KDL-46HX820-Streaming problems
anousheh
Post Sat Feb 28, 2015 10:13 pm
I have MKV, AVI, MP4, ... video (movie) files to stream to our Sony Bravia TV.
I have installed latest version of Serviio (1.5.1)
Sometimes we have following problems:
- Sounds but no videos
- Narrow videos (aspect ratios not right) on some files
I do not know how to change any setting and codes in Serviio.
This is an example of a MP4 movie with sound only.
Would appreciate if I get help to fix these issues.
Regards,
Anousheh
Complete name : M:\MOVIES (TOSHIBA)\Taken 3 2015.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 1.74 GiB
Duration : 1h 44mn
Overall bit rate : 2 392 Kbps
Encoded date : UTC 2015-01-28 08:22:26
Tagged date : UTC 2015-01-28 11:02:27
Writing application : HandBrake 0.9.9 2013052900
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1h 44mn
Bit rate : 2 228 Kbps
Width : 1 280 pixels
Height : 544 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.128
Stream size : 1.62 GiB (93%)
Writing library : x264 core 130 r2273 b3065e6
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Color primaries : BT.709
Matrix coefficients : BT.709
Color range : Limited
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 44mn
Bit rate mode : Variable
Bit rate : 160 Kbps
Maximum bit rate : 235 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 119 MiB (7%)
Title : Stereo
Language : English
MP4 movie details-Taken 3.txt
(2.07 KiB) Downloaded 845 times
Post Sun Mar 01, 2015 9:24 am
Re: KDL-46HX820-Streaming problems
I don't know...probably due to a AVC encoding setting that sony bravia does not support...such weird files should be transcoded.
I suggest to add a custom profile that you can manually select on serviio console when you want to see such files.
Edit the ./serviio/config/profiles.xml file (make a backup before)
Add the following lines at the end of file, just before the last </Profiles> element.
   <Profile id="custom" name="Sony Bravia TV (2011) *custom*" extendsProfileId="sony2011">
         <Video targetContainer="mpegts" targetVCodec="h264" maxVBitrate="12000" forceVTranscoding="true" targetACodec="ac3" aBitrate="384" DAR="16:9" forceInheritance="true">
            <Matches container="*" vCodec="h264" />
Save the file, then restart serviio service or simply reboot your PC to reload profile.
You can now either select custom profile or select default 2011 profile for your device on serviio console.
anousheh
Post Sun Mar 01, 2015 5:10 pm
Hi Illico,
Thank you so much for your reply. I shall try that and will let you know the result.
All the best,
Anousheh
anousheh
Post Sun Mar 01, 2015 5:30 pm
Hello Illico,
My profile was Sony Bravia TV (2010). I changed it to Sony Bravia TV (2011). It worked but my avi files disappeared. I changed the profile to Sony Bravia TV (2011)-US.
Everything seems working fine. If I come across any problem, I post again.
Thank you so much for your time and input.
Regards,
Anousheh
Users browsing this forum: Google [Bot] and 13 guests
