LG 47LA667S Profile for H.265
Pirand92
Post Wed Mar 04, 2015 8:02 pm
Hi guys, I'm a italian guy and I excuse me for my bad english.
Then, my problem is the next: I want reproduce, on my Smart TV LG, video with format H.265 and I need of the right profile.
Anyone have this profile? Or it know where find it?
Thanks for help.
Post Thu Mar 05, 2015 7:45 pm
Re: LG 47LA667S Profile for H.265
Try a Samsung profile for this file.
Pirand92
Post Thu Mar 05, 2015 10:21 pm
Thank for answer, but how do I use the samsung profile?
EDIT: forget it, I find the method to changing profile on Serviio. I tried with Playstation 3 profile and the videos is played on Tv, but it goes in spurts. Now i try the samsung profile and I'll know.
EDIT: I tried the samsung profile and I must say that streaming has improved, but not so much. Tomorrow, I will prove the others Samsung profiles.
Post Fri Mar 06, 2015 12:24 am
The h265 decoder takes alot of CPU - so you'll need a pretty good PC to play these files.
Pirand92
Post Fri Mar 06, 2015 10:52 am
Ok, I have a "i5 2500K" and I set the use on 4 cores, do you believe that not enough?
Post Sun Mar 08, 2015 12:45 pm
it may not, I'm not sure. Try to emable detailed logging, find the ffmpeg command it uses to transcode and run it manually- you'll see the FPS it does
