Serviio does not open
marcusr
Post Tue Feb 17, 2015 11:52 am
Hi Guys,
I have Windows 8.1 and my Serviioo does not work on here. I have reinstalled constantly and followed a few previous posts on here which advises you to install Java etc....
Is there anything else I can try? It worked before on Windows 8.1 But it suddenly stopped working after a while and tried different ways to get it working. I am reluctant to reinstall Windows 8.1 but I would like to cover off all avenues before I consider this as an option.
Could you suggest anything to try that I may not of tried?
Thanks,
Marcus.
Neil
Post Sat Feb 21, 2015 5:23 pm
Re: Serviio does not open
Hi
I have the same problem and I have windows 8.1 and Serviio 1.5.
I have gone into services(local) and tried to restart it but it keeps stopping after a few seconds, all the services that it depands on are working. I have uninstalled and reinstalled Serviio but that does not work. Anyone got any ideas?
Neil
Post Sat Feb 21, 2015 6:40 pm
Ok I have just installed it again but did not uninstall it this time and it is now working.
zingo1
Post Wed Feb 25, 2015 2:49 pm
Same here on my mac removed old version which worked fine downloaded new 1.5.1 but only the console will install and not the server.
