
2015-01-04 11:57:30,421 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 7 times
2015-01-04 11:57:32,406 INFO [ServiioConsole] Initializing Serviio Console
2015-01-04 11:57:32,421 INFO [ServiioConsole] Starting Serviio Console
2015-01-04 11:57:32,531 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2015-01-04 11:57:35,437 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 6 times
2015-01-04 11:57:40,437 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 5 times
2015-01-04 11:57:45,437 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 4 times
2015-01-04 11:57:50,453 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 3 times
2015-01-04 11:57:55,453 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 2 times
2015-01-04 11:58:00,453 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 1 times
2015-01-04 11:58:05,468 INFO [Device] Created UPnP Device with UUID: 204683ed-9f48-3c47-b70d-0da4ab7276fa, bound address: 192.168.1.4
2015-01-04 11:58:05,546 INFO [DBSchemaUpdateExecutor] Cleaning persistent cache
2015-01-04 11:58:05,562 WARN [IndexedDiskCache] Region [online_technical_metadata] Reseting cache
2015-01-04 11:58:05,843 INFO [MediaServer] ------------------------------------------------------------------------
2015-01-04 11:58:05,843 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2015-01-04 11:58:06,046 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-01-04 11:58:06,125 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2015-01-04 11:58:06,125 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2015-01-04 11:58:06,125 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2015-01-04 11:58:06,125 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2015-01-04 11:58:06,125 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2015-01-04 11:58:06,125 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013)' (id=sony2013)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2015-01-04 11:58:06,140 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2015-01-04 11:58:06,156 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2015-01-04 11:58:06,187 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-01-04 11:58:06,203 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2015-01-04 11:58:06,203 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2015-01-04 11:58:06,203 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2015-01-04 11:58:06,203 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2015-01-04 11:58:06,203 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2015-01-04 11:58:06,203 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2015-01-04 11:58:06,203 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2015-01-04 11:58:06,203 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2015-01-04 11:58:06,203 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2015-01-04 11:58:06,203 INFO [PluginCompilerThread] Started looking for plugins
2015-01-04 11:58:06,203 INFO [UpdateChecker] Checking if a new version is available
2015-01-04 11:58:07,000 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version N-54096-ge41bf19 Copyright (c) 2000-2013 the FFmpeg developers
2015-01-04 11:58:07,062 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-01-04 11:58:07,078 INFO [WebServer] WebServer starting on port 8895
2015-01-04 11:58:07,093 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 9 times
2015-01-04 11:58:12,093 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 8 times
2015-01-04 11:58:17,093 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 7 times
2015-01-04 11:58:22,093 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 6 times
2015-01-04 11:58:27,109 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 5 times
2015-01-04 11:58:32,109 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 4 times
2015-01-04 11:58:37,109 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 3 times
2015-01-04 11:58:42,125 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 2 times
2015-01-04 11:58:47,125 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 1 times
2015-01-04 11:58:52,125 INFO [Device] Updated bound IP address of Device with UUID: 204683ed-9f48-3c47-b70d-0da4ab7276fa, bound address: 192.168.1.4
2015-01-04 11:58:52,125 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-01-04 11:58:52,125 INFO [EventDispatcher] Starting EventDispatcher
2015-01-04 11:58:52,125 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-01-04 11:58:52,140 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2015-01-04 11:58:52,140 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek PCIe GBE Family Controller - Packet Scheduler Miniport) and address 192.168.1.4, timeout = 0
2015-01-04 11:58:52,140 INFO [RendererSearchSender] Searching for Renderer devices
2015-01-04 11:58:54,203 INFO [RendererManager] Stored a new renderer: uuid='d21cc037-09eb-4b39-a86f-28d5fae043eb', name = 'Unrecognized device', ipAddress='192.168.1.4', profile = '1'
2015-01-04 11:58:54,796 INFO [RendererManager] Stored a new renderer: uuid='7139b9b5-0ba5-4885-bbba-b7d5c42a4442', name = 'Unrecognized device', ipAddress='192.168.1.6', profile = '1'
2015-01-04 11:58:58,703 INFO [Messages] Loaded console message bundle for locale: en
2015-01-04 11:59:00,812 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2015-01-04 11:59:01,515 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2015-01-04 11:59:18,140 INFO [FeedUpdaterThread] Started looking for information about online resources
2015-01-04 11:59:18,156 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2015-01-04 11:59:18,156 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2015-01-04 11:59:18,156 INFO [PlaylistMaintainerThread] Started looking playlist changes
The address for the tv is 192.168.1.5 if that helps
Many thanks team!
DunxUK
Post Thu Jan 08, 2015 8:21 pm
Re: Cannot detect TV
Ok I opened a bunch of ports through the firewall that it was moaning about and got this far but it still can't recognise its own port (192.168.1.4) nor the tv (192.168.1.5). Any ideas anyone?
2015-01-04 12:17:46,046 INFO [MediaServer] ------------------------------------------------------------------------
2015-01-04 12:17:46,046 INFO [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f)
2015-01-04 12:17:46,046 INFO [MediaServer] Petr Nejedly 2009-2014
2015-01-04 12:17:46,046 INFO [MediaServer] http://www.serviio.org
2015-01-04 12:17:46,046 INFO [MediaServer] Java 1.7.0_05-Oracle Corporation
2015-01-04 12:17:46,046 INFO [MediaServer] OS Windows XP amd64 5.2
2015-01-04 12:17:46,046 INFO [MediaServer] File encoding: windows-1252
2015-01-04 12:17:46,046 INFO [MediaServer] Headless mode enabled: true
2015-01-04 12:17:46,046 INFO [MediaServer] User: SYSTEM
2015-01-04 12:17:46,046 INFO [MediaServer] User home dir: C:\Documents and Settings\Default User
2015-01-04 12:17:46,046 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2015-01-04 12:17:46,125 INFO [WebServer] Socket buffer set to 65535 bytes
2015-01-04 12:17:46,140 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-01-04 12:17:46,171 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-01-04 12:17:46,171 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-01-04 12:17:46,171 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-01-04 12:17:46,187 INFO [DatabaseManager] Using DERBY database language
2015-01-04 12:17:46,843 INFO [MediaServer] ------------------------------------------------------------------------
2015-01-04 12:17:46,843 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2015-01-04 12:17:46,859 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 9 times
2015-01-04 12:17:51,859 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 8 times
2015-01-04 12:17:56,859 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 7 times
2015-01-04 12:18:01,875 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 6 times
2015-01-04 12:18:06,875 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 5 times
2015-01-04 12:18:11,875 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 4 times
2015-01-04 12:18:16,890 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 3 times
2015-01-04 12:18:21,890 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 2 times
2015-01-04 12:18:26,890 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 1 times
2015-01-04 12:18:31,890 INFO [Device] Created UPnP Device with UUID: 204683ed-9f48-3c47-b70d-0da4ab7276fa, bound address: 192.168.1.4
2015-01-04 12:18:32,218 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-01-04 12:18:32,281 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2015-01-04 12:18:32,296 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2015-01-04 12:18:32,296 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2015-01-04 12:18:32,296 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2015-01-04 12:18:32,296 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2015-01-04 12:18:32,296 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2015-01-04 12:18:32,296 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2015-01-04 12:18:32,296 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2015-01-04 12:18:32,296 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2015-01-04 12:18:32,296 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2015-01-04 12:18:32,296 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013)' (id=sony2013)
2015-01-04 12:18:32,296 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2015-01-04 12:18:32,296 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2015-01-04 12:18:32,312 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2015-01-04 12:18:32,328 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2015-01-04 12:18:32,328 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2015-01-04 12:18:32,328 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2015-01-04 12:18:32,328 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2015-01-04 12:18:32,328 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2015-01-04 12:18:32,328 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2015-01-04 12:18:32,359 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-01-04 12:18:32,359 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2015-01-04 12:18:32,359 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2015-01-04 12:18:32,359 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2015-01-04 12:18:32,359 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2015-01-04 12:18:32,359 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2015-01-04 12:18:32,359 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2015-01-04 12:18:32,359 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2015-01-04 12:18:32,359 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2015-01-04 12:18:32,390 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2015-01-04 12:18:32,390 INFO [PluginCompilerThread] Started looking for plugins
2015-01-04 12:18:32,390 INFO [UpdateChecker] Checking if a new version is available
2015-01-04 12:18:32,437 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version N-54096-ge41bf19 Copyright (c) 2000-2013 the FFmpeg developers
2015-01-04 12:18:32,453 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-01-04 12:18:32,484 INFO [WebServer] WebServer starting on port 8895
2015-01-04 12:18:32,484 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 9 times
2015-01-04 12:18:37,484 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 8 times
2015-01-04 12:18:42,500 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 7 times
2015-01-04 12:18:47,500 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 6 times
2015-01-04 12:18:52,500 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 5 times
2015-01-04 12:18:57,500 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 4 times
2015-01-04 12:19:02,515 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 3 times
2015-01-04 12:19:07,515 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 2 times
2015-01-04 12:19:12,515 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 1 times
2015-01-04 12:19:17,515 INFO [Device] Updated bound IP address of Device with UUID: 204683ed-9f48-3c47-b70d-0da4ab7276fa, bound address: 192.168.1.4
2015-01-04 12:19:17,531 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-01-04 12:19:17,531 INFO [EventDispatcher] Starting EventDispatcher
2015-01-04 12:19:17,531 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-01-04 12:19:17,531 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2015-01-04 12:19:17,531 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek PCIe GBE Family Controller - Packet Scheduler Miniport) and address 192.168.1.4, timeout = 0
2015-01-04 12:19:17,531 INFO [RendererSearchSender] Searching for Renderer devices
2015-01-04 12:19:43,546 INFO [FeedUpdaterThread] Started looking for information about online resources
2015-01-04 12:19:43,546 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2015-01-04 12:19:43,546 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2015-01-04 12:19:43,546 INFO [PlaylistMaintainerThread] Started looking playlist changes
2015-01-04 12:21:12,656 INFO [ServiioConsole] Initializing Serviio Console
2015-01-04 12:21:12,656 INFO [ServiioConsole] Starting Serviio Console
2015-01-04 12:21:12,718 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2015-01-04 12:21:13,265 INFO [Messages] Loaded console message bundle for locale: en
2015-01-04 12:21:15,281 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2015-01-04 12:21:15,875 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2015-01-04 12:23:40,296 INFO [ServiioConsole] Serviio Console completely closed
2015-01-04 12:23:46,906 WARN [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2015-01-04 12:23:46,906 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2015-01-04 12:23:46,906 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2015-01-04 12:23:46,906 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2015-01-04 12:23:46,953 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2015-01-04 12:23:47,062 INFO [FeedUpdaterThread] Finished looking for online resources information
2015-01-04 12:23:47,156 INFO [PluginCompilerThread] Finished looking for plugins
2015-01-04 12:23:47,265 INFO [SearchManager] Starting up search engine
2015-01-04 12:23:47,703 INFO [SearchIndexer] Closing search index writer
2015-01-04 12:23:47,703 INFO [WebServer] WebServer shutting down
2015-01-04 12:23:47,703 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2015-01-04 12:23:47,703 INFO [EventDispatcher] Leaving EventDispatcher
2015-01-04 12:23:47,703 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2015-01-04 12:23:47,703 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2015-01-04 12:23:47,703 INFO [DatabaseManager] Shutting down database
2015-01-04 12:23:48,328 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-01-08 20:13:09,812 INFO [MediaServer] ------------------------------------------------------------------------
2015-01-08 20:13:09,890 INFO [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f)
2015-01-08 20:13:09,890 INFO [MediaServer] Petr Nejedly 2009-2014
2015-01-08 20:13:09,890 INFO [MediaServer] http://www.serviio.org
2015-01-08 20:13:09,890 INFO [MediaServer] Java 1.7.0_05-Oracle Corporation
2015-01-08 20:13:09,890 INFO [MediaServer] OS Windows XP amd64 5.2
2015-01-08 20:13:09,890 INFO [MediaServer] File encoding: windows-1252
2015-01-08 20:13:09,906 INFO [MediaServer] Headless mode enabled: true
2015-01-08 20:13:09,906 INFO [MediaServer] User: SYSTEM
2015-01-08 20:13:09,906 INFO [MediaServer] User home dir: C:\Documents and Settings\Default User
2015-01-08 20:13:09,906 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2015-01-08 20:13:09,906 INFO [MediaServer] ------------------------------------------------------------------------
2015-01-08 20:13:11,531 INFO [WebServer] Socket buffer set to 65535 bytes
2015-01-08 20:13:11,578 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-01-08 20:13:11,953 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-01-08 20:13:11,953 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-01-08 20:13:12,031 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-01-08 20:13:12,156 INFO [DatabaseManager] Using DERBY database language
2015-01-08 20:13:20,250 INFO [MediaServer] ------------------------------------------------------------------------
2015-01-08 20:13:20,250 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2015-01-08 20:13:20,390 INFO [Device] Created UPnP Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2015-01-08 20:13:22,187 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-01-08 20:13:22,359 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2015-01-08 20:13:22,406 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2015-01-08 20:13:22,421 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2015-01-08 20:13:22,421 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2015-01-08 20:13:22,421 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2015-01-08 20:13:22,437 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2015-01-08 20:13:22,437 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2015-01-08 20:13:22,437 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2015-01-08 20:13:22,437 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2015-01-08 20:13:22,453 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2015-01-08 20:13:22,453 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013)' (id=sony2013)
2015-01-08 20:13:22,453 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2015-01-08 20:13:22,453 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2015-01-08 20:13:22,453 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2015-01-08 20:13:22,453 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2015-01-08 20:13:22,453 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2015-01-08 20:13:22,453 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2015-01-08 20:13:22,453 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2015-01-08 20:13:22,468 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2015-01-08 20:13:22,468 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2015-01-08 20:13:22,484 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2015-01-08 20:13:22,562 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-01-08 20:13:22,562 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2015-01-08 20:13:22,562 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2015-01-08 20:13:22,562 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2015-01-08 20:13:22,562 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2015-01-08 20:13:22,562 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2015-01-08 20:13:22,562 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2015-01-08 20:13:22,562 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2015-01-08 20:13:22,562 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2015-01-08 20:13:22,828 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2015-01-08 20:13:22,828 INFO [UpdateChecker] Checking if a new version is available
2015-01-08 20:13:22,843 INFO [PluginCompilerThread] Started looking for plugins
2015-01-08 20:13:24,468 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version N-54096-ge41bf19 Copyright (c) 2000-2013 the FFmpeg developers
2015-01-08 20:13:25,296 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-01-08 20:13:25,703 INFO [WebServer] WebServer starting on port 8895
2015-01-08 20:13:25,703 INFO [Device] Updated bound IP address of Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2015-01-08 20:13:26,375 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-01-08 20:13:26,375 INFO [EventDispatcher] Starting EventDispatcher
2015-01-08 20:13:26,375 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-01-08 20:13:26,421 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2015-01-08 20:13:26,421 INFO [RendererSearchSender] Searching for Renderer devices
2015-01-08 20:13:26,453 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek PCIe GBE Family Controller - Packet Scheduler Miniport) and address 192.168.1.9, timeout = 0
2015-01-08 20:13:52,734 INFO [FeedUpdaterThread] Started looking for information about online resources
2015-01-08 20:13:52,765 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2015-01-08 20:13:53,109 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2015-01-08 20:13:53,109 INFO [PlaylistMaintainerThread] Started looking playlist changes
2015-01-08 20:13:58,671 INFO [RendererManager] Stored a new renderer: uuid='d49f9c67-804f-4821-956a-ff4e54cde16b', name = 'Unrecognized device', ipAddress='192.168.1.9', profile = '1'
2015-01-08 20:14:08,640 INFO [ServiioConsole] Initializing Serviio Console
2015-01-08 20:14:08,656 INFO [ServiioConsole] Starting Serviio Console
2015-01-08 20:14:09,531 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2015-01-08 20:14:11,875 INFO [Messages] Loaded console message bundle for locale: en
2015-01-08 20:14:21,718 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2015-01-08 20:14:22,375 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
Post Sat Jan 10, 2015 1:03 am
192.168.1.x are not port numbers, these are your device IP addresses. If you look in the log, you will see that Serviio uses two ports: 23423 and 23424.
For some reason, Serviio was having trouble determining the computer IP address. It finally seems to find 192.168.1.4. After a reboot, your computer IP address seems to change to 192.168.1.9.
Several questions:
How are your devices assigned their IP addresses, via a router (DHCP) or manually (static)?
How many devices are connected to your network?
Are they wired or wireless?
Personally, I suggest assigning a static IP address to the Serviio computer. If you are setting these addresses manually, make sure each device has the same SUBNET address, which should be 255.255.255.0. Once we are sure all the network settings are correct, then we can begin working on your firewall permissions. I don't have any XP machine left, so I would have to make some guesses about how to change the settings. You might even try disabling the firewall completely on the Serviio computer as a test.
DunxUK
Post Wed Jan 14, 2015 12:44 am
Many thanks. I know about the IP addresses but enabled ports 23423, 23424 and 2870.
The IP addresses are indeed handed out by the router, and this computer is indeed 192.168.1.9 and I have made that static now on the router I hope. I tried searching with the firewall completely off but no luck. Serviio does work flawlessly when installed on a netbook on the same network but unfortunately it doesn't have the oompf to transcode anything.
So even without the firewall it still can't see anything except other PCs. Any ideas team?
Many thanks
Duncan
DunxUK
Post Wed Jan 14, 2015 12:53 am
Also there are five things on the network. The TV and the Serviio PC are both on wired connection as is one of the other PCs detected, the other two are wireless. Here is the result of the run with the firewall completely disabled:
2015-01-14 00:48:24,284 INFO [MediaServer] ------------------------------------------------------------------------
2015-01-14 00:48:24,284 INFO [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f)
2015-01-14 00:48:24,284 INFO [MediaServer] Petr Nejedly 2009-2014
2015-01-14 00:48:24,284 INFO [MediaServer] http://www.serviio.org
2015-01-14 00:48:24,284 INFO [MediaServer] Java 1.7.0_05-Oracle Corporation
2015-01-14 00:48:24,284 INFO [MediaServer] OS Windows XP amd64 5.2
2015-01-14 00:48:24,299 INFO [MediaServer] File encoding: windows-1252
2015-01-14 00:48:24,299 INFO [MediaServer] Headless mode enabled: true
2015-01-14 00:48:24,299 INFO [MediaServer] User: SYSTEM
2015-01-14 00:48:24,299 INFO [MediaServer] User home dir: C:\Documents and Settings\Default User
2015-01-14 00:48:24,299 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2015-01-14 00:48:24,299 INFO [MediaServer] ------------------------------------------------------------------------
2015-01-14 00:48:24,377 INFO [WebServer] Socket buffer set to 65535 bytes
2015-01-14 00:48:24,377 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-01-14 00:48:24,409 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-01-14 00:48:24,409 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-01-14 00:48:24,424 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-01-14 00:48:24,424 INFO [DatabaseManager] Using DERBY database language
2015-01-14 00:48:25,205 INFO [MediaServer] ------------------------------------------------------------------------
2015-01-14 00:48:25,205 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2015-01-14 00:48:25,221 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 9 times
2015-01-14 00:48:30,237 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 8 times
2015-01-14 00:48:35,237 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 7 times
2015-01-14 00:48:40,237 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 6 times
2015-01-14 00:48:45,237 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 5 times
2015-01-14 00:48:50,252 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 4 times
2015-01-14 00:48:55,252 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 3 times
2015-01-14 00:49:00,252 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 2 times
2015-01-14 00:49:05,252 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 1 times
2015-01-14 00:49:10,268 INFO [Device] Created UPnP Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2015-01-14 00:49:10,549 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-01-14 00:49:10,612 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2015-01-14 00:49:10,627 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2015-01-14 00:49:10,627 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2015-01-14 00:49:10,627 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2015-01-14 00:49:10,627 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2015-01-14 00:49:10,627 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2015-01-14 00:49:10,627 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013)' (id=sony2013)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2015-01-14 00:49:10,643 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2015-01-14 00:49:10,659 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2015-01-14 00:49:10,705 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-01-14 00:49:10,705 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2015-01-14 00:49:10,705 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2015-01-14 00:49:10,705 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2015-01-14 00:49:10,705 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2015-01-14 00:49:10,705 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2015-01-14 00:49:10,705 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2015-01-14 00:49:10,705 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2015-01-14 00:49:10,705 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2015-01-14 00:49:10,737 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2015-01-14 00:49:10,737 INFO [PluginCompilerThread] Started looking for plugins
2015-01-14 00:49:10,737 INFO [UpdateChecker] Checking if a new version is available
2015-01-14 00:49:10,893 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version N-54096-ge41bf19 Copyright (c) 2000-2013 the FFmpeg developers
2015-01-14 00:49:10,924 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-01-14 00:49:10,955 INFO [WebServer] WebServer starting on port 8895
2015-01-14 00:49:10,955 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 9 times
2015-01-14 00:49:15,955 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 8 times
2015-01-14 00:49:18,877 INFO [ServiioConsole] Initializing Serviio Console
2015-01-14 00:49:18,893 INFO [ServiioConsole] Starting Serviio Console
2015-01-14 00:49:18,955 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2015-01-14 00:49:20,955 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 7 times
2015-01-14 00:49:25,971 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 6 times
2015-01-14 00:49:30,971 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 5 times
2015-01-14 00:49:35,971 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 4 times
2015-01-14 00:49:40,971 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 3 times
2015-01-14 00:49:45,987 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 2 times
2015-01-14 00:49:50,987 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 1 times
2015-01-14 00:49:55,987 INFO [Device] Updated bound IP address of Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2015-01-14 00:49:55,987 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-01-14 00:49:55,987 INFO [EventDispatcher] Starting EventDispatcher
2015-01-14 00:49:55,987 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-01-14 00:49:56,002 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek PCIe GBE Family Controller - Packet Scheduler Miniport) and address 192.168.1.9, timeout = 0
2015-01-14 00:49:56,002 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2015-01-14 00:49:56,002 INFO [RendererSearchSender] Searching for Renderer devices
2015-01-14 00:50:02,284 INFO [Messages] Loaded console message bundle for locale: en
2015-01-14 00:50:04,393 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2015-01-14 00:50:04,955 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2015-01-14 00:50:22,002 INFO [FeedUpdaterThread] Started looking for information about online resources
2015-01-14 00:50:22,018 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2015-01-14 00:50:22,018 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2015-01-14 00:50:22,018 INFO [PlaylistMaintainerThread] Started looking playlist changes
Only other thing is this computer is running 64-bit XP, is that a problem?
Cheers once again!
Post Wed Jan 14, 2015 1:32 am
There's that error again about not finding a local IP address. Strange.
No issues running on a 64 bit OS. I have Windows 7 x64.
I'm wondering if a uninstall and reinstall might help. Something just seems "off".
DunxUK
Post Thu Jan 29, 2015 10:33 pm
Ok reinstalled and it correctly identifying the network card (yay!) but still not seeing the telly, just another PC on the network:
2015-01-29 22:27:22,686 INFO [MediaServer] ------------------------------------------------------------------------
2015-01-29 22:27:22,686 INFO [MediaServer] Serviio DLNA media streaming server v 1.5 (rev. 19ceb8acec8c)
2015-01-29 22:27:22,686 INFO [MediaServer] Petr Nejedly 2009-2015
2015-01-29 22:27:22,686 INFO [MediaServer] http://www.serviio.org
2015-01-29 22:27:22,686 INFO [MediaServer] Java 1.8.0_20-Oracle Corporation x86
2015-01-29 22:27:22,686 INFO [MediaServer] OS Windows XP 5.2
2015-01-29 22:27:22,686 INFO [MediaServer] File encoding: windows-1252
2015-01-29 22:27:22,686 INFO [MediaServer] Headless mode enabled: true
2015-01-29 22:27:22,686 INFO [MediaServer] User: SYSTEM
2015-01-29 22:27:22,686 INFO [MediaServer] User home dir: C:\WINDOWS\system32\config\systemprofile
2015-01-29 22:27:22,686 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2015-01-29 22:27:22,827 INFO [WebServer] Socket buffer set to 65535 bytes
2015-01-29 22:27:22,827 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-01-29 22:27:22,967 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-01-29 22:27:22,967 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-01-29 22:27:22,983 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-01-29 22:27:22,999 INFO [DatabaseManager] Using DERBY database language
2015-01-29 22:27:28,577 INFO [DBSchemaUpdateExecutor] Updating DB schema
2015-01-29 22:27:42,983 INFO [DBSchemaUpdateExecutor] Dropping search index
2015-01-29 22:27:42,983 INFO [SearchManager] Starting up search engine
2015-01-29 22:27:43,202 INFO [DBSchemaUpdateExecutor] Cleaning temporary cache
2015-01-29 22:27:43,217 INFO [Device] Created UPnP Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2015-01-29 22:27:43,296 INFO [DBSchemaUpdateExecutor] Cleaning persistent cache
2015-01-29 22:27:43,311 WARN [IndexedDiskCache] Region [online_technical_metadata] Reseting cache
2015-01-29 22:27:43,983 INFO [MediaServer] ------------------------------------------------------------------------
2015-01-29 22:27:43,983 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2015-01-29 22:27:44,139 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-01-29 22:27:44,186 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2015-01-29 22:27:44,202 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2015-01-29 22:27:44,217 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2015-01-29 22:27:44,217 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2015-01-29 22:27:44,217 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2015-01-29 22:27:44,217 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2015-01-29 22:27:44,217 INFO [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2015-01-29 22:27:44,233 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-01-29 22:27:44,233 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2015-01-29 22:27:44,233 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2015-01-29 22:27:44,233 INFO [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2015-01-29 22:27:44,233 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2015-01-29 22:27:44,233 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2015-01-29 22:27:44,233 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2015-01-29 22:27:44,233 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2015-01-29 22:27:44,233 INFO [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2015-01-29 22:27:44,233 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2015-01-29 22:27:44,233 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2015-01-29 22:27:44,233 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2015-01-29 22:27:44,233 INFO [PluginCompilerThread] Started looking for plugins
2015-01-29 22:27:44,233 INFO [UpdateChecker] Checking if a new version is available
2015-01-29 22:27:45,202 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
2015-01-29 22:27:45,374 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-01-29 22:27:45,389 INFO [WebServer] WebServer starting on port 8895
2015-01-29 22:27:45,405 INFO [Device] Updated bound IP address of Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2015-01-29 22:27:45,405 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-01-29 22:27:45,405 INFO [EventDispatcher] Starting EventDispatcher
2015-01-29 22:27:45,405 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-01-29 22:27:45,405 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek PCIe GBE Family Controller - Packet Scheduler Miniport) and address 192.168.1.9, timeout = 0
2015-01-29 22:27:45,405 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2015-01-29 22:27:45,405 INFO [RendererSearchSender] Searching for Renderer devices
2015-01-29 22:27:48,202 INFO [RendererManager] Stored a new renderer: uuid='ff710aa3-617a-4a86-9b2a-fa1529e15295', name = 'Unrecognized device', ipAddress='192.168.1.4', profile = '1'
2015-01-29 22:28:11,421 INFO [FeedUpdaterWorker] Started looking for information about online resources
2015-01-29 22:28:11,452 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2015-01-29 22:28:11,452 INFO [LocalLibraryManager] Starting automatic library scan
2015-01-29 22:28:11,452 INFO [LibraryDeltaScanner] Starting the library delta scan
2015-01-29 22:28:11,452 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2015-01-29 22:28:22,577 INFO [ServiioConsole] Initializing Serviio Console
2015-01-29 22:28:22,702 INFO [ServiioConsole] Starting Serviio Console
2015-01-29 22:28:22,905 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2015-01-29 22:28:23,374 INFO [Messages] Loaded console message bundle for locale: en
2015-01-29 22:28:24,171 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2015-01-29 22:28:24,452 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2015-01-29 22:29:03,592 INFO [WebServer] WebServer shutting down
2015-01-29 22:29:03,592 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2015-01-29 22:29:03,592 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2015-01-29 22:29:03,592 INFO [EventDispatcher] Leaving EventDispatcher
2015-01-29 22:29:03,592 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2015-01-29 22:29:03,592 INFO [WebServer] WebServer starting on port 8895
2015-01-29 22:29:03,608 INFO [Device] Updated bound IP address of Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2015-01-29 22:29:03,608 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-01-29 22:29:03,608 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-01-29 22:29:03,608 INFO [EventDispatcher] Starting EventDispatcher
2015-01-29 22:29:03,608 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek PCIe GBE Family Controller - Packet Scheduler Miniport) and address 192.168.1.9, timeout = 0
2015-01-29 22:29:03,608 INFO [RendererSearchSender] Searching for Renderer devices
2015-01-29 22:29:05,405 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
I'd be grateful if anyone could make any further suggestions!
Post Fri Jan 30, 2015 1:06 am
I see two IP addresses in this log: 192.168.1.4 and .9. I see .9 is your Serviio computer, and I assume the other computer you mention is .4.
What is the IP address of the TV? Want to make sure it's received its IP address correctly.
Also, just as an observation. I once had a bad Cat5 cable that seemed to work, but in reality wasn't connecting properly. The computer saw the network, but couldn't actually talk with anything. Do you have another cable you can try on the TV?
DunxUK
Post Sat Feb 07, 2015 9:45 am
atc98092 wrote:I see two IP addresses in this log: 192.168.1.4 and .9. I see .9 is your Serviio computer, and I assume the other computer you mention is .4.
The TV detects fine when I install Serviio and run it on my netbook on the same network so everything must be fine right back to the PC itself. Unfortunately the netbook isn't quick enough to transcode. The only difference I can find is the hardware of the PC and the fact it is running XP X64 instead of XP.
DunxUK
Is there any way I can 'ping' the telly from here to see if it is visible?
Post Sat Feb 07, 2015 6:49 pm
If you know the IP address of the TV, then yes you certainly should be able to ping it. I just pinged my Panasonic from my Serviio computer with no problems.
If it's working on your netbook, but not the other computer, that pretty much isolates the problem to the computer. I'm not familiar with XP x64, so I don't know if it had anything different as far as a firewall. I'm also wondering if you have some sort of anti-virus that might be blocking it.
On my home network, I don't run the firewall on any of my computers. Just don't feel it's necessary, since I control everything inside the router. We also don't go to suspicious web sites ;)
Post Sat Feb 07, 2015 10:09 pm
How is everything connected? I presume the netbook was wireless, how about the tv and xp server? What routers and switches are you using?
Users browsing this forum: No registered users and 103 guests
