[Solved] Serviio 1.5 on Unbuntu 14.04.1 LTS
thymon
Post Tue Feb 10, 2015 12:13 pm
Hi all,
I don't understand how i can install serviio 1.5
The Wiki explain for unbuntu 12.04 but not fo 14.04
So, I install FFmepg
sudo add-apt-repository ppa:jon-severinsson/ffmpeg && sudo apt-get update -qq
sudo apt-get install ffmpeg
Install serviio1.5 :
cd ~
wget http://download.serviio.org/releases/serviio-1.5-linux.tar.gz
tar xvf serviio-1.5-linux.tar.gz
cd serviio-1.5
cd bin
./serviio.sh &
./serviio-console.sh
Exception in thread "main" java.lang.UnsupportedClassVersionError: org/serviio/MediaServer : Unsupported major.minor version 52.0
        at java.lang.ClassLoader.defineClass1(Native Method)
        at java.lang.ClassLoader.defineClass(ClassLoader.java:800)
        at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
        at java.net.URLClassLoader.defineClass(URLClassLoader.java:449)
        at java.net.URLClassLoader.access$100(URLClassLoader.java:71)
        at java.net.URLClassLoader$1.run(URLClassLoader.java:361)
        at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
        at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
        at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
        at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:482)
JRE problem ?
thymon@HomeServer:~$ java -version
java version "1.7.0_75"
OpenJDK Runtime Environment (IcedTea 2.5.4) (7u75-2.5.4-1~trusty1)
OpenJDK 64-Bit Server VM (build 24.75-b04, mixed mode)
(sorry for my english)
thymon
Post Tue Feb 10, 2015 2:09 pm
Re: Serviio 1.5 on Unbuntu 14.04.1 LTS
OK JRE updated
java version "1.8.0_31"
Java(TM) SE Runtime Environment (build 1.8.0_31-b13)
Java HotSpot(TM) 64-Bit Server VM (build 25.31-b07, mixed mode)
Launch serviio.sh + serviio-console.sh
$ cd serviio-1.5/bin/
screen -S "serviio" ./serviio.sh
[CTRL] [a] + [D]
screen -S "serviio" ./serviio-console.sh
Console interface appear. But error on terminal console :
Error parsing gtk-icon-sizes string: ''
test external MediaBrower : OK
What is this error ?
Post Tue Feb 10, 2015 10:47 pm
not sure what he error is, probably something around java on your system
thymon
Post Wed Feb 11, 2015 5:22 pm
Hum... icon size on the toolbar (Xubuntu)
Forget about it :-) :-)
Thank you for this app
wojtas40
Post Sun Jan 24, 2016 5:44 pm
zip wrote:not sure what he error is, probably something around java on your system
I (started to) have the same problem. I use Synology DS216Play.
I've installed Serviio 1.5.2 NAS, it worked a few days, meantime there were 2 updates of DSM software, and now I cannot start the server. I have an error:
"Exception in thread "main" java.lang.UnsupportedClassVersionError: org/serviio/MediaServer : Unsupported major.minor version 52.0"
but:
1. Have installed on the system JDK 7 Linux ARM v6/v7 Hard Float ABI (http://www.oracle.com/technetwork/java/ ... 87468.html)
2. Have installed Java SE Embedded 8 (1.8.0_65-0035)
Could you help me to solve the problem?
Post Sun Jan 24, 2016 7:27 pm
Re: [Solved] Serviio 1.5 on Unbuntu 14.04.1 LTS
You need java 8, not Java 7. Make sure the java executable is the one from Java 8.
wojtas40
Post Sun Jan 24, 2016 9:22 pm
zip wrote:You need java 8, not Java 7. Make sure the java executable is the one from Java 8.
JDK 8 not JDK 7?
Post Sun Jan 24, 2016 9:49 pm
Yes... actually you don't need JDK at all, just JRE. In any way, Serviio needs Java 8 to run and it's finding Java 7 on your system.
wojtas40
Post Sun Jan 24, 2016 9:53 pm
Uninstalling JDK v7 worked! Thanks.
Last question: how to check if the Serviio supports HW transcoding on my DS216play?
Post Sun Jan 24, 2016 10:07 pm
You need to ask patters who built the package.
http://pcloadletter.co.uk/2012/01/25/se ... o-package/
