Bravia 2013 online sources issue
skiocink
Post Thu Feb 19, 2015 11:09 am
Hi to all, my Sony Bravia W654 wont reproduce many live streams.
I'm looking to profiles.xml file and I cant see the OnlineTranscoding section in Sony Bravia TV (2013/14) profile.
I'm wondering to add these strings:
<OnlineTranscoding>
<Video targetContainer="mpegts" targetACodec="ac3" aBitrate="384" forceInheritance="true">
<Matches container="applehttp" vCodec="h264" />
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" forceInheritance="true">
<Matches container="asf" />
<Matches container="flv" />
<Matches container="rtp" />
<Matches container="rtsp" />
<Matches container="applehttp" />
<Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" forceInheritance="true">
<Matches container="mp4" />
</OnlineTranscoding>
Something wrong in it?
Post Thu Feb 19, 2015 7:34 pm
Re: Bravia 2013 online sources issue
Sony Bravia 2013/2014 profile inherits of Generic Profile <OnlineTranscoding> section.
You can try to add the 2012 profile section :
      <OnlineTranscoding>
         <!-- Add DAR option for Sony Bravia -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" DAR="16:9" targetACodec="ac3" aBitrate="384" forceInheritance="true">
            <Matches container="asf"/>
            <Matches container="flv"/>
            <Matches container="rtp"/>
            <Matches container="rtsp"/>
            <Matches container="applehttp"/>
After modification, you have to restart serviio service or reboot PC to reload profiles.xml file.
skiocink
Post Fri Feb 20, 2015 10:58 am
its quite similar to mine.
I added also:
and now can see some stream, but its not yet perfect
skiocink
Post Fri Feb 20, 2015 3:14 pm
what do you think about this?
<OnlineTranscoding>
<Matches container="*" />
should resolve any codec transcoding problem
Post Fri Feb 20, 2015 4:11 pm
Yes of course you can. I suggest to create your custom profile with these settings indeed.
But serviio developper would like to minimize transcoding process (only when necessary) to minimize CPU load especially for light system (NAS, Raspberry,etc)
So if you want to contribute to complete Sony 2013/2014 profile, check url online source that are not supported in native by Sony device.
Post "ffmpeg -i" result here to see codec combination not supported, then we will update profile.
skiocink
Post Tue Feb 24, 2015 2:01 pm
Oh ok, understood.
But I run serviio on a Mac Mini that is my mediaserver and transcoding is not a problem
sarahj
Post Tue Mar 10, 2015 8:26 am
Sony Bravia 2013/2014 profile inherits of Generic Profile <OnlineTranscoding> section?
