Sony Bravia TV (2014) *.m2ts files playback
alexb
Post Thu Mar 19, 2015 5:19 am
I have a list of .m2ts files, info shown below.
TV can see only files ## 2, 3, 4, 5, 6, 10, 14, 16, 17, 19.
3, 5 - no sound; 4 - unplayable, 16-19 - seems some info files for BD so not really cares me. Would be very nice to make all file playable and seen in TV :)
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00002.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 471 MiB
Duration                                 : 2mn 31s
Overall bit rate                         : 26.0 Mbps
Maximum Overall bit rate                 : 48.0 Mbps
Menu ID                                  : 1 (0x1)
Format settings, GOP                     : M=3, N=24
Codec ID                                 : 27
Duration                                 : 2mn 31s
Bit rate                                 : 24.4 Mbps
Maximum bit rate                         : 34.0 Mbps
Height                                   : 1 080 pixels
Standard                                 : NTSC
Bits/(Pixel*Frame)                       : 0.490
Stream size                              : 439 MiB (93%)
Color range                              : Limited
Menu ID                                  : 1 (0x1)
Format                                   : TrueHD / AC-3
Muxing mode                              : Stream extension
Codec ID                                 : 131
Duration                                 : 2mn 31s
Bit rate mode                            : Variable / Constant
Bit rate                                 : 640 Kbps
Maximum bit rate                         : 7 839 Kbps
Channel(s)                               : 8 channels / 6 channels
Channel positions                        : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Stream size                              : 11.5 MiB (2%)
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00003.m2ts
Format                                   : BDAV
File size                                : 246 MiB
Duration                                 : 1mn 5s
Overall bit rate                         : 31.3 Mbps
Menu ID                                  : 1 (0x1)
Format                                   : MPEG Video
Format profile                           : Main@High
Format settings, BVOP                    : Yes
Format settings, Matrix                  : Custom
Format settings, GOP                     : Variable
Codec ID                                 : 2
Duration                                 : 1mn 5s
Bit rate                                 : 25.5 Mbps
Maximum bit rate                         : 38.0 Mbps
Bits/(Pixel*Frame)                       : 0.513
Time code of first frame                 : 01:34:51:21
Time code source                         : Group of pictures header
GOP, Open/Closed                         : Open
Stream size                              : 199 MiB (81%)
Menu ID                                  : 1 (0x1)
Format                                   : PCM
Format settings, Sign                    : Signed
Muxing mode                              : Blu-ray
Codec ID                                 : 128
Duration                                 : 1mn 5s
Bit rate                                 : 4 608 Kbps
Stream size                              : 35.9 MiB (15%)
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00004.m2ts
Format                                   : BDAV
File size                                : 98.5 MiB
Duration                                 : 25s 740ms
Overall bit rate                         : 32.1 Mbps
Menu ID                                  : 1 (0x1)
Codec ID                                 : 27
Duration                                 : 25s 25ms
Bit rate                                 : 30.2 Mbps
Standard                                 : NTSC
Bits/(Pixel*Frame)                       : 0.607
Stream size                              : 90.0 MiB (91%)
Menu ID                                  : 1 (0x1)
Codec ID                                 : 131
Duration                                 : 25s 25ms
Bit rate                                 : 640 Kbps
Maximum bit rate                         : 5 562 Kbps
Sampling rate                            : 96.0 KHz / 48.0 KHz
Stream size                              : 1.91 MiB (2%)
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00005.m2ts
Format                                   : BDAV
File size                                : 502 MiB
Duration                                 : 2mn 39s
Overall bit rate                         : 26.3 Mbps
Menu ID                                  : 1 (0x1)
Format                                   : MPEG Video
Codec ID                                 : 2
Duration                                 : 2mn 39s
Maximum bit rate                         : 40.0 Mbps
Time code of first frame                 : 00:04:06:10
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format profile                           : MA / Core
Mode                                     : 16
Codec ID                                 : 134
Duration                                 : 2mn 39s
Bit rate                                 : Unknown / 1 509 Kbps
Bit depth                                : 24 bits
Compression mode                         : Lossless / Lossy
Text
ID                                       : 4113 (0x1011)-CC1
Menu ID                                  : 1 (0x1)
Format                                   : EIA-608
Muxing mode                              : A/53 / DTVCC Transport
Muxing mode, more info                   : Muxed in Video #1
Duration                                 : 2mn 39s
Stream size                              : 0.00 Byte (0%)
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00006.m2ts
Format                                   : BDAV
File size                                : 190 MiB
Duration                                 : 37s 530ms
Overall bit rate                         : 42.3 Mbps
Menu ID                                  : 1 (0x1)
Codec ID                                 : 27
Duration                                 : 36s 954ms
Bit rate                                 : 40.0 Mbps
Maximum bit rate                         : 39.5 Mbps
Standard                                 : NTSC
Bits/(Pixel*Frame)                       : 0.805
Stream size                              : 176 MiB (93%)
Menu ID                                  : 1 (0x1)
Codec ID                                 : 131
Duration                                 : 36s 923ms
Bit rate                                 : 640 Kbps
Maximum bit rate                         : 5 247 Kbps
Stream size                              : 2.82 MiB (1%)
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00007.m2ts
Format                                   : BDAV
File size                                : 813 MiB
Duration                                 : 2mn 45s
Overall bit rate                         : 41.2 Mbps
Menu ID                                  : 1 (0x1)
Codec ID                                 : 27
Duration                                 : 2mn 44s
Maximum bit rate                         : 37.0 Mbps
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Mode                                     : 16
Codec ID                                 : 134
Duration                                 : 2mn 44s
Bit depth                                : 24 bits
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00008.m2ts
Format                                   : BDAV
File size                                : 725 MiB
Duration                                 : 2mn 37s
Overall bit rate                         : 38.6 Mbps
Menu ID                                  : 1 (0x1)
Format settings, ReFrames                : 2 frames
Codec ID                                 : 27
Duration                                 : 2mn 36s
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Mode                                     : 16
Codec ID                                 : 134
Duration                                 : 2mn 36s
Channel(s)                               : 7 channels / 6 channels
Channel positions                        : Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
Bit depth                                : 24 bits
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00009.m2ts
Format                                   : BDAV
File size                                : 490 MiB
Duration                                 : 3mn 55s
Overall bit rate                         : 17.5 Mbps
Menu ID                                  : 1 (0x1)
Format settings, ReFrames                : 3 frames
Codec ID                                 : 27
Duration                                 : 3mn 54s
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Mode                                     : 16
Codec ID                                 : 134
Duration                                 : 3mn 54s
Bit depth                                : 24 bits
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00010.m2ts
Format                                   : BDAV
File size                                : 608 MiB
Duration                                 : 2mn 37s
Overall bit rate                         : 32.3 Mbps
Menu ID                                  : 1 (0x1)
Codec ID                                 : 27
Duration                                 : 2mn 37s
Bit rate                                 : 30.4 Mbps
Maximum bit rate                         : 31.5 Mbps
Bits/(Pixel*Frame)                       : 0.612
Stream size                              : 570 MiB (94%)
Menu ID                                  : 1 (0x1)
Codec ID                                 : 131
Duration                                 : 2mn 37s
Bit rate                                 : 640 Kbps
Maximum bit rate                         : 9 540 Kbps
Stream size                              : 12.0 MiB (2%)
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00011.m2ts
Format                                   : BDAV
File size                                : 804 MiB
Duration                                 : 3mn 37s
Overall bit rate                         : 31.0 Mbps
Menu ID                                  : 1 (0x1)
Codec ID                                 : 27
Duration                                 : 3mn 36s
Maximum bit rate                         : 35.0 Mbps
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Mode                                     : 16
Codec ID                                 : 134
Duration                                 : 3mn 36s
Bit depth                                : 24 bits
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00012.m2ts
Format                                   : BDAV
File size                                : 108 MiB
Duration                                 : 44s 730ms
Overall bit rate                         : 20.3 Mbps
Menu ID                                  : 1 (0x1)
Codec ID                                 : 27
Duration                                 : 44s 44ms
Writing library                          : x264 core 98 r1649 c54c47d
Encoding settings                        : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=tesa / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / weightp=0 / keyint=24 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=40000 / vbv_bufsize=30000 / crf_max=0.0 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=vbr
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Mode                                     : 16
Codec ID                                 : 134
Duration                                 : 44s 32ms
Bit depth                                : 24 bits
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00013.m2ts
Format                                   : BDAV
File size                                : 1 006 MiB
Duration                                 : 3mn 30s
Overall bit rate                         : 40.1 Mbps
Menu ID                                  : 1 (0x1)
Codec ID                                 : 27
Duration                                 : 3mn 29s
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Mode                                     : 16
Codec ID                                 : 134
Duration                                 : 3mn 29s
Bit depth                                : 24 bits
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00014.m2ts
Format                                   : BDAV
File size                                : 1 014 MiB
Duration                                 : 3mn 44s
Overall bit rate                         : 38.0 Mbps
Menu ID                                  : 1 (0x1)
Codec ID                                 : 27
Duration                                 : 3mn 43s
Bit rate                                 : 35.8 Mbps
Maximum bit rate                         : 36.5 Mbps
Bits/(Pixel*Frame)                       : 0.720
Stream size                              : 954 MiB (94%)
Menu ID                                  : 1 (0x1)
Codec ID                                 : 131
Duration                                 : 3mn 43s
Bit rate                                 : 640 Kbps
Maximum bit rate                         : 6 273 Kbps
Stream size                              : 17.0 MiB (2%)
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00015.m2ts
Format                                   : BDAV
File size                                : 981 MiB
Duration                                 : 4mn 34s
Overall bit rate                         : 30.0 Mbps
Menu ID                                  : 1 (0x1)
Format profile                           : High@L4.0
Codec ID                                 : 27
Duration                                 : 4mn 33s
Nominal bit rate                         : 22.8 Mbps
Maximum bit rate                         : 22.8 Mbps
Bits/(Pixel*Frame)                       : 0.458
Writing library                          : x264 core 93 r1542M 5b86182
Encoding settings                        : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x12 / me=hex / subme=2 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=0 / keyint=24 / keyint_min=4 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=abr / mbtree=0 / bitrate=22768 / ratetol=1.0 / qcomp=0.50 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=22768 / vbv_bufsize=25000 / ip_ratio=1.10 / pb_ratio=1.10 / aq=1:1.00 / nal_hrd=vbr
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Mode                                     : 16
Codec ID                                 : 134
Duration                                 : 4mn 33s
Bit depth                                : 24 bits
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00016.m2ts
Format                                   : BDAV
File size                                : 24.0 KiB
Duration                                 : 1s 80ms
Overall bit rate                         : 165 Kbps
Menu ID                                  : 1 (0x1)
Codec ID                                 : 27
Duration                                 : 1s 126ms
Bit rate                                 : 152 Kbps
Standard                                 : NTSC
Bits/(Pixel*Frame)                       : 0.003
Stream size                              : 20.8 KiB (87%)
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00017.m2ts
Format                                   : BDAV
File size                                : 108 KiB
Duration                                 : 1s 80ms
Overall bit rate                         : 768 Kbps
Menu ID                                  : 1 (0x1)
Format                                   : MPEG Video
Codec ID                                 : 2
Duration                                 : 1s 126ms
Bit rate                                 : 731 Kbps
Maximum bit rate                         : 15.0 Mbps
Standard                                 : NTSC
Bits/(Pixel*Frame)                       : 0.015
Time code of first frame                 : 00:00:00:00
Stream size                              : 100 KiB (93%)
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00019.m2ts
Format                                   : BDAV
File size                                : 4.41 MiB
Duration                                 : 6s 930ms
Overall bit rate                         : 5 326 Kbps
Menu ID                                  : 1 (0x1)
Format settings, GOP                     : M=3, N=18
Codec ID                                 : 27
Duration                                 : 7s 7ms
Bit rate                                 : 5 108 Kbps
Standard                                 : NTSC
Bits/(Pixel*Frame)                       : 0.103
Stream size                              : 4.27 MiB (97%)
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00020.m2ts
Format                                   : BDAV
File size                                : 276 KiB
Duration                                 : 2s 970ms
Overall bit rate                         : 740 Kbps
Menu
Menu ID                                  : 1 (0x1)
List                                     : 5120 (0x1400) ()
Complete name                            : F:\Видео\Best of Disc\BDMV\STREAM\00021.m2ts
Format                                   : BDAV
File size                                : 276 KiB
Duration                                 : 2s 970ms
Overall bit rate                         : 739 Kbps
Menu
Menu ID                                  : 1 (0x1)
Thanks in advance!
Post Thu Mar 19, 2015 11:31 am
Re: Sony Bravia TV (2014) *.m2ts files playback
For such weird files, you can use a custom profile that transcode them:
Add this section at the end of profiles.xml just before the last <profiles> element (make a backup before), save, restart serviio service or reboot PC.
Then you can manually select this profile on serviio console when you have problem with some files.
   <Profile id="custom" name="Sony Bravia TV *" extendsProfileId="sony2012">
         <!-- Transcode */h264 -->
         <!-- remove DAR option on next line for U.S. model -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384" DAR="16:9" forceInheritance="true">
            <Matches container="*" vCodec="h264" />
alexb
Post Sat Mar 21, 2015 10:20 pm
Pretty elegant solution with extra profile. Thanks, will try it as soon as will reach me PC
