ServiioGo not listing contents
a7mag3ddon
Post Thu Mar 05, 2015 1:52 pm
I am just testing the 'over the internet' things before buying the Pro version and I have a couple of problems.
1) Using Serviio Go (doesn't ask me to login)
I can connect to the server but when I click on folders or Last added ect there is not content showing.
2) Media browser method.
When I open my server using the media browser method, I can see folders and enter them and see the tv shows however when I click on play nothing happens.
What am I doing wrong?
I have set the server to transcode to the easiest method, leaving audio intact (just so I can get something streaming)
I have a password set and on the media browser I can log in.
Post Thu Mar 05, 2015 7:38 pm
Re: ServiioGo not listing contents
a7mag3ddon wrote:I am just testing the 'over the internet' things before buying the Pro version and I have a couple of problems.
ServiiGo will automatically setup the server using the default settings. Have you set the default access group to Limited Access? If you log out of the server you will see the list of configured servers, does it say Limited Access or No Restriction? If limited, Long click and select edit.
a7mag3ddon
Post Thu Mar 05, 2015 7:45 pm
Default access group is set to no restriction
Post Thu Mar 05, 2015 7:47 pm
Also forgot to ask, which OS are you using, if Linux, which version of ffmpeg?
a7mag3ddon
Also why doesn't serviiGo ask for the server password?
a7mag3ddon
Post Thu Mar 05, 2015 7:48 pm
I'm using windows 7 x64
Post Thu Mar 05, 2015 7:49 pm
a7mag3ddon wrote:Also why doesn't serviiGo ask for the server password?
Because it got it from the server when you added it to ServiiGo (have to be on your home WiFi for the auto setup).
a7mag3ddon
Post Thu Mar 05, 2015 7:50 pm
I wasnt on my home network when i installed it on my phone
I shall uninstall and re-install it i think.
Post Thu Mar 05, 2015 8:02 pm
a7mag3ddon wrote:I wasnt on my home network when i installed it on my phone
How did you add the server, manual (enter details) or automatic (just select).
Either way, that shouldn't affect what is listed. Could you check the Serviio log to make sure there aren't any errors?
a7mag3ddon
Post Thu Mar 05, 2015 8:03 pm
Thanks for the advice! It now works internally (home network) and over 4G and ect WIFI.
I guess i just needed to add the server internally first so it could get some settings?
now i can test when i get to work and purchase the pro version if alls well.
Users browsing this forum: No registered users and 74 guests
