Sony Bravia KDL-22EX320 - Audio / no picture
prmadmax
Post Tue Mar 03, 2015 12:06 am
I have an MKV that will play, however I get no picture on the TV. Audio works fine.
Device: Synology NAS DS1512+
TV: Sony Bravia KDL-22EX320
Serviio version: 1.4.1.2
Profile: Sony Bravia TV (2012) - US
Seem to find I have issues with the non-us version.
ffmpeg -i output:
Input #0, matroska,webm, from 'Orpheus.mkv':
    creation_time   : 2010-05-25 02:01:22
  Duration: 00:44:02.69, start: 0.000000, bitrate: 1902 kb/s
    Chapter #0.0: start 0.000000, end 545.127911
      title           : Chapter 1
    Chapter #0.1: start 545.127911, end 985.275956
      title           : Chapter 2
    Chapter #0.2: start 985.275956, end 1521.603411
      title           : Chapter 3
    Chapter #0.3: start 1521.603411, end 2011.718033
      title           : Chapter 4
    Chapter #0.4: start 2011.718033, end 2642.688000
      title           : Chapter 5
    Stream #0:0(eng): Video: h264 (High), yuv420p, 720x480 [SAR 853:720 DAR 853:
480], SAR 186:157 DAR 279:157, 23.98 fps, 23.98 tbr, 1k tbn, 180k tbc (default)
    Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default)
      title           : English
    Stream #0:2(eng): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s
      title           : Director's Commentary
    Stream #0:3(eng): Subtitle: subrip (default)
      title           : English
MediaInfo
Unique ID                                : 181480359227214055481944786611784835792 (0x8887D8875B666E39A064FCB1553EE2D0)
Complete name                            : C:\Users\Mark\Desktop\Orpheus.mkv
File size                                : 599 MiB
Duration                                 : 44mn 2s
Overall bit rate                         : 1 902 Kbps
Encoded date                             : UTC 2010-05-25 02:01:22
Writing application                      : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24
Writing library                          : libebml v0.8.0 + libmatroska v0.9.0
Format profile                           : High@L3.1
Format settings, ReFrames                : 9 frames
Duration                                 : 44mn 2s
Bit rate                                 : 1 261 Kbps
Width                                    : 720 pixels
Height                                   : 480 pixels
Original display aspect ratio            : 16:9
Standard                                 : NTSC
Bits/(Pixel*Frame)                       : 0.152
Stream size                              : 386 MiB (64%)
Writing library                          : x264 core 88
Encoding settings                        : cabac=1 / ref=9 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1261 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Color primaries                          : BT.601 NTSC
Matrix coefficients                      : BT.601
Color range                              : Limited
Audio #1
Duration                                 : 44mn 2s
Bit rate                                 : 448 Kbps
Stream size                              : 141 MiB (24%)
Title                                    : English
Audio #2
Format profile                           : Dolby Digital
Duration                                 : 44mn 2s
Bit rate                                 : 192 Kbps
Stream size                              : 60.5 MiB (10%)
Title                                    : Director's Commentary
Text
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Title                                    : English
Menu
00:00:00.000                             : en:Chapter 1
00:09:05.127                             : en:Chapter 2
00:16:25.275                             : en:Chapter 3
00:25:21.603                             : en:Chapter 4
00:33:31.718                             : en:Chapter 5
Regards, MadMax
Serviio Beta Tester
Samsung Series 6 UE32H6400 (3D Full HD Smart TV)
Synology DS1512+ / 3GB Ram / 5x 3TB WD Red Edition HDDs with 5.2 firmware running Patters Serviio package for Synology NAS
Post Tue Mar 03, 2015 12:18 pm
Re: Sony Bravia KDL-22EX320 - Audio / no picture
The SAR / DAR values of your source is not supported by our device. You should transcode your file.
You can also create a custom profile that you can manually select on serviio console when you want to see such files (hope your DS1512+ could support it).
Edit the ./serviio/config/profiles.xml file (make a backup before)
Add the following lines at the end of file, just before the last </Profiles> element.
   <Profile id="custom" name="Sony Bravia TV (2010) *custom*" extendsProfileId="sony2010">
         <Video targetContainer="mpegts" targetVCodec="h264" maxVBitrate="12000" forceVTranscoding="true" targetACodec="ac3" aBitrate="384" DAR="16:9" forceInheritance="true">
            <Matches container="*" vCodec="h264" />
Save the file, then restart serviio service or simply reboot your PC to reload profile.
You can now either select custom profile or select default 2011 profile for your device on serviio console.
prmadmax
Post Tue Mar 03, 2015 11:28 pm
Hey,
That worked great thanks :)
Regards, MadMax
Serviio Beta Tester
Users browsing this forum: Google [Bot] and 3 guests
