SeasonVar.ru (Web Resource)
qanatoz
Post Fri Feb 01, 2013 2:45 pm
SeasonVar.ru Web Resource plugin
Source type: Web Resource
Media type: Video
Version: 6.0
Plugin allows to watch custom online movies and series from SeasonVar.ru
Changes in version 2.0
  • Added support for new urls types
  • Bug fixes
  • Added versioning support
Changes in version 3.0
  • Bug fixes
Changes in version 4.0
  • Bug fixes
Changes in version 5.0
  • Bug fixes
  • Added thumbnail support
Changes in version 6.0
  • Support for Serviio 1.5
Changes in version 7.0
  • Support of new SeasonVar layout
Changes in version 8.0
  • Fixed issue with GZIP streams
Changes in version 10
  • Fixed minor issues after last site upgrade
  • Added support to select different translations. Supported translations: Any available for given season (example below in URL examples)
Changes in version 11
  • Fixed issue with translations
Changes in version 12
  • Added To4kaTV translations support
Changes in version 16
  • Bug fixes
Changes in version 17,18
  • Some bug fixes
  • Additional translations support
Changes in version 19
  • Some bug fixes after site changes
URL example:
How to select translation:
*Note: The URLs must be configured as a Web Resource.
SeasonVar.groovy
Version 19
(14.14 KiB) Downloaded 1820 times
qanatoz
Post Sun Jun 09, 2013 7:58 pm
Re: SeasonVar.ru (Web Resource)
Plugin updated.
  • Bug fixes
qanatoz
Post Tue Sep 02, 2014 4:32 pm
Plugin updated.
  • Bug fixes
PervySage
Post Sat Oct 25, 2014 12:42 pm
thanks! much appreciated!
works really well
AlexSG
Post Sun Jan 11, 2015 2:50 pm
http://seasonvar.ru/serial-8431-Mahabharata_2013.html doesn't works. Servio 1.4.1.2 + Plugin from 1st post + TV Sony KDL-42W828 :( Can anybody help? Thanks.
rcmc_ronny
Post Thu Jan 15, 2015 7:19 pm
last Version does not compile (I am using serviio 1.5)
2015-01-15 20:17:58,441 WARN [PluginCompilerThread] Plugin SeasonVar.groovy failed to compile: startup failed:
/opt/serviio/plugins/SeasonVar.groovy: 3: unable to resolve class org.restlet.engine.util.CookieSettingSeries
@ line 3, column 1.
import org.restlet.engine.util.CookieSettingSeries
1 error
Post Thu Jan 15, 2015 10:25 pm
Updated to version 6, compiles in 1.5 now.
AlexSG
Post Thu Jan 15, 2015 10:50 pm
Upgraded Serviio to 1.5. Even thumnails in "Online" Folder are disappeared now. Can anybody help me? :(
AlexSG
Post Thu Jan 15, 2015 10:56 pm
Upgraded plugin to the latest version and it works fine. Thanks! :)
Jurijlv
Post Mon Mar 23, 2015 12:58 am
Hello, today after updating my Synology DSM to version DSM 5.1-5022 Update 4 this plugin stopped working. All folder disappeared. LOG is in the attachment.
Serviio log extract.txt
(2.27 KiB) Downloaded 1334 times
qanatoz
Post Wed Mar 25, 2015 9:08 pm
Not related to upgrade, they again changed the site structure.. dooh.
I will post the fix tomorrow.
Jurijlv
Post Wed Mar 25, 2015 10:24 pm
Sorry for the wrong info, but anyway thank you very much for your support and great job!!!
qanatoz
Post Fri Mar 27, 2015 11:00 am
Plugin updated
Jurijlv
Post Sat Mar 28, 2015 2:53 am
Everything works. Thank you VERY much. Спасибо!
mortifactor
Post Thu Apr 16, 2015 12:34 pm
I have errors in log:
2015-04-16 19:28:38,991 WARN  [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-5000-Simpsoni-24-season.html, waiting for expiry time to try again: Unexpected error while invoking plugin (SeasonVar): Not in GZIP format
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (SeasonVar): Not in GZIP format
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:78)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:186)
   at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:203)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.getOnlineItems(FeedUpdaterWorker.java:191)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:108)
Caused by: java.util.zip.ZipException: Not in GZIP format
   at java.util.zip.GZIPInputStream.readHeader(GZIPInputStream.java:165)
   at java.util.zip.GZIPInputStream.<init>(GZIPInputStream.java:79)
   at java.util.zip.GZIPInputStream.<init>(GZIPInputStream.java:91)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
   at java.lang.reflect.Constructor.newInstance(Constructor.java:422)
   at org.codehaus.groovy.reflection.CachedConstructor.invoke(CachedConstructor.java:77)
   at org.codehaus.groovy.runtime.callsite.ConstructorSite$ConstructorSiteNoUnwrapNoCoerce.callConstructor(ConstructorSite.java:102)
   at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCallConstructor(CallSiteArray.java:54)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callConstructor(AbstractCallSite.java:182)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callConstructor(AbstractCallSite.java:190)
   at SeasonVar.postToURL(SeasonVar.groovy:197)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
   at java.lang.reflect.Method.invoke(Method.java:497)
   at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite$PogoCachedMethodSiteNoUnwrapNoCoerce.invoke(PogoMetaMethodSite.java:267)
   at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite.callCurrent(PogoMetaMethodSite.java:52)
   at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCallCurrent(CallSiteArray.java:46)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:133)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:145)
   at SeasonVar.getSourceFromPlayer(SeasonVar.groovy:112)
   at SeasonVar.extractItems(SeasonVar.groovy:60)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
   at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
   at java.util.concurrent.FutureTask.run(FutureTask.java:266)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
   ... 1 more
lamo4ok
Post Thu May 14, 2015 7:55 pm
Привет, испытал приятное удивление от наличия вашего плагина для этого медиасервера! Вопрос такой - планируется ли возможность добавления ссылок не на отдельные сезоны, а на сериалы целиком?
И не совсем в тему вопрос, тем не менее - возможна ли работа плагинов для данного медиасервера таким образом, чтобы онлайн-контент попадал не только в категорию онлайн, но и в другие категории, а конкретно - в сериалы? Было бы очень удобно, если там можно было видеть новые сезоны и их серии ну или хотя бы просто серии сезонов.
Заранее спасибо за ответы.
lamo4ok
Post Thu May 14, 2015 8:44 pm
qanatoz
Post Mon Aug 03, 2015 8:13 pm
mortifactor wrote:I have errors in log:
   ... 1 more
Fixed now, download v 8.
lamo4ok
Post Mon Aug 03, 2015 8:37 pm
qanatoz wrote:Fixed now, download v 8.
Thx!
PervySage
Post Sat Sep 19, 2015 4:02 am
I keep getting the following errors while trying to add any resources.
2015-09-19 13:43:51,165 WARN [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-10512-Interny-4-season.html, will try again soon: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
Caused by: java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:6202)
at org.codehaus.groovy.runtime.dgm$310.invoke(Unknown Source)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at SeasonVar.getPlaylistURL(SeasonVar.groovy:102)
at SeasonVar.extractItems(SeasonVar.groovy:56)
... 1 more
Help would be greatly appreciated
Return to Available plugins
Users browsing this forum: Google Adsense [Bot] and 13 guests
