1.5.1 none of my devices are able to ff or rewind
jerrelle630
Post Thu Mar 26, 2015 6:23 pm
Since the update, I am unable to ff or rewind. What happens is the video freezes with the ff or rewind image shown. When I stop the video and try to restart it, serviio remembers where I left off, but only plays sound. My entire network consist of Sony devices/ blurays/ media streamers except for Xbox one and that does it as well. Any help would be appreciated.
jerrelle630
Post Tue Mar 31, 2015 10:41 pm
Re: 1.5.1 none of my devices are able to ff or rewind
No one else is having the problem? Removed 1.5.1 and reinstalled it, same situation. ended up going back to 1.4.2 until an update comes out.
Post Tue Mar 31, 2015 11:36 pm
Any chance the wrong profile was selected after upgrading to 1.5.1? I have no idea if any profiles were modified between 1.4.2 and 1.5, other than the addition of a Samsung H Series profile. But something certainly sounds strange. I encountered no problems after upgrading. As my sig shows, I have a good mix of equipment. However, I will also state that I seldom FF or rewind, but do pause on occasion. I did just try using all three on my Sony BDP-S3100 and had no difficulty. This was with a DVD ripped into a MKV container, and I tried it with and without captions enabled.
If you want to see if it was the profile, your 1.4.2 profile was backed up (renamed) when you installed 1.5.1, so you could rename it back to profiles.xml and restart the Serviio process to see if that cures the problem.
