Serviio library when repo is offline
skala63
Post Thu Feb 05, 2015 10:15 pm
I have a linux file server and linux serviio setup. Both use Ubuntu 14.04 server.
A share (CIFS) )on the file server is mounted on the serviio server.
I rebooted the file server and serviio started removing items from the library.
Is this supposed to happen? Is there anything I can do to stop it from doing this?
Post Fri Feb 06, 2015 3:28 am
Re: Serviio library when repo is offline
What version of Serviio are you using. Version 1.5 improved this dramatically.
skala63
Post Fri Feb 06, 2015 8:38 pm
im using 1.5.
I tested it again by rebooting the file server and it did the same
Post Fri Feb 06, 2015 9:42 pm
Please post a detailed log showing a server reboot.
skala63
Post Sat Feb 07, 2015 9:12 pm
so ive done some more testing and it appears to happen only if the fileserver is rebooted when the share is already mounted.
If both servers are rebooted and the serviio server comes on first, it can't mount the share and DOESNT start removing files from the database
Post Sun Feb 08, 2015 11:56 pm
Can you post detailed log of this happening?
