Mediabrowser "bug on menu" with iOS device. (Linux)
thymon
Post Mon Feb 16, 2015 11:19 am
Hi Zip,
It's me again... :)
All was easy on windows but all is so complicate in Linux ^^
I' have a "bug interface" on mediabrowser with iOS device (iPhone 5/6).
I think it 'll be easier for me to show you than trying to explain it ...
Is it possible to mp you with my outside IP, for try it ? (iOS device needed)
Post Mon Feb 16, 2015 10:15 pm
Re: Mediabrowser "bug on menu" with iOS device. (Linux)
thymon
Post Tue Feb 17, 2015 7:18 pm
I did vidz this better :
http://youtu.be/AAcM3hqeMsE
- if I select a movie in the first page : OK
- If I scroll to select a movie : BUG
auto resize for iOS display bug ?
Because no auto resize on windows and no display bug
Post Wed Feb 18, 2015 10:04 pm
thanks. There is a lot of movement that should not really be there. What is your iOS version?
thymon
Post Wed Feb 18, 2015 11:47 pm
iOS 8.1.3
thank you in advance
Post Thu Feb 19, 2015 12:41 am
And is the same problem on iPad?
thymon
Post Thu Feb 19, 2015 12:56 am
I just tested, it works on the iPad...
(the list of movies is very long to load. IPad 2)
thymon
Post Fri Feb 20, 2015 12:06 pm
Do you need my outside IP to try ?
Post Fri Feb 20, 2015 7:27 pm
No, I have iPhone 4 with iOS 7 so will try to reproduce it.
thymon
Post Fri Feb 20, 2015 11:30 pm
Thank you Zip
thymon
Post Sun Feb 22, 2015 12:14 pm
Tested on iOS 7 (iPhone4)
Same bug.
Post Sun Feb 22, 2015 5:12 pm
Yes, fixed it for 1.5.1. Thanks for reporting
thymon
Post Sun Feb 22, 2015 11:18 pm
Great !!!
Thank you :-D
Users browsing this forum: No registered users and 57 guests
