Which version of Java?
MegaMike
Post Sun Mar 15, 2015 9:01 am
Which version of Java should I have on my system? Java 7 is running now, but should I allow it to upgrade to Java 8? A friend of mine had problems that he claimed was caused by Java 8. Advice?
Post Sun Mar 15, 2015 12:10 pm
Re: Which version of Java?
if you're on Windows or OSX you don't need any Java for Serviio anymore, it comes bundled with the installer and is installed inside the Serviio folder.
Users browsing this forum: Baidu [Spider] and 58 guests
