Power Settings
NailsAndScrews
Post Sun Mar 01, 2015 3:14 pm
Power Settings
Great product, thanks.
I run Serviio on a Windows 7 machine that is set to go to sleep after 20 minutes. It would be nice if when Serviio is actually streaming a file if it would disable sleeping until streaming stops. Similar to what BitTorrent does when it is downloading or uploading files.
MikeWB
Post Wed Mar 11, 2015 7:40 pm
Re: Power Settings
I'm with you I like to shut my laptop lid and put my computer down. I've change the settings so the computer stays on when the lid is closed, but I don't like having to set my computer to never sleep and when I set it to sleep in 3 hours, if I start a second movie after the first one ends the computer cuts Serviio off and goes to sleep halfway threw that movie. I don't know if its possible though? It looks like its fairly easy for programmers set windows to not sleep when a program is running https://msdn.microsoft.com/en-us/library/aa373208(v=vs.85).aspx, but Serviio runs constantly, so you miles as well just set you pc to never sleep, unless you disable Serviio from starting as a service, and then put a shortcut to serviio.bat on your desk top so you can click and run it that way.
Post Thu Mar 12, 2015 5:20 am
Re: Power Settings
Until it is supported natively in Serviio (if ever, Serviio development has to deal with multiple platforms/OS's which isn't an easy task) you may want to try my WinHelper tool: viewtopic.php?f=17&t=12136.
Return to Feature requests
