Samsung D series mkv
Galactus
Post Thu Mar 05, 2015 1:46 pm
I have a problem with playing some mkv files on my Samsung D series. I can play files from USB flash on my TV or through serviio media browser on any PC. Is there any solution? Here is media info of problem file:
Complete name : \\GALACTUS\Tv Shows\Star Trek Voyager\Season 1\Star Trek Voyager - 1x03 - Parallax.mkv
Format : Matroska
Format version : Version 2
File size : 550 MiB
Duration : 45mn 55s
Overall bit rate : 1 675 Kbps
Encoded date : UTC 2010-12-06 04:32:38
Writing application : mkvmerge v4.4.0 ('Die Wiederkehr') built on Oct 31 2010 21:52:48
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 45mn 55s
Bit rate : 1 225 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 23.976 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.148
Stream size : 392 MiB (71%)
Writing library : x264 core 107
Encoding settings : cabac=1 / ref=9 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=16 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1225 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.601 NTSC
Matrix coefficients : BT.601
Color range : Limited
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 45mn 55s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 147 MiB (27%)
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : English
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:Chapter 1
00:06:20.713 : en:Chapter 2
00:12:38.466 : en:Chapter 3
00:17:48.942 : en:Chapter 4
00:23:37.457 : en:Chapter 5
00:29:15.628 : en:Chapter 6
00:34:27.857 : en:Chapter 7
00:41:19.477 : en:Chapter 8
Galactus
Post Thu Mar 05, 2015 1:49 pm
Re: Samsung D series mkv
Info is from wrong file. :-) Here it is now:
Complete name : \\GALACTUS\Tv Shows\Star Trek The Next Generation\Season 1\Star Trek The Next Generation - 1x01 & 1x02 - Encounter at Farpoint.mkv
Format : Matroska
File size : 623 MiB
Duration : 1h 31mn
Overall bit rate : 954 Kbps
Encoded date : UTC 2013-08-23 12:43:57
Writing application : mkvmerge v6.2.0 ('Promised Land') built on Apr 28 2013 18:50:30
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Format : AVC
Format profile : High@L4.1
Format settings, ReFrames : 16 frames
Duration : 1h 31mn
Width : 960 pixels
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Writing library : x264 core 135 r2345 f0c1c53
Encoding settings : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=23.5 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.709
Matrix coefficients : BT.709
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 1h 31mn
Channel(s) : 2 channels
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Language : English
Default : No
Forced : No
Post Thu Mar 05, 2015 7:41 pm
try to disable transcoding in the console
Galactus
Post Thu Mar 05, 2015 9:34 pm
I try that but it doesn't help.
Post Fri Mar 06, 2015 12:23 am
Ok, so the DLNA player probably doesn't like the file's encoding (16 ref frames looks suspicious). It might play via USB, but the player component is different to the DLNA one in the Samsung.
I'd recommend reencoding the file.
Galactus
Post Fri Mar 06, 2015 6:33 am
Thank you for quick replies zip. I'll try to reencode files.
