library not being updated
spudy12
Post Fri Feb 27, 2015 10:12 am
Hi Zip
Ever since the 1.5.x update with the new file change mechanism i have been having to force a refresh to get my files to update. This even happens on the 1.5.1 version.
Running ubuntu 14 with files stored on an NFS NAS server
Post Fri Feb 27, 2015 10:01 pm
Re: library not being updated
Its a shame you didn't post on the beta forums, seeing you are a beta tester.
You can force the poller scanner, see the wiki article about the library scanning mechanism for details.
apw2607
Post Sun Mar 01, 2015 7:12 am
I'm running on Mac OSX and not seeing auto refresh either. force refresh works fine however. Using 1.5.1
spudy12
Post Mon Mar 02, 2015 9:41 am
zip wrote:Its a shame you didn't post on the beta forums, seeing you are a beta tester.
Sorry Zip, been extremely busy with work at the moment so not had much time for anything and didn't get a chance to post whilst it was in beta.
Saw the change log re force poller and will give it a try.
Post Mon Mar 02, 2015 7:40 pm
apw2607 wrote:I'm running on Mac OSX and not seeing auto refresh either. force refresh works fine however. Using 1.5.1
On Mac, it does auto-refresh every 5 minutes, by default - is that not the case?
apw2607
Post Tue Mar 03, 2015 2:24 am
You know what. I think I could have being a bit hasty with my analysis. It appears Serviio is indeed working correctly and automatically updating its library almost immediately.
What I was expecting to happen then is that the clients would also see the update, but that doesnt seem to be happening. In order to see any changes, I need to restart the client DLNA app (so Kodi on a AppleTV), or my Blueray player. I guess this is a symptom of the client rather than the server.
CoffeeMan
Post Fri Mar 06, 2015 2:42 pm
Hi
Since the upgrade to 1.5.x my Serviio also stopped updating my library (Windows 7 x64). It does so on startup but then it completely stops updating.
Example from yesterday:
Boot up computer at 8:00: search started & library updated.
Added 2 mkv files at 9:00: still not added to library at 11:00.
Forced update at 11:01: files added & library updated.
Add 1 new file at 12:00: still not added to library at 15:00.
Force update again: files added now & library updated.
I have to click the force refresh button every time I add files which is pretty annoying.
Here's the log from today:
Computer booted at 7:37 & 1 file was added.
Forced update at 15:26 because I added files around 12:00 & they weren't added until after the forced refresh at 15:26.
2015-03-06 07:37:09,584 INFO [MediaServer] ------------------------------------------------------------------------
2015-03-06 07:37:09,631 INFO [MediaServer] Serviio DLNA media streaming server v 1.5.1 (rev. 9d3f18af690f)
2015-03-06 07:37:09,631 INFO [MediaServer] Petr Nejedly 2009-2015
2015-03-06 07:37:09,631 INFO [MediaServer] http://www.serviio.org
2015-03-06 07:37:09,631 INFO [MediaServer] Java 1.8.0_31-Oracle Corporation x86
2015-03-06 07:37:09,631 INFO [MediaServer] OS Windows 7 6.1
2015-03-06 07:37:09,631 INFO [MediaServer] File encoding: windows-1252
2015-03-06 07:37:09,709 INFO [MediaServer] Headless mode enabled: true
2015-03-06 07:37:09,709 INFO [MediaServer] User: JUSTMYPC$
2015-03-06 07:37:09,709 INFO [MediaServer] User home dir: C:\Windows\system32\config\systemprofile
2015-03-06 07:37:09,709 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2015-03-06 07:37:09,709 INFO [MediaServer] ------------------------------------------------------------------------
2015-03-06 07:37:18,040 INFO [WebServer] Socket buffer set to 65535 bytes
2015-03-06 07:37:18,164 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-03-06 07:37:23,765 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-03-06 07:37:23,765 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-03-06 07:37:24,155 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-03-06 07:37:24,716 INFO [DatabaseManager] Using DERBY database language
2015-03-06 07:37:37,805 INFO [MediaServer] ------------------------------------------------------------------------
2015-03-06 07:37:37,805 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2015-03-06 07:37:39,474 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-03-06 07:37:39,536 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2015-03-06 07:37:39,536 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2015-03-06 07:37:39,536 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2015-03-06 07:37:39,536 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2015-03-06 07:37:39,536 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2015-03-06 07:37:39,599 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2015-03-06 07:37:39,599 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2015-03-06 07:37:39,599 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2015-03-06 07:37:39,599 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2015-03-06 07:37:39,599 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2015-03-06 07:37:39,599 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2015-03-06 07:37:39,599 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2015-03-06 07:37:39,599 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2015-03-06 07:37:39,599 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2015-03-06 07:37:39,599 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2015-03-06 07:37:39,599 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2015-03-06 07:37:39,599 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2015-03-06 07:37:39,599 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2015-03-06 07:37:39,599 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2015-03-06 07:37:39,614 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2015-03-06 07:37:39,630 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2015-03-06 07:37:39,630 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2015-03-06 07:37:39,630 INFO [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2015-03-06 07:37:39,630 INFO [ProfilesDefinitionParser] Added profile 'Apple iPad/iPhone' (id=Apple_iPad_iPhone)
2015-03-06 07:37:39,646 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-03-06 07:37:39,646 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2015-03-06 07:37:39,646 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2015-03-06 07:37:39,646 INFO [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2015-03-06 07:37:39,646 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2015-03-06 07:37:39,646 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2015-03-06 07:37:39,646 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2015-03-06 07:37:39,646 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2015-03-06 07:37:39,646 INFO [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2015-03-06 07:37:39,646 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2015-03-06 07:37:39,661 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2015-03-06 07:37:39,724 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2015-03-06 07:37:39,739 INFO [UpdateChecker] Checking if a new version is available
2015-03-06 07:37:39,755 INFO [PluginCompilerThread] Started looking for plugins
2015-03-06 07:37:43,093 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
2015-03-06 07:37:43,312 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-03-06 07:37:43,748 INFO [WebServer] WebServer starting on port 8895
2015-03-06 07:37:43,795 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-03-06 07:37:43,795 INFO [EventDispatcher] Starting EventDispatcher
2015-03-06 07:37:43,795 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-03-06 07:37:43,811 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2015-03-06 07:37:43,852 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Intel(R) 82579LM Gigabit Network Connection) and address 192.168.0.2, timeout = 0
2015-03-06 07:37:43,868 INFO [RendererSearchSender] Searching for Renderer devices
2015-03-06 07:38:09,905 INFO [FeedUpdaterWorker] Started looking for information about online resources
2015-03-06 07:38:10,004 INFO [FileDeltaWatcher] Using 'sun.nio.fs.WindowsWatchService' for delta scan
2015-03-06 07:38:10,080 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2015-03-06 07:38:10,144 INFO [LocalLibraryManager] Starting automatic library scan
2015-03-06 07:38:10,173 INFO [LibraryDeltaScanner] Added repository 'E:\Video' to delta scanner (NATIVE)
2015-03-06 07:39:15,941 INFO [SearchManager] Starting up search engine
2015-03-06 07:39:16,430 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2015-03-06 07:39:16,903 INFO [MediaFileIndexer] Added file 'Walk_Downtown.mkv' (title: Walk_Downtown) to Library
2015-03-06 08:18:52,500 INFO [ServiioConsole] Initializing Serviio Console
2015-03-06 08:18:52,654 INFO [ServiioConsole] Starting Serviio Console
2015-03-06 08:19:14,400 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2015-03-06 08:19:25,317 INFO [Messages] Loaded console message bundle for locale: en
2015-03-06 08:19:49,997 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2015-03-06 15:26:55,948 INFO [LibraryOneTimeScanner] Interrupting library scan
2015-03-06 15:26:55,948 INFO [LibraryDeltaScanner] Stopping the library delta scan
2015-03-06 15:26:55,949 INFO [PlaylistMaintainerWorker] Finished looking for playlist changes
2015-03-06 15:26:56,088 INFO [LocalLibraryManager] Starting automatic library scan
2015-03-06 15:26:56,108 INFO [LibraryDeltaScanner] Added repository 'E:\Video' to delta scanner (NATIVE)
2015-03-06 15:27:08,667 INFO [LibraryDeltaScanner] Starting the library delta scan
2015-03-06 15:27:08,668 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2015-03-06 15:27:09,928 INFO [MediaFileIndexer] Added file 'Holidays01.mkv' (title: Holidays01) to Library
2015-03-06 15:27:10,704 INFO [MediaFileIndexer] Added file 'Holidays02.mkv' (title: Holidays02) to Library
EDIT:
Tried with POLLER option but doesn't work either, log file clearly states that POLLER is used for the folder. Interval is set to 1 minute but after 10 minutes the file still isn't added. It's just one folder on a local disk. Guess I'll go back to the 1.4.x version.
Post Sun Mar 08, 2015 12:41 pm
Can you post detailed log? What is your OS and the FileSystem of the E drive?
discosux
Post Tue Mar 10, 2015 9:07 pm
I seem to have the same issue on a WinXP machine. I also get ffmpg.exe errors when I force a refresh. Weird thing is that some files are added after I reboot serviio, and then the automatic updating just seems to stop after a number of files or days. I don't mind making a log, if I know what bit you want. Running a debug log while forcing a refresh produces a lot of data, I can't imagine you'd want that posted here.
Post Tue Mar 10, 2015 9:38 pm
the ffmpeg errors I guess
CoffeeMan
Post Thu Mar 12, 2015 10:07 am
zip wrote:Can you post detailed log? What is your OS and the FileSystem of the E drive?
It's a Windows 7 SP1 x64 machine & the E drive is NTFS. The same configuration thatn worked with the 1.4.x version.
I'll post a detailed log asap.
Post Thu Mar 12, 2015 9:53 pm
thanks. NTFS and local drive? or remote?
discosux
Post Fri Mar 13, 2015 2:41 pm
zip wrote:the ffmpeg errors I guess
I switched on the debug log, and since that time it runs like a charm... :?
SpaceAce
Post Sun Mar 22, 2015 6:49 am
I also am unable to have my library automatically update. I am running v1.5.1 of Serviio -- on my Raspberry Pi 2. Here is a snippet of my log:
2015-03-21 23:28:54,535 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:RenderingControl:1 from address /192.168.1.15:43215s
2015-03-21 23:28:56,545 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.15:43215s
2015-03-21 23:28:56,561 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:43215
2015-03-21 23:28:57,085 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:2 from address /192.168.1.15:43215s
2015-03-21 23:28:57,565 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.15:43215s
2015-03-21 23:28:57,567 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.15:43215s
2015-03-21 23:28:57,570 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.15:43215s
2015-03-21 23:28:57,572 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.15:43215s
2015-03-21 23:28:57,575 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:43215
2015-03-21 23:29:02,575 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:RenderingControl:1 from address /192.168.1.15:58828s
2015-03-21 23:29:04,585 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.15:58828s
2015-03-21 23:29:04,587 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:58828
2015-03-21 23:29:05,339 DEBUG [SearchManager] Committing search index
2015-03-21 23:29:05,685 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:2 from address /192.168.1.15:58828s
2015-03-21 23:29:05,745 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.15:58828s
2015-03-21 23:29:05,747 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.15:58828s
2015-03-21 23:29:05,748 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.15:58828s
2015-03-21 23:29:05,750 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.15:58828s
2015-03-21 23:29:05,752 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:58828
2015-03-21 23:29:13,950 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-03-21 23:29:13,951 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-03-21 23:29:35,341 DEBUG [SearchManager] Committing search index
2015-03-21 23:29:49,154 DEBUG [WebServer] I/O error: Connection reset
2015-03-21 23:30:05,343 DEBUG [SearchManager] Committing search index
2015-03-21 23:30:13,954 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-03-21 23:30:13,955 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-03-21 23:30:21,659 DEBUG [ServiioHttpService] Incoming request from /192.168.1.15:54311: SUBSCRIBE /serviceEventing/ContentDirectory HTTP/1.1, headers = [HOST: 192.168.1.17:8895,SID: uuid:759bdfa4-119f-47d2-b59e-1f08daf26fbf,TIMEOUT: Second-300,Connection: close]]
2015-03-21 23:30:21,664 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.15
2015-03-21 23:30:21,668 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ContentDirectory and subscription uuid:759bdfa4-119f-47d2-b59e-1f08daf26fbf
2015-03-21 23:30:21,668 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ContentDirectory and subscription 759bdfa4-119f-47d2-b59e-1f08daf26fbf
2015-03-21 23:30:35,345 DEBUG [SearchManager] Committing search index
2015-03-21 23:30:51,645 DEBUG [ServiioHttpService] Incoming request from /192.168.1.15:54312: GET /deviceDescription/7c03e23b-dd40-3855-8e20-f7d9756dc143 HTTP/1.1, headers = [Accept: */*,Host: 192.168.1.17:8895,User-Agent: Mozilla/4.0 (Compatible, Aggregation, EMC, Twonky, 7.2.9-6, Linux 2.6.31.8; armv5tel) DLNADOC/1.50,Connection: close]]
2015-03-21 23:30:51,647 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.15
2015-03-21 23:30:51,651 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 7c03e23b-dd40-3855-8e20-f7d9756dc143 from 192.168.1.15 (headers = [Accept: */*,Host: 192.168.1.17:8895,User-Agent: Mozilla/4.0 (Compatible, Aggregation, EMC, Twonky, 7.2.9-6, Linux 2.6.31.8; armv5tel) DLNADOC/1.50,Connection: close])
2015-03-21 23:30:51,651 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.15
2015-03-21 23:30:51,653 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Accept: */*,Host: 192.168.1.17:8895,User-Agent: Mozilla/4.0 (Compatible, Aggregation, EMC, Twonky, 7.2.9-6, Linux 2.6.31.8; armv5tel) DLNADOC/1.50,Connection: close]
2015-03-21 23:30:51,665 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.15
2015-03-21 23:30:51,782 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2015-03-21 23:30:51,848 DEBUG [ServiioHttpService] Incoming request from /192.168.1.15:54314: SUBSCRIBE /serviceEventing/ContentDirectory HTTP/1.1, headers = [HOST: 192.168.1.17:8895,SID: uuid:759bdfa4-119f-47d2-b59e-1f08daf26fbf,TIMEOUT: Second-300,Connection: close]]
2015-03-21 23:30:51,849 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.15
2015-03-21 23:30:51,851 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ContentDirectory and subscription uuid:759bdfa4-119f-47d2-b59e-1f08daf26fbf
2015-03-21 23:30:51,852 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ContentDirectory and subscription 759bdfa4-119f-47d2-b59e-1f08daf26fbf
2015-03-21 23:31:05,347 DEBUG [SearchManager] Committing search index
2015-03-21 23:31:13,958 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-03-21 23:31:13,958 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-03-21 23:31:33,594 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:RenderingControl:1 from address /192.168.1.15:58882s
2015-03-21 23:31:35,349 DEBUG [SearchManager] Committing search index
2015-03-21 23:31:35,599 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.15:58882s
2015-03-21 23:31:35,601 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:58882
2015-03-21 23:31:36,351 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:2 from address /192.168.1.15:58882s
2015-03-21 23:31:36,608 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.15:58882s
2015-03-21 23:31:36,610 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.15:58882s
2015-03-21 23:31:36,612 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.15:58882s
2015-03-21 23:31:36,613 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.15:58882s
2015-03-21 23:31:36,615 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:58882
2015-03-21 23:31:41,619 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:RenderingControl:1 from address /192.168.1.15:56946s
2015-03-21 23:31:43,628 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.15:56946s
2015-03-21 23:31:43,630 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:2 from address /192.168.1.15:56946s
2015-03-21 23:31:43,630 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:56946
2015-03-21 23:31:43,688 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.15:56946s
2015-03-21 23:31:43,690 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.15:56946s
2015-03-21 23:31:43,692 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.15:56946s
2015-03-21 23:31:43,722 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.15:56946s
2015-03-21 23:31:43,724 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:56946
2015-03-21 23:32:05,350 DEBUG [SearchManager] Committing search index
2015-03-21 23:32:13,961 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-03-21 23:32:13,961 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-03-21 23:32:16,370 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.1.17, timeout = 0
2015-03-21 23:32:16,374 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 7c03e23b-dd40-3855-8e20-f7d9756dc143
2015-03-21 23:32:18,185 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:15 (advertisement duration is 1800 sec.)
2015-03-21 23:32:35,352 DEBUG [SearchManager] Committing search index
2015-03-21 23:33:05,354 DEBUG [SearchManager] Committing search index
2015-03-21 23:33:13,982 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-03-21 23:33:13,983 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-03-21 23:33:14,943 DEBUG [PlaylistDAOImpl] Reading all Playlists
2015-03-21 23:33:21,622 DEBUG [ServiioHttpService] Incoming request from /192.168.1.15:55986: SUBSCRIBE /serviceEventing/ContentDirectory HTTP/1.1, headers = [HOST: 192.168.1.17:8895,SID: uuid:759bdfa4-119f-47d2-b59e-1f08daf26fbf,TIMEOUT: Second-300,Connection: close]]
2015-03-21 23:33:21,624 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.15
2015-03-21 23:33:21,626 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ContentDirectory and subscription uuid:759bdfa4-119f-47d2-b59e-1f08daf26fbf
2015-03-21 23:33:21,627 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ContentDirectory and subscription 759bdfa4-119f-47d2-b59e-1f08daf26fbf
2015-03-21 23:33:35,356 DEBUG [SearchManager] Committing search index
2015-03-21 23:34:05,358 DEBUG [SearchManager] Committing search index
2015-03-21 23:34:11,559 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:RenderingControl:1 from address /192.168.1.15:55191s
2015-03-21 23:34:13,571 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.15:55191s
2015-03-21 23:34:13,573 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:55191
2015-03-21 23:34:13,985 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-03-21 23:34:13,986 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-03-21 23:34:14,207 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:2 from address /192.168.1.15:55191s
2015-03-21 23:34:14,681 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.15:55191s
2015-03-21 23:34:14,683 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.15:55191s
2015-03-21 23:34:14,685 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.15:55191s
2015-03-21 23:34:14,687 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.15:55191s
2015-03-21 23:34:14,688 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:55191
2015-03-21 23:34:19,743 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:RenderingControl:1 from address /192.168.1.15:49315s
2015-03-21 23:34:21,701 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.15:49315s
2015-03-21 23:34:21,703 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:49315
2015-03-21 23:34:22,801 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:2 from address /192.168.1.15:49315s
2015-03-21 23:34:22,861 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.15:49315s
2015-03-21 23:34:22,863 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.15:49315s
2015-03-21 23:34:22,865 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.15:49315s
2015-03-21 23:34:22,867 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.15:49315s
2015-03-21 23:34:22,869 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:49315
2015-03-21 23:34:35,360 DEBUG [SearchManager] Committing search index
2015-03-21 23:34:51,631 DEBUG [ServiioHttpService] Incoming request from /192.168.1.15:56004: GET /deviceDescription/7c03e23b-dd40-3855-8e20-f7d9756dc143 HTTP/1.1, headers = [Accept: */*,Host: 192.168.1.17:8895,User-Agent: Mozilla/4.0 (Compatible, Aggregation, EMC, Twonky, 7.2.9-6, Linux 2.6.31.8; armv5tel) DLNADOC/1.50,Connection: close]]
2015-03-21 23:34:51,633 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.15
2015-03-21 23:34:51,636 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 7c03e23b-dd40-3855-8e20-f7d9756dc143 from 192.168.1.15 (headers = [Accept: */*,Host: 192.168.1.17:8895,User-Agent: Mozilla/4.0 (Compatible, Aggregation, EMC, Twonky, 7.2.9-6, Linux 2.6.31.8; armv5tel) DLNADOC/1.50,Connection: close])
2015-03-21 23:34:51,637 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.15
2015-03-21 23:34:51,638 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Accept: */*,Host: 192.168.1.17:8895,User-Agent: Mozilla/4.0 (Compatible, Aggregation, EMC, Twonky, 7.2.9-6, Linux 2.6.31.8; armv5tel) DLNADOC/1.50,Connection: close]
2015-03-21 23:34:51,645 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.15
2015-03-21 23:34:51,705 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2015-03-21 23:34:51,764 DEBUG [ServiioHttpService] Incoming request from /192.168.1.15:56006: SUBSCRIBE /serviceEventing/ContentDirectory HTTP/1.1, headers = [HOST: 192.168.1.17:8895,SID: uuid:759bdfa4-119f-47d2-b59e-1f08daf26fbf,TIMEOUT: Second-300,Connection: close]]
2015-03-21 23:34:51,765 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.15
2015-03-21 23:34:51,767 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ContentDirectory and subscription uuid:759bdfa4-119f-47d2-b59e-1f08daf26fbf
2015-03-21 23:34:51,768 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ContentDirectory and subscription 759bdfa4-119f-47d2-b59e-1f08daf26fbf
2015-03-21 23:35:05,362 DEBUG [SearchManager] Committing search index
2015-03-21 23:35:13,988 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-03-21 23:35:13,989 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-03-21 23:35:35,364 DEBUG [SearchManager] Committing search index
2015-03-21 23:36:05,366 DEBUG [SearchManager] Committing search index
2015-03-21 23:36:14,037 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-03-21 23:36:14,037 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-03-21 23:36:33,323 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.1.17, timeout = 0
2015-03-21 23:36:33,327 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 7c03e23b-dd40-3855-8e20-f7d9756dc143
2015-03-21 23:36:35,136 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:10 (advertisement duration is 1800 sec.)
2015-03-21 23:36:35,368 DEBUG [SearchManager] Committing search index
2015-03-21 23:36:50,560 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:RenderingControl:1 from address /192.168.1.15:39345s
2015-03-21 23:36:52,564 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.15:39345s
2015-03-21 23:36:52,566 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:2 from address /192.168.1.15:39345s
2015-03-21 23:36:52,575 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:39345
2015-03-21 23:36:52,625 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.15:39345s
2015-03-21 23:36:52,626 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.15:39345s
2015-03-21 23:36:52,628 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.15:39345s
2015-03-21 23:36:52,630 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.15:39345s
2015-03-21 23:36:52,631 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:39345
2015-03-21 23:36:57,635 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:RenderingControl:1 from address /192.168.1.15:39894s
2015-03-21 23:36:59,644 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.15:39894s
2015-03-21 23:36:59,646 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:39894
2015-03-21 23:37:00,210 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:2 from address /192.168.1.15:39894s
2015-03-21 23:37:00,300 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.15:39894s
2015-03-21 23:37:00,302 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.15:39894s
2015-03-21 23:37:00,304 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.15:39894s
2015-03-21 23:37:00,306 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.15:39894s
2015-03-21 23:37:00,307 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:39894
2015-03-21 23:37:05,370 DEBUG [SearchManager] Committing search index
2015-03-21 23:37:14,040 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-03-21 23:37:14,040 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-03-21 23:37:21,579 DEBUG [ServiioHttpService] Incoming request from /192.168.1.15:42310: SUBSCRIBE /serviceEventing/ContentDirectory HTTP/1.1, headers = [HOST: 192.168.1.17:8895,SID: uuid:759bdfa4-119f-47d2-b59e-1f08daf26fbf,TIMEOUT: Second-300,Connection: close]]
2015-03-21 23:37:21,581 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.15
2015-03-21 23:37:21,584 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ContentDirectory and subscription uuid:759bdfa4-119f-47d2-b59e-1f08daf26fbf
2015-03-21 23:37:21,585 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ContentDirectory and subscription 759bdfa4-119f-47d2-b59e-1f08daf26fbf
2015-03-21 23:37:35,372 DEBUG [SearchManager] Committing search index
2015-03-21 23:38:05,374 DEBUG [SearchManager] Committing search index
2015-03-21 23:38:14,043 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-03-21 23:38:14,043 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-03-21 23:38:14,947 DEBUG [PlaylistDAOImpl] Reading all Playlists
2015-03-21 23:38:35,376 DEBUG [SearchManager] Committing search index
2015-03-21 23:38:51,533 DEBUG [ServiioHttpService] Incoming request from /192.168.1.15:42313: GET /deviceDescription/7c03e23b-dd40-3855-8e20-f7d9756dc143 HTTP/1.1, headers = [Accept: */*,Host: 192.168.1.17:8895,User-Agent: Mozilla/4.0 (Compatible, Aggregation, EMC, Twonky, 7.2.9-6, Linux 2.6.31.8; armv5tel) DLNADOC/1.50,Connection: close]]
2015-03-21 23:38:51,535 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.15
2015-03-21 23:38:51,539 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 7c03e23b-dd40-3855-8e20-f7d9756dc143 from 192.168.1.15 (headers = [Accept: */*,Host: 192.168.1.17:8895,User-Agent: Mozilla/4.0 (Compatible, Aggregation, EMC, Twonky, 7.2.9-6, Linux 2.6.31.8; armv5tel) DLNADOC/1.50,Connection: close])
2015-03-21 23:38:51,539 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.15
2015-03-21 23:38:51,542 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Accept: */*,Host: 192.168.1.17:8895,User-Agent: Mozilla/4.0 (Compatible, Aggregation, EMC, Twonky, 7.2.9-6, Linux 2.6.31.8; armv5tel) DLNADOC/1.50,Connection: close]
2015-03-21 23:38:51,547 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.15
2015-03-21 23:38:51,599 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2015-03-21 23:38:51,651 DEBUG [ServiioHttpService] Incoming request from /192.168.1.15:42315: SUBSCRIBE /serviceEventing/ContentDirectory HTTP/1.1, headers = [HOST: 192.168.1.17:8895,SID: uuid:759bdfa4-119f-47d2-b59e-1f08daf26fbf,TIMEOUT: Second-300,Connection: close]]
2015-03-21 23:38:51,652 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.15
2015-03-21 23:38:51,659 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ContentDirectory and subscription uuid:759bdfa4-119f-47d2-b59e-1f08daf26fbf
2015-03-21 23:38:51,659 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ContentDirectory and subscription 759bdfa4-119f-47d2-b59e-1f08daf26fbf
2015-03-21 23:39:05,378 DEBUG [SearchManager] Committing search index
2015-03-21 23:39:14,046 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-03-21 23:39:14,047 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-03-21 23:39:27,486 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:RenderingControl:1 from address /192.168.1.15:45387s
2015-03-21 23:39:29,498 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.15:45387s
2015-03-21 23:39:29,499 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:2 from address /192.168.1.15:45387s
2015-03-21 23:39:29,500 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:45387
2015-03-21 23:39:29,558 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.15:45387s
2015-03-21 23:39:29,559 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.15:45387s
2015-03-21 23:39:29,561 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.15:45387s
2015-03-21 23:39:29,563 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.15:45387s
2015-03-21 23:39:29,565 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:45387
2015-03-21 23:39:34,568 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:RenderingControl:1 from address /192.168.1.15:54257s
2015-03-21 23:39:35,400 DEBUG [SearchManager] Committing search index
2015-03-21 23:39:36,578 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.15:54257s
2015-03-21 23:39:36,580 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:2 from address /192.168.1.15:54257s
2015-03-21 23:39:36,580 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:54257
2015-03-21 23:39:36,638 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.15:54257s
2015-03-21 23:39:36,640 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.15:54257s
2015-03-21 23:39:36,641 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.15:54257s
2015-03-21 23:39:36,643 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.15:54257s
2015-03-21 23:39:36,645 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.15:54257
2015-03-21 23:40:05,402 DEBUG [SearchManager] Committing search index
2015-03-21 23:40:14,073 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-03-21 23:40:14,073 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-03-21 23:40:35,404 DEBUG [SearchManager] Committing search index
2015-03-21 23:40:45,615 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.1.17, timeout = 0
2015-03-21 23:40:45,619 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 7c03e23b-dd40-3855-8e20-f7d9756dc143
2015-03-21 23:40:47,428 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:51 (advertisement duration is 1800 sec.)
2015-03-21 23:41:05,407 DEBUG [SearchManager] Committing search index
2015-03-21 23:41:14,077 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-03-21 23:41:14,078 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-03-21 23:41:16,141 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.13:58226s
2015-03-21 23:41:16,145 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.13:58226s
2015-03-21 23:41:16,147 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.13:58226
2015-03-21 23:41:16,199 DEBUG [ServiioHttpService] Incoming request from /192.168.1.13:65219: GET /deviceDescription/7c03e23b-dd40-3855-8e20-f7d9756dc143 HTTP/1.1, headers = [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.1.17:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50]]
2015-03-21 23:41:16,201 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.13
2015-03-21 23:41:16,206 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 7c03e23b-dd40-3855-8e20-f7d9756dc143 from 192.168.1.13 (headers = [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.1.17:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50])
2015-03-21 23:41:16,206 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.13
2015-03-21 23:41:16,208 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.1.17:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50]
2015-03-21 23:41:16,213 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.13
2015-03-21 23:41:16,308 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2015-03-21 23:41:16,352 DEBUG [ServiioHttpService] Incoming request from /192.168.1.13:65223: GET /icon/smallPNG HTTP/1.1, headers = [Connection: Keep-Alive,User-Agent: Windows-Media-Player-DMS/12.0.7601.17514,Host: 192.168.1.17:8895]]
2015-03-21 23:41:16,353 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.13
2015-03-21 23:41:16,355 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-03-21 23:41:19,135 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.13:58226s
2015-03-21 23:41:19,138 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.13:58226
2015-03-21 23:41:19,140 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.13:58226s
2015-03-21 23:41:22,134 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.13:58226s
2015-03-21 23:41:22,138 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.13:58226s
2015-03-21 23:41:22,140 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.13:58226
2015-03-21 23:41:22,553 DEBUG [ServiioHttpService] Incoming request from /192.168.1.15:42332: SUBSCRIBE /serviceEventing/ContentDirectory HTTP/1.1, headers = [HOST: 192.168.1.17:8895,SID: uuid:759bdfa4-119f-47d2-b59e-1f08daf26fbf,TIMEOUT: Second-300,Connection: close]]
2015-03-21 23:41:22,555 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.15
2015-03-21 23:41:22,558 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ContentDirectory and subscription uuid:759bdfa4-119f-47d2-b59e-1f08daf26fbf
2015-03-21 23:41:22,558 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ContentDirectory and subscription 759bdfa4-119f-47d2-b59e-1f08daf26fbf
Library update is selected via the GUI of Serviio Console, but updates only happen if I reboot, or force a library refresh from the GUI. Any thoughts? Let me know if you have questions, please.
Post Sun Mar 22, 2015 7:15 am
Try using the poller scanning mechanism - not on Linux, but see http://wiki.serviio.org/doku.php?id=lib ... _mechanism and viewtopic.php?f=6&t=18500#p99293 for an example of how to set it up.
SpaceAce
Post Sun Mar 22, 2015 7:24 am
I did add the poller statement, like this:
JAVA_OPTS="-Dserviio.forceLibraryPoller=true -Dserviio.libraryPollerFrequency=2 -Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade -Dderby.system.home=$SERVIIO_HOME/library -Dserviio.home=$SERVIIO_HOME -Dffmpeg.location=ffmpeg -Ddcraw.location=dcraw"
Is this correct?
SpaceAce
Post Sun Mar 22, 2015 7:40 am
I forgot to mention that the the files are in a mapped folder called /home/pi/movies -- which is mapped via my /etc/fstab like so:
//192.168.1.15/Movies /home/pi/movies cifs _netdev,username=username,password=password,sec=ntlm 0 0
I have no issue serving these NAS files, via Serviio, to my Blu-Ray player; the problem is that there is no automatic update of newly edited/added/deleted files.
spudy12
Post Mon Mar 23, 2015 9:44 am
SpaceAce wrote:I did add the poller statement, like this:
Is this correct?
Looks correct, did you restart the serviio service after?
daisyraven
Post Mon Mar 23, 2015 11:48 am
Experiencing same with Serviio 1.5.1 . Mac OS X 10.10.2
SpaceAce
Post Mon Mar 23, 2015 12:17 pm
Is this correct?
Oh, yes. What is interesting is that if I use the console to "Add Path" to add the shares by UNC--- if I use //myIPaddress/myshare, the system changes it to /myIPaddress/myshare, and if I use \\myIPaddress\myshare, it changes to /home/pi\myIPaddress\myshare--- do I can't add the share using UNC at all. So I have to use /etc/fstab to mount them first, and add the shares as local. Any ideas?
Return to User experiences
Users browsing this forum: Baidu [Spider] and 3 guests
