Sony KDL32EX403 Cannot play avi files
melpen
Post Wed Feb 23, 2011 3:10 pm
Please forgive my lack of knowledge this is all new to me.
Have just bought the Sony Bravia TV KDL32EX403 and trying to get to grips with DNLA.
I am trying to play a video file which is in avi format.
I can see the file on my TV and has a thumb nail picture, but when I try to play the file I get an error "The server is Temporarily unavailable" I can play mpeg2video with no problems.
Here is the ffmpeg.exe file:
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavcodec 52.108 0 / 52.108. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[avi @ 015ecfb0] max_analyze_duration reached
Input #0, avi, from `e:\generic\ultraviolet\ultraviolet.title2.avi`:
title : ULTRAVIOLET.Title2.DVDRip
album : ULTRAVIOLET
encoder : Lavf52.78.4
Duration: 01:23:52.32, start: 0.000000, bitrate: 1497 kb/s
Stream #0.0: Video: h264, yuv420p, 720x388, 25 fps, 25 tbr, 25 tbn, 50 tbc
Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Serviio log:
2011-02-23 14:12:02,921 WARN [ProcessExecutor] Process C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe has a return code of 1! This is a possible error.
2011-02-23 14:12:10,000 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
at org.serviio.delivery.resource.VideoDeliveryEngine.retrieveTranscodedResource(VideoDeliveryEngine.java:160)
at org.serviio.delivery.resource.VideoDeliveryEngine.retrieveTranscodedResource(VideoDeliveryEngine.java:54)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:90)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:116)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:126)
at org.serviio.upnp.webserver.AbstractRequestHandler.handle(AbstractRequestHandler.java:52)
I have seleted the sony bravia tv profile in serviio console.
Do you require any more info ?
can anybody help in what I am doing wrong ?
Post Wed Feb 23, 2011 4:12 pm
Re: Sony KDL32EX403 Cannot play avi files
If you turn on detailed logging (see my signature for link) you should be able to see the FFmpeg command that is used for the transcode. Try executing the command manually in a terminal window and post the (error) result here.
