[SOLVED] 1.5 Version: profiles.xml and ffpmpeg??
skiocink
Post Sun Feb 08, 2015 12:20 pm
I've just upgraded do 1.5 version on my OSX.
I can't find the profiles.xml file (M2TS files problem solved by myself in 1.4 version) and ffmpeg encoder (I want upgrade it)
Suggestions?
Post Sun Feb 08, 2015 9:26 pm
Re: 1.5 Version: profiles.xml and ffpmpeg??
In Windows, the Profiles.xml file is located under the main Serviio folder in the config folder. FFMPEG is located in the lib folder. If the Mac install follows the same structure format, there's the first place to look. If the structure differs on a Mac, then I'll butt out and let someone else help.
Post Sun Feb 08, 2015 11:40 pm
skiocink
Post Wed Feb 11, 2015 2:51 pm
SOLVED!
Thank you
Users browsing this forum: Bing [Bot] and 17 guests
